RV: log VAG from blocks 3 and 115 regarding an earlier post on my boost problems
https://forums.audiworld.com/s4/msgs/2810277.phtml
If anyone can help, please email me for the full log.
Thanks
2. Your requested boost never even reaches 1bar. What is the Oettinger chip? Never seen it and the website doesn't provide any info.
3. Despite your requested boost being "1950" max, your actual spikes to "2460"....which is a little over 21 psi after atmospheric subtraction. What altitude are you at?
So, you are massively overboosting. Do you have a BRAND NEW N75 valve in there? Don't use that N75k race valve and don't use an old OEM N75 valve.
What was the deal with your wastegate actuators?
I should mention that I'm not doing it looking for boost increase, just was the only n75 that was in stock.
The term "parallel" usually refers to how one mounts a manual boost controller (MBC) - whether it's "in parallel" with the N75 valve or "alone" with the N75 taken out of the loop.
In your case, saying you have an N75k valve in parallel isn't really informative. It suggests that you have an MBC but there's no need for an MBC on a stock car...unless you are deleting the N75 valve...in which case you'd need other things to make it work properly (MAP clamp, etc).
Thanks for the input.
