Audi Pre sense Prestige vs Premium plus
I am a little confused with Pre Sense. We have a 2018 Q5 and 2018 A4 both in premium plus trim. Is the Pre Sense in either a watered down version or is it the same as in the Prestige model. Looking at the manual it says Pre Sense uses sensors as well as cameras to activate system. Since we dont have active Cruise control we dont have cameras correct? Will a premium plus come to a complete stop to prevent a rear end collision?
You can have cameras regardless of active cruise. The Active Cruise uses radar for vehicle detection. Back is in the trunk, front is top windshield behind the mirror.
I believe pre-sense uses cameras + parking distance. There was a thread that one of the members posted what tech was needed for each of the Audi functionalities. It came from the Audi Portal if you google it.
Audi pre sense helps monitor the areas around the vehicle with a sophisticated front-facing cameraand rear-facing radar or ultrasonic sensors
- Pre sense city - Using forward-facing camera and radar systems
- Pre sense rear - Uses radar sensors in the rear bumper
- Pre sense front - Uses data from a suite of sensors and cameras
Thanks Spindlewood! Memory was slipping me last night.
I wonder how pre-sense works for the OP then if they don't have adaptive cruise (unless the radars are installed regardless). Perhaps he can even enable active cruise through OBDEleven then?
I had actually done some research on this because all these terms were so confusing:
- Pre sense city - Uses the front-facing camera. Standard on all trims. Pedestrian warning 6-50 mph. Vehicle warning 6-155 mph. Auto brake < 50 mph only
- Pre sense front - Uses the front-facing camera and ACC radar. Only available on 2018 Prestige w/ Driver Assistance Package and 2019 Prestige (ACC is standard on 2019 Prestige). It provides full speed range warning and auto brake. It also includes Evasive Steering Support (adjusts steering to help steer around an obstacle 20-90 mph) and Turn Assist (stops turning to avoid an oncoming vehicle < 6 mph)
- Pre sense rear - Uses the side assist sensors. Not available on Premium. Standard on P+ and Prestige. Detects the possibility of being rear ended and tightens up the seat belts, closes windows/sunroof and turns on the emergency flashers when necessary
- Pre sense basic - Standard on all trims. It's not a detection system. It merely takes input from the above systems and tightens up the seat belts, closes windows/sunroof and turns on the emergency flashers when necessary
- Rear cross-traffic assist - Uses the side assist sensors. Not available on Premium. Standard on P+ and Prestige. Warning and auto brake in reverse <9 mph
jfk-usaf (01-02-2022)
- Pre sense city - Use the front-facing camera. Standard on all trims. Pedestrian warning 6-50 mph. Vehicle warning 6-155 mph. Auto brake < 50 mph only
- Pre sense front - Use the front-facing camera and ACC radar. Only available on 2018 Prestige w/ Driver Assistant Package or 2019 Prestige (ACC is standard on 2019 Prestige). It provides full speed range warning and auto brake. It also includes Evasive Steering Support (adjust steering to help steer around an obstacle 20-90 mph) and Turn Assist (stop turning to avoid an oncoming vehicle < 6 mph)
- Pre sense rear - Use the side assist sensors. Not available on Premium. Standard on P+ and Prestige. Detects the possibility of being rear ended and tighten up the seat belts, close windows/sunroof and turn on the emergency flashers when necessary
- Pre sense basic - Standard on all trims. It's not a detection system. It merely takes input from the above systems and tighten up the seat belts, close windows/sunroof and turn on the emergency flashers when necessary
- Rear cross-traffic assist - Use the side assist sensors. Not available on Premium. Standard on P+ and Prestige. Warning and auto brake in reverse <9 mph
This is the only mention of an active "evasive" action in the document. It seems to only adjusts torque to make it easier to maneuner.
Collision avoidance assist
Collision avoidance assist helps the driver steer around an obstacle in a critical situation. The system uses data from the two radar sensors and the front camera for this purpose. In calculating a suitable evasive maneuver corridor, it takes into account the distance, width and offset of the vehicle driving ahead. Collision avoidance assist is available over a speed range from approx. 30 to 150 km/h (18.6 to 93.2 mph), and it assumes that the driver is actively steering throughout the maneuver. The driver is informed of the intervention by an indicator in the instrument cluster.
First, a jolt is produced to warn the driver of the hazard. If the driver then actively avoids the obstacle, the assistant applies a slight steering torque that helps by correcting the driver’s steering input or helping to make a lane change. Models like the Audi A8 (2017) use a specific braking of individual wheels – with it the vehicle is made to follow the computed course.
Thanks for the write-up. I haven't seen Evasive Steering included with Pre-Sense Front anywhere. For example, this Audi Media Center page has it as something distinct. That said, I haven't seen anywhere that the Q5 and SQ5 at any trim level has this feature. Can you provide a link that supports this?
Of all the places to find it... lol. Thanks. While I like the Audi Media Center, finding which technologies are in my car is not so straight forward. Even the manual has many features with asterisks that are not in all markets or trims. Confusing. Why the Audi Media Center doesn't match the manual is another head scratcher. With tech changing all the time, there should be a grid of some sort that matches to years and trims. [/END RANT]
