Audi A3 / S3 / RS 3 MKII Discussion forum for the 2015 to 2022 Audi A3, S3 and RS3 - including the upcoming E-tron and TDI models
michelin tyre pressures
Old 11-11-2017, 10:30 AM
whitby's Avatar
Default michelin tyre pressures
Just put a set of Pilot SuperSports on the S3 to replace the original Continentals that lasted almost 25k miles.
They came with a warning that they needed to be inflated to 42PSI - which makes the ride rock hard!
Don't remember having that requirement in the past.
If anyone else is running Michelins, what pressures are you running?
Old 11-12-2017, 03:57 PM
arU4ic's Avatar
I ran these at 40 front 38 rear, the entire time I drove them (10k miles).
Old 11-13-2017, 06:41 AM
Flying Scotsman's Avatar
Did you buy them from Tire Rack, as they put that warning on S3 19" tyres on their configurator. I personally run 39-40 F and 36-37 R for up to 3 people and 44 all around for a fully loaded vehicle.
Old 11-13-2017, 09:50 PM
arU4ic's Avatar
No, I bought them at a local tire shop (here in CA), didn't know about the warning.
Old 11-14-2017, 04:20 AM
Fixeroh's Avatar
Still have original Contis for my 2015 S3 but with swapping between winter and summer sets of wheels/tires, am extending the usefulness of the Contis. However, after discussing the Michelin tires with gents like arU4ic, I've decided to go with the Pilot Super Sports when I do get new summer rubber. Will have to check into that warning but that seems odd to generalize the pressure like that. I was running 39 F and 37 R on my Continentals however. Seemed to give me the best grip and comfort level overall.
Old 11-19-2017, 11:35 AM
whitby's Avatar
Default Yes, they came from Tire Rack
I guess I should probably ping Tire Rack and see what they say
Old 11-19-2017, 05:14 PM
They will state 42 PSI for vehicle..... Audi S3 2015 manual specs page 255 for tire pressures for 235/35/19 91Y are 39F and 36R for partial load ( 3 people ) and 44 fully loaded. Door specs now show for Canadian 2017 models 44 psi methinks because most of us do not check air pressures enough for load purposes and for liability issues they only show one pressure now, fully loaded.
Old 11-20-2017, 06:44 PM
gk1
gk1's Avatar
They are XL Extra Load tires right? I believe they are required by law to advise you they have to be inflated to at least 42 psi to achieve the extra load rated weight capacity. Otherwise they risk being sued by someone who uses them improperly inflated on their fully loaded Ford Explorer towing the space shuttle.
Similar to the door sticker psi being for full load as we cannot be trusted to understand full and partial load...oh well.
Old 11-21-2017, 12:09 PM
XMetal00's Avatar
My US Specs 2018 S3 also got that 44psi label on the door without any indication that it's the pressure for fully loaded
Cards
A4 (B8 Platform) Discussion
11-08-2015 10:37 AM
Cme42thdk
S7
03-15-2015 08:15 AM
fussball.biturbo
03-01-2007 05:57 AM
Minimization
14
01-23-2004 03:39 PM
RMcQ
Audi allroad
17
10-15-2003 06:11 PM
Quick Reply: michelin tyre pressures
