problem, or no problem?
Old Nov 9, 2006 | 08:18 PM
UberVier's Avatar
Default problem, or no problem?
<img src="http://pictureposter.audiworld.com/17771/img_1045.jpg">
<img src="http://pictureposter.audiworld.com/17771/img_1047.jpg">
no idea how long it's been like this, could be as much as 3k miles (since I changed the oil last time). It doesn't look *that* bad, not a failure of the seals, but that driver's side shaft seal and the driveshaft seal look to be the culprits. Not RMS, I checked oil level, and it's fine, and the seepage is not from the engine/trans connection at all.
I want to change the trans/diff fluids soon, should I be worried that the motul 300 will all seep out?
Great. I was about to seriously consider coilovers.
Old Nov 9, 2006 | 08:24 PM
Mike2kS4's Avatar
Default No problem: Looks like normal seepage to me.
If it were anything more your cats would look nasty. The axleshaft looks ok too.
When you change the tranny fluid, dip a pinkie in there and if you can feel fluid, it's normal fluid loss.
Old Nov 9, 2006 | 08:39 PM
UberVier's Avatar
Default thanks Mike :)
I was going to email this to you and Hal personally, I'm embarassed any time my car wets itself
Motul, here I come!!!!
oh, any rec for the rear diff fluid? I'm in North Carolina, temps are mild, we see a range from 15 to 92 or so in summer.
Old Nov 9, 2006 | 08:48 PM
Mike2kS4's Avatar
Default I'm going NEO RHD in the rear and tranny in the Avant.
I currently have RHD in the Sedan's tranny (Schmooooove) and Redline 75/90 in the rear. Seems fine.
RHD has some amazing shock absorption properties without any nasty sulfur additives and is fluid in a broad temperature range
Old Nov 9, 2006 | 08:55 PM
UberVier's Avatar
thank you, sir.
Old Nov 9, 2006 | 09:28 PM
spt@lubzu's Avatar
how does the motul compare to the neo for the rear oil?
Old Nov 9, 2006 | 09:56 PM
Mike2kS4's Avatar
Default Either should work fine: Our diffs aren't fragile.
I'm just a geek when it comes to this stuff, and want what I believe is best.
Old Nov 9, 2006 | 10:08 PM
spt@lubzu's Avatar
just noticed your sig,whats up with all that bling bling on your avant?
 Pouria Savadkouei
 Michael S. Palmer
Old Nov 9, 2006 | 10:16 PM
Mike2kS4's Avatar
The transformation has begun
Old Nov 9, 2006 | 10:27 PM
spt@lubzu's Avatar
nooooo bling bling,rather have it CF
