All-Season Replacement Tires - Sensor Issues?
Planning to replace my 285 / R45/ 20" with 285/ R50 / 20" due to much better selection of tires and brands and prices about 50% less. For the additional 1.5cm of extra tire height, has anyone done this and had problems with the low tire pressure warning light going off ? Audi service warned me this could occur (no guarantee either way) and will not shut off alarm light if it occurs due to safety reasons. Anybody out there try this different tire size and have this problem ?? THANKS!
Why would the rolling diameter of the tires set off the warning system????
But like uber said, it should be fine because the Audi compares the two tires rotation to figure out if one has less pressure. So in theory you could put Jeep tires on there as long as they match across the axel and have the same pressure, it should be fine.
Audi service claims the taller tires rotate less and this triggers the low pressure sensors. I find that hard to believe but wanted to see if any other owners had this issue when changing tire size Thanks
I suppose you could test this by lowering all of your tires to 20 lbs and seeing what happens. I’d stay on slow/private roads though. Don’t recommend high speeds.
What about wheel well clearance. Has that been evaluated?
Read that any changes to the tire aspect ratio (wheel/tire) combo has an overall diameter/circumference that should be maintained with 3% of (+/-) the original spec.
What non run flat and cheaper alternative tires can be mounted on the same OEM rim, specifically, the 285/R45/20 run flat tires?
