Gas Pedal is very heavy
Old 11-23-2016, 04:04 AM
1stq7's Avatar
Default Gas Pedal is very heavy
The gas pedal gets very heavy when the q7 reaches 70mph. Does yours do that?
It feels hard to accelerate the q7 at that speed.
Old 11-23-2016, 08:30 AM
discogone's Avatar
I don't think the pedal is heavy, I think it presses down fine, the car simply does not accelerate as much as you think it should (as you described next).
If I am driving in Auto mode, yes it feels hard. If I need to accelerate at that speed, I either switch to Sport mode or shift down.
Old 11-23-2016, 09:33 AM
1stq7's Avatar
I am driving in Auto mode as well. I feel like it going against me when I press it to increase the speed.
Shifting it down to 7th gear will give me immediate power.
Wanna see if this is normal.
I was driving an E90 before this car. The E90 would give me immediate power almost all the time
Old 11-23-2016, 06:20 PM
GDawgA4's Avatar
Keep in mind the weight of the Q7...it's 5000 lbs of mass to move vs the E90 is around 3500 lbs. IMO the Q7 moves pretty well given its size, even at 70+ mph.
Old 11-24-2016, 06:23 AM
jallen0's Avatar
I had that same issue and I kept thinking it had something to to with Pre-Sense. You would literally smash the gas pedal down and it would take 2-4 seconds to engage with the power you were expecting. It actually made me hesitant in some cases to initiate the move I wanted to make. I will also say I typically drove in Comfort mode,
Old 11-25-2016, 05:49 AM
1stq7's Avatar
That's true. There have been a couple of times that I hesitated to make lane change.
I drive in auto mode all the time. It has 1250 miles with long term memory showing 23.3mpg. The mpg is great. So, just down shift if you need to pass someone at above 70mph. Fun fun.
Old 04-25-2017, 09:21 AM
BigKutta's Avatar
I'd like to bring this thread back up. This is my first Audi, so the pedal seems very heavy and (physically) resistant to me. Anyone else feel the same way? Is this normal?
Old 04-25-2017, 01:10 PM
RSQ9's Avatar
Try Dynamic/Sport
Old 04-25-2017, 04:56 PM
dsyeggy's Avatar
I tested this on the way home today. I was doing 70, traffic opened up and I hit the gas. Next thing I knew i was doing 90. Gas pedal felt normal.
Make sure your floor mat is installed properly and not affecting the gas pedal in any way.
Old 04-25-2017, 05:57 PM
zelosu's Avatar
Get used to pull the shifter and use Sport mode when passing/merging or in need of quickly accelerating. What you describe is normal behaviour of a 5000lbs car in that's supposed to give you decent fuel economy. The Sport mode will rev the engine higher and give you instant torque.
nicksq5
Q5/SQ5 MKI (8R) Discussion
09-16-2016 06:37 AM
Yoshimura
08-10-2014 10:17 AM
Nica
12-03-2003 09:26 PM
CK NYoC
03-12-2001 06:46 PM
RiceBoy53
12-15-2000 09:36 AM
Quick Reply: Gas Pedal is very heavy
