Oil smoke... Where is the oil coming from?
Old Nov 23, 2008 | 10:23 AM
rtheriaque's Avatar
New Member
Default Oil smoke... Where is the oil coming from?
Guys,
I have an 01.5 Avant, 97k miles. The car has TT diverter valves and GIAC programming.
A few weeks ago, I was having problems with blowing oil smoke, especially on startup. There was significant oil in both intercoolers, leading to a diagnosis of blown turbos. The turbos were replaced- that's when the diverters were installed and the GIAC programming flashed.
I've put about 1,000 miles on the new turbos with no problems (nor any even "spirited" driving, as I was advised at least 1,000 miles or so for break-in).
I noticed the same smoke on startup today. I dropped the skidplate and the driver's side intercooler hose was filled with foamed oil again.
What could this be? Bad new turbos (from Audi)? Something else entirely?
Any help would be greatly appreciated.
Thanks,
Rob Theriaque
Old Nov 23, 2008 | 10:41 AM
pitchS4's Avatar
Where are you seeing the smoke? Were the ICs cleaned?
Old Nov 23, 2008 | 10:42 AM
rtheriaque's Avatar
New Member
Tailpipes. The intercoolers were cleaned and there was no smoke for about a month.
Old Nov 23, 2008 | 10:58 AM
BLK01S4's Avatar
sounds like your turbo took a **** agian.
Old Nov 23, 2008 | 11:00 AM
rtheriaque's Avatar
New Member
Default A turbo from Audi dying in less than 1,000 miles??
I can't afford to replace the effing thing again this soon.
Old Nov 23, 2008 | 11:04 AM
BLK01S4's Avatar
Default did they see u put the updated ECU in the car?
If not and Audi did the install put the stock ecu back in and take it back to the dealer.
Old Nov 23, 2008 | 11:06 AM
rtheriaque's Avatar
New Member
An independant shop did the turbos and the flash.
Old Nov 23, 2008 | 11:26 AM
pitchS4's Avatar
Should be under warranty
Old Nov 23, 2008 | 11:27 AM
SIMPPLY @ WMS's Avatar
Former Vendor
take it to another shop and have it looked at. Where are you located ?
Old Nov 23, 2008 | 11:28 AM
rtheriaque's Avatar
New Member
Default This is literally the first big job I haven't done myself...
When a part under warranty fails, do they typically cover the labor to replace it? With something like this, if not, what's the bloody point?
