Orange reflectors up front
My car just got to port! I just ordered some new reflectors painted glacier white from Tag Motorsports. Can you guys help me on something? Is that reflector just a reflector or is there an actual light in there? On my S7 it was a light that i disabled through Vag com. If it is a light, does anyone know how to disable it with OBDeleven?
Thanks guys,
Thanks guys,
Thanks guys,
Thanks guys,
There is a light in there but I have no idea about disabling them. I did read though that you have to remove the front bumper to install them and after R&R the front bumper all of the sensors need to be re-calibrated by Audi, not cheap. I hope you find out different because I would love to change out mine to the painted versions.
For example, when you take off the front bumper, which I have done on my car twice to install an OEM RS7 grille, there was no calibration needed, sensors everything is perfect. Another example, people say online to get the front rings off you have to pull the bumper off, false there is a workaround for that as well. I will wait to get my car and see what type of access I have to those reflectors and I will report back.
Unless it is completely different from my car, I find that very hard to believe that you have to take the bumper off. Pulling the liner away in the wheel wells should get you access to pop the reflector out. Honestly be careful on what you read about online as people just make crap up.
Same here. Eager to see how it works out. The orange ones — another totally stupid DOT requirement that does noting, but messing up the clean lines of front (end rant).
There is no bulb in the oranger reflector. The amber side marker is an LED in the headlight assembly. Not sure if it can be disabled in OBDEleven / VAG COM.
So I just pulled back the liners in the wheel wells. Looks like you were right! Completely different then my car and it looks like I can't get to it like I did in my car. There may be a way to pop it out but I'm not sure at this point. Once I access it through the wheel well there is still plastic over it and no way to push it out. Im glad I checked it out before I ordered them.
