Audi TT Idles Super Hard HELP!!
Old 06-08-2019, 05:37 PM
zmatania's Avatar
Default Audi TT Idles Super Hard HELP!!
Hello, when I step on my gas pedal in my TT it was backfiring and losing power. So I decided to replace the spark plugs and the coil packs. After removing then there was some yellow residue on one of the coil packs and the spark plug. After replacing them all I started the car and instead of the idle being at 1000-1100 like normal it is at about 400-500. It shakes crazy hard and sometimes dies. I have no clue what to do and have done everything I can think of. No vaccum leaks, fuel injectors are clean, everything is plugged in. I also do not have any codes on the car but the misfire count is mostly in cylinder 1 and 2. Please help.
Old 06-09-2019, 12:37 PM
Mister Bally's Avatar
Are you certain that your turbo/intercooler lines are intact? All connections solid and no tears in the "rubber" Your problem sound as if this is the case.
Old 06-09-2019, 12:51 PM
zmatania's Avatar
I have check every hose I can possibly see.
Old 06-18-2019, 11:43 AM
Handmedown's Avatar
Default Do you have s scanner?
Look for stored codes. There has to be a spark or fuel issue for the tool to pick up. If you kept your old coils swap one in one cylinder at a time.
wilco.k
TT (Mk1) Discussion
12-01-2021 05:16 PM
Popwar867
TT (Mk1) Discussion
10-29-2017 09:52 AM
iMMix
TT (Mk1) Discussion
07-24-2007 06:37 AM
DoubleDose
05-09-2007 03:54 PM
Pekboy
03-09-2004 09:02 AM
Quick Reply: Audi TT Idles Super Hard HELP!!
