Audi S8 TRANSMISSION ISSUE PLEASE HELP
So I bought a 2003 audi s8. Before I bought the car I you know test drove it checked everything drove it for 2 days before buying (it was off craigslist) it. Car was running great **** I drove it to the Southside of san Jose and made my way to a smog shop and it passed smog flying colors. 15min after smog I got t a light and when the light turned green I went to go and the trans slipped and then it slipped again went into limb mode. How is this possible the car just passed smog 15 min ago. There is check engine light code p0730 and p0733. Incorrect gear ratio and incorrect gear ratio third gear. Anyway I want some advice I was just going to buy the parts to rebuild the trans or should I check and see if there is fluid in the trans. Will it still shift in gear if the trans is low on fluid? Please help anyone or suggestions. Thanx.
Could be a stuck pressure control valve or that stuck valve can cause other stuff to break. Low fluid usually has a few other symptoms, slow shifting to 4th, maybe slipping from a stop?
Did it shift rough, downshift rough, or freewheel-bang at all before it went into limp? Can you shut off and restart the car and not go into limp?
Audi help
So yeah if I turn the car off and back on it won't be in limb mode. When i go into drive it still wont be in limb mode until it slips again which it does bringing it to drive from park position.Like the car was driving great it wasent shifting rough or anything. I think flywheel bang then limb mode. Like this was 15 after it passed smog.
Most likely it had a problem before you bought it.
You just didn't get it got enough on the testdrive. Coolant gets to temp in 5-8 min. Trans fluid needs way more than that. I doubt that it is low on fluid because it would slip cold it it is low. Unfortunately you will need a rebuild. I would talk to the seller because it is very possible that it was slipping before, but maybe they only drove it on a short distance.
As Gabor suggests it was probably slipping/banging sometimes before the sale, at that point it might have been saved but once the banging breaks something or blows a seal it's rebuild time. The seller might have beaten the game of russian roulette by selling it before it broke. Too bad, it's under $250 to fix when it's only the valve sticking and it hasn't broken the drum.
ERIC B 6023
12
08-28-2007 12:30 PM
