Recommended inflation pressure?
Check the manual p.337. The SQ is only listed for the 20 and 21's. The Q is listed for the 18, 19 & 20. The overlap, at the 20 size is different for each car. And by the way, they don't even show a 255 in the 18" size - only a 235.
I believe that sticker is for recommended max pressure. Audi's manual shows different pressures for lightly loaded and fully loaded cars - almost a 10% difference between the two.
I don't have my Q7 any more otherwise I'd go and check.
Personally I've never referred to the manual for tire pressure so I can't say what info is there.
I know that I've referred to that sticker for all of my tire pressures in my cars and I'm almost sure it gives both recommended and maximum.
My door sticker has only one set of pressures. Since you are in Canada, there might be a different requirement on the door sticker
Thanks for all the replies. The sticker on the door does have a range....but not for my size tire....owner's manual also does not have my size tire listed. Internet search got me nowhere either, so I posted the question here. I bought the tire/wheel package from Tirerack.com and they were shipped with 31psi. This seems sort of in line with the manual which lists the 18" tire range at 29 - 38 depending on load and front to rear, but as others noted those pressures are for the Q5, not the S, and not for my 255/55 proportions. I will update as I find more info.
Truth be told, it really is a range. There is no magic single air pressure. And different tires even within the same categories will respond differently to the same air pressure. On my Q, the Audi recommend felt a tad squishy. The max felt hard. I split the difference, and Voila, perfecto. As an aside, I have never had a car that has such good suspension that those small changes in air translate into such different feels --- I like it, I like it!! lol
Lots of great information and feedback from all kinds of great people.
I wish you could like the posts people put on the forum. I have been on others that you can and it's a nice way of giving feedback without having to respond every time.
Thanks for the response @ronsal
