The reason why the A4 at idle seems like it will cut off
Old 07-24-2016, 07:54 PM
james.bond's Avatar
Default The reason why the A4 at idle seems like it will cut off
I looked at the RPM on the tachometre when starting the car, it is lower than 1,000 RPM, I know from past experience from prior cars when the RPM is this low at idle, the car will stall, turn itself off and accelerate roughly. This is a flaw Audi has to fix, this is NOT normal.
The next time anybody start their car, prior to driving off, look at the tachometre. My car always feels like it will turn itself off and I had to find the reason why.
Old 07-24-2016, 08:18 PM
plat27265's Avatar
Since your car is a new B9 A4, it will be best to take it to the dealer and have them check it out. This way, you find out the reason why it's acting up like that.
Old 07-24-2016, 08:25 PM
james.bond's Avatar
Everybody on this site that has the same car mentioned the same issue on a recent thread, even people that tested the car in You Tube mentioned the exact same thing, this is not specific to me, this is Audi A4 car wide.
Old 07-24-2016, 09:10 PM
OHWHATDA's Avatar
I haven't noticed anything with my 2017 A4 that would indicate to me that it's about to stall or cut off. Are you talking about the fact that the car actually does shut off when you're pushing down on the break to save gas?
Also, if you're in Sport the car idles at a solid 2k so if you like a higher idle can always just shift it to Sport or leave the car in Dynamic.
Old 07-24-2016, 09:40 PM
james.bond's Avatar
No. When the car starts on for the first time, it feels like it will cut off, it never does though but t he RPM is way below 1,000, it should be higher than 1,000 RPM or just at 1,000 RPM.
I turn off that stop / start feature, however, in that mode, the engine by design does cut itself off.
I have an individual mode for my personal car settings and most are in comfort mode with the exception of steering which is in dynamic mode.
Old 07-25-2016, 02:12 AM
SYMAWD's Avatar
On a cold start it's below 1,000? After that, below 1,000 is normal for just about any car.
Old 07-25-2016, 03:45 AM
bob m's Avatar
Here's the link to a previous discussion about the roughness on idle. I brought my 2 week old A4 in last month just for that complaint L. They checked and said it's normal for this car. Scratched my head then and I accept it for what it is, though still scratching my head about it.
https://www.audiworld.com/forums/a4-...start-2903676/
Old 07-25-2016, 08:19 AM
Arkive's Avatar
There's a link in that thread bob just posted to a TSB that addresses this exact issue. Long story short: Working as intended.
Old 07-25-2016, 08:59 AM
KurtEiger's Avatar
Cold start: engine idles at 1200 for about 60 seconds then drops to just below 800 rpm.
Warm start: car idles just below 800 rpm upon start.
This is completely normal.
Old 07-25-2016, 05:01 PM
VM
VM's Avatar
... and basically matches the behaviour of every other tach-equipped fuel-injected car I've observed.
Quick Reply: The reason why the A4 at idle seems like it will cut off
