93 100 s location fuel pump relay
Old 10-17-2018, 02:28 PM
coastaleddy619's Avatar
Default 93 100 s location fuel pump relay
93 audi 100 s fuel pump relay switch location
Old 10-18-2018, 07:35 AM
Rusty Spokes's Avatar
Pretty sure the fuel pump relay is #271 under the driver's side kick panel. Be aware that the fuse for the fuel pump is located under the passenger side foot rest. It is on a plastic bridge with several other fuses and often is badly corroded..reducing the available voltage to the fuel pump. There are several fuses on that bridge that routinely should be cleaned and replaced. The ECUs for the engine and transmission are back there too..be sure the engine cowl drains are clear and no h2o is leaking down around the fuses and delicate electronics.
Da-Hunter
03-15-2008 11:31 PM
egp320i
05-28-2005 03:51 PM
seattle 93q avant
Audi 100 / A6 (C4 Platform)
03-25-2004 09:58 AM
02silverbullet
Chicago Discussion
11-14-2003 06:00 PM
GDA4
10-07-2003 09:37 AM
Quick Reply: 93 100 s location fuel pump relay
