Airbag clock spring replacement
Good evening!
Currently own a Audi A4 B8 (2008) and the clock spring has started to make noise. Got a new clock spring on order and planning to replace it incoming week. However, I am finding very conflicting information online whether the new clock spring will need to be coded, and/or whether any and all calibrations can be done with simple "DIY" tricks such as holding the steering wheel at a certain angle. The new clock spring is not OEM but I have read up on the basics about having the steering wheel centered as to install the new clock spring in it's zero position. If it does need to be coded, can this be done afterwards or is the exact coding from the original spring required?
Thanks!
Thanks!
The J527 will need to be programmed with the correct coding for your vehicle. The long coding string is only three bytes. But you need to know what it is on your old one so you can make sure the new one is set to the same. As for CP, I do not believe that module is involved in the CP system, so shouldn't need anything done in that regard. You're going to have to do the steering angle adaptation end stops regardless. But I think you just turn the wheel full left, wait for beep, full right, wait for beep, done.
Why would you pay a dealership an hour labor to do something you can do yourself with a tool you can buy and keep for the same price as that hour labor? I don't think blind swapping the J527 and not doing anything to it will prevent you from driving to the dealership.
As true as that might be, I am wildly unfamiliar with what programming/coding the J527 entails. Unbolting and bolting on new parts is easy enough (usually, at least) but that is obviously another thing entirely.
Update: Replaced the clock spring last night. Moved over the steering angle sensor and just replaced the actual clock-spring, and as such, had to do nothing special. Basically plug-and-play, given the correct tools. However, it seems the squeaking and snapping sound at certain points when turning the steering wheel left haven't changed one bit, so will have to break it open tonight as well, see if I have missed anything or if the replacement part is defective.
I did find that the steering wheel is rubbing on something a lot more at a certain height but whether that is related to the primary issue or not is difficult for me to say.
Considering removing the clock spring entirely, leaving the steering angle sensor in place, and slapping on the steering wheel, as to check whether the sound is STILL there or disappears. Would that mean any trouble other than a few error codes once the battery is hooked up?
