Need some help with the car starting to overheating. More inside...
It has never passed the 1st tick mark on the right side of the center in the water temp gauge.
I can't duplicate it, it can be in hot weather with the AC on or off in traffic and the car will NOT start to overheat. And there are times its 60 deg cruising on the freeway and it will starts to overheat.
It seems to be happening much more when I drive uphill on the freeway.
Would it be the water pump or the thermostat or something else?
Here is a picture of what I see.
I am going to replace the temp sensor and see what is what.
TIA
Next would be to check your coolant and make sure its not more than 60/40 ('coolant' actually cools worse than water). While there make sure it is actually 'clean' with no oily residue (blown head gasket). Then then make sure the thermostat opens at the correct temp (sometimes can be done in car with a thermometer), then check the temp sensor.
