So this happened... :(
I Parked in a large parking lot next to a curb. When I went to leave I forgot I was next to it, I made a hard right turn and bam. Sooooooo pissed.
Not sure if I should drive the 400 miles back home or wait for a tire to come in to be repaired. I'm visiting friends out of state and dealers / Tire centers are closed until Monday!!!! The tire isn't flat and not loosing any air.
That sucks. That tire damage to the sidewall is bad. I would definitely try to replace before the 400 mile trip. If you can't then swap it to the rear for the drive. Don't forget that the new tire needs to match tread depth of others so it does not screw up the AWD system. This often means shaving the new tire to match. Do not use mismatched tires.
The car has 1,200 miles on it so I think I should be fine repairing this one tire only right?
Correct. That tire is not repairable and would be dangerous to drive on. Be sure to replace with same brand, model and size. If not available locally, TireRack should be able to get one to you overnight.
Be safe.
You know this was the one reason i bought the extra tire care warranty. It was $1800 but covers this. You get a new tire and wheel under the warranty. I thought at first it was a rip off but i live in NY and huge potholes are a normal every day occurrence. Havent used it yet but pretty sure its just a matter of time.
