Microphone sensitivity adjustment in MMI
Unfortunately, when I go to the telephone volume settings in the MMI, the Microphone Sensitivity option appears in red and cannot be adjusted.
I've also seen reference to hidden menus enabled by a Vagcom update (see below), but I haven't been able to implement this.
Adjust bluetooth microphone sensitivity
Hidden menu
Diagnose
Settings
Mic sensiblity - choose -6db/0db/+6db
Any ideas on how to improve the microphone response or should I be taking this into the dealer (maybe one of the mic's is faulty).
Thanks.
Regarding the Microphone sensitivity adjustment in the Telephone - Settings - Volume section of the MMI............do you know if it's normal that this setting is displayed in MMI but not adjustable? Microphone sensitivity shows as positioned at the mid-way point, but unlike most settings in MMI, there seems to be no way to change it.
EDIT: Actually, now that I think of it, one time a customer of mine came in and in the service department they DID go into that setting and turned it up right from the MMI. I think he was in the middle of a phone call when they did it though in order to change it.
Unfortunately, I've tried the full range of microphone sensitivity adjustments and the mic is still cutting in and out during a call. It appears I have a faulty microphone. The fact that it works about 50% of the time makes it look like a short or possibly one of the two microphones is faulty. I've tried shutting off radio, fans, and all other ambient noise, but no luck.
Looks like I'll be taking it in. Sad.
I finally made it into the dealer this evening and coincidentally there is now a TSB that covers a Phone update for Windows and Android devices (not affecting iPhones). I did not note the TSB number. Apologies. My previous Phone driver was version 14.41.1. The new version is 15.26.2. The update had to take place using an SD card. Entire process took about 15 minutes.
Placed a few test calls and it now works as intended with no call quality issues whatsoever. Glad to be able to put his behind me. Hope this helps.
Thanks.
Just to confirm, the phone update you're referring to is for the S6 (MMI) and not the phone itself.
Thanks.
