Max tire size for 18"?
Old 04-25-2017, 03:47 PM
A5cabguy's Avatar
Default Max tire size for 18"?
What is the maximum tire that will fit the 18" rim? 2011 a5 cab?
Old 04-25-2017, 04:09 PM
Glisse's Avatar
Obviously an 18" tyre
As for width, that will depend on the width of the wheel, which you haven't stated.
Audi made both 7.5 and 8.5" width wheels for 18" fitments. If it is the latter, a 255/40 x 18 would work (OEM is 245). Assumes the wheels are OEM offset or thereabouts.
Old 04-25-2017, 06:13 PM
SloopJohnB@mac.com's Avatar
Default U can also check with TireRack
Audi is notorious for putting wider tires on rims than otherwise.
Old 04-26-2017, 03:47 PM
A5cabguy's Avatar
8.5" rim
Calculator shows 285 35 nearly the same circumference but adds 1.1" of width.
Speedometer would barely be affected.
Has anyone put 285 35's on an 8.5?
Old 04-27-2017, 01:58 AM
19hole's Avatar
9.5" wide is the minimum recommended wheel width for a 285/35-18 tire. It probably would fit on an 8.5" wheel, but the installer might find it hard to get on and after he does git it on the sidewalls will bulge a fair amount.
Old 04-27-2017, 09:46 AM
Default I'd rather replace a curbed tire than a damaged rim.
Of course, damaging the tire by curbing it might get an instant flat....
Old 04-28-2017, 01:55 PM
wkhanna's Avatar
agreed, Sloop.
however, curb rash on the wheels gets expensive, too.
yes, there is a handling/safety issue with putting too wide of a tire on the rim.
but have always put +10 mm tires on The Wife's Audi's to minimize wheel damage from her parking-by-feel process.
Rccooke
10-05-2013 08:03 PM
my2000apb MEGABOOST
Wheels & Tires Discussion
05-07-2008 09:52 AM
GTA_Driver
03-27-2007 07:14 AM
David
04-15-2004 05:17 PM
HighPSI
03-03-2004 08:55 AM
Quick Reply: Max tire size for 18"?
