Car Play not connecting randomally
Old 08-18-2017, 06:01 AM
Pasquale Colella's Avatar
Default Car Play not connecting randomally
Zero issues with this in wifes 18 SQ5.
The 17 I just picked up is not always connecting to Car Play. Made sure the usb is plugged in, switch the sides that the lighting connector is going on.
Old 08-19-2017, 04:43 AM
leafnut73's Avatar
Default I have the same problem
i also have intermittent trouble establishing a connection with CarPlay. 75% of the time a simple plug-out/plug-in fixes it, however, the remaining 25% of the time only restarting the car will be the remedy. Help here would also be appreciated!
Old 08-19-2017, 07:32 AM
Lectoid's Avatar
I wonder if you just restarted the MMI instead of the car it would work. I don't recall how to do it but it's a series of buttons on the interface.
Old 08-20-2017, 05:15 AM
RickObe's Avatar
MMI reset: hold Nav and Radio levers forward and then push down the center ****.
Old 08-20-2017, 07:30 AM
discogone's Avatar
It may be similar to this old thread, try to clean up the lightning port and see if that helps:
https://www.audiworld.com/forums/q7-...y-mmi-2906923/
