VCDS - Battery "Not OK"
VCDS - Battery "Not OK" Measuring Block Group 17 , What could this possibly mean?, this battery is brand new! H9 AGM DieHard Battery
I tried to reprogram the battery using VCDS by changing the serial number by 1 digit but I'm not sure if its coded correctly how would i be able to check?
I have a 2009 A5 Quattro 3.2 L V6 B8 Automatic transmission.
What are the actual error codes for 19-gateway (fault codes - 02) ? If there's no error codes, that looks very odd. Never seen that. What is the p/n in the adaptation channel 004? You have VCDS, so go to applications and then history data, pull the history data for 19 into a CSV and post that text.
AzJazz
A4 (B9 Platform) Discussion
11
07-15-2023 12:35 AM
brettfletcher79
Q7 MK 1 Discussion
09-15-2021 08:00 AM
