TT (Mk2) Discussion Discussion forum for the Mk2 Audi TT, TT-S and TT-RS Coupe & Roadster produced from 2007-2014
NEED HELP...Audi TT MK2 Suspension
Old 07-05-2015, 11:54 AM
dorianint31's Avatar
Default NEED HELP...Audi TT MK2 Suspension
Hi guys! I just have a quick question regarding my shocks and struts. I have a 2008 Audi TT Quattro 3.2 V6 with Magnetic Ride. I was informed that my front and rear should be replaced as they seem to be leaking. I can't really seem to find shocks for the "magnetic ride" and I'm not too keen on going to the stealership. My question is...is it necessary that I replace them with "magnetic ride" shocks and struts? I'm not concerned about losing that option being that I very rarely use the option anyhow. If someone can let me know whether this is technically possible that would be greatly appreciated.
Thanks in advance,
Dorian
Old 07-07-2015, 07:13 PM
benmontemayor's Avatar
Thanks in advance,
Dorian
Hi Dorian,
You can replace with regular struts and shocks for 3.2 PQ35 chassis like TT 3.2, A3 3.2, R32 mk2. You need to code OUT Magnetic Ride controller so it will not throw codes. I have a set from a 3.2 A3 S-line if you're interested. Make me offer. You pay shipping.
Old 07-07-2015, 08:10 PM
Pardon my ignorance here.....but can you explain how to code out the AMR?
Old 07-08-2015, 07:12 AM
You will need VCDS to remove suspension computer from CAN gateway.
Old 12-28-2015, 11:31 AM
arshagtt's Avatar
Default Audi TT RS suspension on Audi TT?
Hello Everyone,
I have a 2011 Audi TT. My suspension is feeling a little soft, and I was wondering if it would be possible to modify my suspension to the OEM TT RS suspension? (shocks and coil overs). Have anyone tried this before? Thank you so much!
Old 01-16-2016, 06:46 AM
martian4000's Avatar
Hello,
My question is has anyone sourced these magnetic ride shocks? I've called Audi, requested online quotes and only receive the below listed parts which are not magnetic from all I can tell.
With the S3, R8 using this system as well as GM,Ferrari why can't I find replacements anyplace? Is code out the only option?
Part Number
8K0513025F
8J0413029F
Old 04-11-2016, 06:32 AM
Alan4.2's Avatar
Originally Posted by martian4000
Hello,
Part Number
8K0513025F
8J0413029F
Have you looked at this parts source?
SHOCKS & COMPONENTS for 2008 Audi TT Quattro
I have just started to look into this since Audi has told me that my rear shocks are leaking and need replacing. They quoted $1750 as a cost. Have to be able to get the job done cheaper some where.
Old 04-11-2016, 01:20 PM
Thank you for your response. The thing that threw me was no illustrations ever shows the wiring ports. You're right, these are the right parts. The rears should be easy to do and a savings of $800 roughly. At least it was easy when I replaced my Passats rears. Since my TT was used I plan to go one more round of Mag Rides just to see the full advantage and then go coilovers maybe. I hope you find it to be an easy fix. Thanks again for the link.
Old 01-18-2018, 03:52 AM
Carl Keehn's Avatar
If your after front and rear you should also replace the SPRINGSS
THEY ARE AS FOLLOWS FOR A 08 Front struts 8J0413029L x 2 and your springs 8J 0411105J match color
rear are as follows 8J0513025F x 2 and springs 8J0511115k color 1 Brown 1 Orange match color
1wheel_drive
TT (Mk2) Discussion
07-17-2018 10:48 AM
dymio2
TT (Mk2) Discussion
07-05-2015 08:38 AM
proport
03-04-2009 05:54 AM
Zetetic
Audi A3 / S3 / RS 3
12
12-30-2008 02:32 PM
Morris
TT (Mk1) Discussion
02-15-2000 10:05 PM
Quick Reply: NEED HELP...Audi TT MK2 Suspension
