INTRO PRICE / Group Buy: *NEW* LED Fog technology: 1 LED 4 modes: WHITE/YELLOW/STROBE
Audiworld Basic Sponsor
GROUP BUY EXTENDED!!
DO NOT MISS OUT!
-Plug and play
-Error free in most cars. Some might need extra resistance - we sell a new design that DOES NOT require you to attach it to metal. It is compact and easy to install - simply plug into OEM adapter and our LEDs (100% plug and play NO splicing design)
-Easy to switch between each color – simply turn OEM fog switch off/on - normal cycle: White - yellow - halogen - flash/strobe
-BRIGHT – this is not just a novelty bulb
-COLOR MATCH - these match our LEDs/HIDs in 5500K White mode
-HYPER YELLOW - these are a true hyper yellow mode you normally see with yellow lamin-x covering the lens **this is NOT a cover around a bulb or a cover on your lens - this is brand new LEDs that are a super hyper 3K yellow**
-SAFE – more light on the sides and down the road when dark or in bad weather conditions
****INTRO PRICE****$110 includes FREE UPGRADED SHIPPING (RETAIL $144.99) Simply email Support@deAutoLED.com for an invoice
This has 3 different colors and 4 different strobe/flash modes:
-The Hyper Strobe / Flash – this does not simply "flash" but has a strobe/flash pattern like an emergency vehicle - you can choose between 4 different modes - video of mode 1:
https://www.youtube.com/watch?v=T-fex4DUPSg
3 colors:
-Super Hyper 3000K Yellow that many like for bad weather: Rain, snow, fog
-Clean White 5500k that matches our LED & HID Headlights
-Halogen 4300k that matches OEM
Video cycling quickly through colors AND different strobe/flash features:
https://www.youtube.com/watch?v=bQG0gRKGFk0
INFO:
****Do not miss out these are going fast**** This Into Price ENDS IN approximately 2 weeks!
-Also including 20% off anything else you purchase – only valid when you purchase fogs
-They have a ship date of December 17th-19th with FREE upgraded priority mail shipping within the US only. These will most likely arrive before Christmas but currently no guarantee (sub to this thread for updates)
-THESE ARE BRIGHT! You might have seen the novelty fog LEDs that can turn yellow/white on amazon and ebay by the thousand that don't provide much useful light, trigger errors, die quickly, or simply don't work correctly. Our new model fixes every issue you might've seen and simply works.
-These produce MORE LUMENS than many standalone single color white fog LEDs on the market
-Not only are these great for safety, daily use on dark roads and bad weather this will amaze at any car show and you will have your friend asking how did you do that and where can I get those anytime you use these fogs!
*Please note these ARE error free but in strobe/flash mode they can trigger an error in some car models – errors WILL clear once you go back to a solid color.
Attachment 104952
Attachment 104953
UPDATED FAQ
Is there a lifetime warranty?
YES! As always this comes with a True Lifetime Warranty!
Will your fogs keep changing colors if you use them as cornering lights?
The answer is no as this only changes by turning your fog switch on/off. If you are using your fogs as cornering lights it will always be the default color of white.
How does this work with the coming home feature?
This works just like OEM. It will always be the default color of white.
What if I have the yellow feature on and turn off my car; will it then go into the next color when I turn it back on?
The LEDs will always revert back to the default color of white. Then simply turn the fog on/off for your desired color: yellow/halogen or strobe/flash mode.
Can these turn 360 degrees?
Yes, these are a fully adjustable design so you can turn these 360 for the best beam angle.
Are these as bright as your single color de360 fogs?
While not as bright lumen wise it comes very close - many people that have switched to our single color white to our dual color yellow/white LED fog kit have not noticed any difference in visibility. As we said this is NOT a novelty yellow/white you normally see. This is meant to be used to help with your visibility.
Can you bypass the strobe feature?
Yes, this works when you turn the fogs on/off quickly. If your next mode will be strobe simply shut off the fogs for a few seconds and then turn it back on and it will go back to the default white.
Some more fun shots - in the rain:
Attachment 104954
White / the super hyper yellow - this will be a hyper lamin-x yellow without the cover!
Attachment 104955
Attachment 104956
And switch back to clean white:
Attachment 104957
DO NOT MISS OUT!
-Plug and play
3 colors:
INFO:
Attachment 104952
Attachment 104953
UPDATED FAQ
Attachment 104954
Attachment 104955
Attachment 104956
Attachment 104957
w:http://deAutoKey.com
-Error Free LEDs for your Audi (interior & exterior)
f: https://www.facebook.com/deAutoKey
i: http://instagram.com/deAutoLED
NEW VIDEO DEMO:
Timestamps are in video descriptions.
LAST WEEKEND!
Thank you
Thank you
It only works if your car has the halogen option.
Thanks
Thanks
Our group buy is extended!
Simply email Support@deAutoLED.com to get in the group buy!
Attachment 105074
Attachment 105074
THE SALE CONTINUES.
Simply fill out questions below and email it to Support@deAutoLED.com:
1) what is the bulb type of your halogen
2) what year/make is your car
3) is this shipping within the US
4) do you want anything else (reverse/turns/interior etc.) at 20% off
5) you might need an outside resistor - we sell it for an additional $15 but can try without resistors first
6) we also have a non-strobe flash if you are interested in this model
Both strobe & non-strobe model utilize the same bright diodes and are the same price.
Thank you
Thank you
Still up and running for anyone still interested please email:
support@deAutoLED.com
