B8 airbag fault
B8 airbag fault
Hello, yesterday i was casually driving and parking brake and airbag fault popped. It shows that there is no comminication with block. Fuse ar fine, is there any other things to look for? My seatbelt beep is not working aswell, now i can drive without it😅
You have VCDS, just post the complete text of the full autoscan log. That screen cap doesn't say what control module that error is from, etc.
Tuesday,30,April,2024,11:37:11:62939
Chassis Type: 8K (8T0)
Scan: 01 03 05 07 08 09 0E 10 14 15 16 17 19 37 3C 42 46 47 52 53
55 56 62 6D 72 77
VIN: WAUZZZ8K09A004299 Mileage: 380060km/236158miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
0E-Media Player 1 -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
14-Susp. Elect. -- Status: OK 0000
15-Airbags -- Status: Cannot be reached 1100
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
37-Navigation -- Status: OK 0000
3C-Lane Change -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (J623-CAPA) Labels: 059-907-401-CAP.clb
Part No SW: 8K0 907 401 F HW: 8K0 907 401
Component: 3.0TDI EDC17 H01 0004
Revision: --H01---
Coding: 010C002C180F0118
Shop #: WSC 29203 141 83105
ASAM Dataset: EV_ECM30LTDIA5 A02004
ROD: EV_ECM30LTDIA5.rod
VCID: 2E53E83371E29E6E36F-807B
3 Faults Found:
7900 - Right Engine Mount Solenoid Valve (N145)
P1577 00 [044] - Open Circuit
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 3
Mileage: 380067 km
Date: 2024.04.30
Time: 10:21:41
5390 - Left Engine Mount Solenoid Valve (N144)
P1573 00 [044] - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 254
Mileage: 380067 km
Date: 2024.04.30
Time: 10:21:41
4710 - No Communications with Airbag Control Module
U0151 00 [047] - -
Freeze Frame:
Fault Priority: 6
Mileage: 380067 km
Date: 2024.04.30
Time: 10:12:47
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (J104) Labels: 8K0-907-379.clb
Part No SW: 8K0 907 379 S HW: 8K0 907 379 S
Component: ESP8 quattro H04 0210
Revision: -------- Serial number: --------------
Coding: 1B0D00
Shop #: WSC 06335 000 00000
VCID: 4999BBAFE04CD95603D-801C
1 Fault Found:
00473 - Control Module for Elect. Park/Hand Brake (J540)
013 - Check DTC Memory
Freeze Frame:
Fault Status: 01101101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 88
Mileage: 380067 km
Time Indication: 0
Date: 2024.04.30
Time: 10:21:38
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x07A0
Hex Value: 0x0016
Hex Value: 0x0288
Hex Value: 0x00FF
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 8K0 907 064 AE HW: 8K0 907 064 AE
Component: BCM2 1.1 H71 0134
Revision: 00002001
Coding: 030200
VCID: 73E53947D240F386991-8026
Subsystem 1 - Part No SW: 8T0 959 754 K HW: 8T0 959 754 K
Component: FBSAUDIB8 IDG H61 0072
Subsystem 2 - Part No SW: 8K0 905 852 C HW: 8K0 905 852 C
Component: ELVAUDIB8 H35 0039
No fault code found.
Address 07: Control Head Labels: 8T0-035-7xx-07-H.clb
Part No SW: 8T0 035 729 T HW: 4E0 035 729
Component: Interfacebox H43 5570
Revision: 00000000 Serial number: 329C$087551987
Coding: 0041003
Shop #: WSC 00000 000 08192
VCID: 4A9B84A3254AD24E0A7-801F
Subsystem 1 - Part No: 8T0 919 609
Component: E0380 BedienteilH08 0100
Subsystem 2 - Serial number: 00000000061513
Subsystem 3 - Serial number: 0121.03.080000000100010341˙
Subsystem 4 - Serial number: 010341˙
Address 08: Auto HVAC (J255) Labels: Redir Fail!
Part No SW: 8T1 820 043 R HW: 8T1 820 043 R
Component: KLIMA 3 ZONEN H05 0120
Revision: C1000000 Serial number: 0112.03.080997
Coding: 36000000
VCID: 408FA68BD376181ED43-8015
1 Fault Found:
01321 - Control Module for Airbags (J234)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 6
Fault Frequency: 1
Reset counter: 88
Mileage: 380067 km
Time Indication: 0
Date: 2024.04.30
Time: 10:12:47
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 D HW: 8K0 907 063 D
Component: BCM1 1.0 H21 0253
Revision: 05021001 Serial number: 00000000016697
Coding: 260050914034AF210E01000300001D0D4F9C87480001014100 0000
Shop #: WSC 06335 123 12345
VCID: 306FF64B63D6889E243-8065
Subsystem 1 - Part No SW: 8K1 955 119 HW: 8T1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 270308 H06 0060
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Coding: 025028
Subsystem 3 - Part No SW: 8K0 941 531 G HW: 8K0 941 531 G
Component: E1 - LDS H07 0070
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 88
Mileage: 380067 km
Time Indication: 0
Date: 2024.04.30
Time: 10:12:00
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 8T1 035 110 C HW: 8T1 035 110 C
Component: MP3-Changer H41 0390
Revision: 00041001 Serial number: AUZ5ZBH8359855
Shop #: WSC 00000 000 00000
VCID: 2A5BE423850AF24EEA7-807F
Address 10: Park/Steer Assist (J446) Labels: 8K0-919-475.clb
Part No SW: 8K0 919 475 B HW: 8K0 919 475
Component: PARKHILFE 4K H06 0010
Revision: 11001001 Serial number: 75330808906597
Coding: 100003
Shop #: WSC 06325 123 12345
VCID: 387FCE6B8BA650DE6C3-806D
Address 14: Susp. Elect. (J250) Labels: None
Part No SW: 8K0 907 364 HW: 8K0 907 364
Component: DAEMPFUNGS-SG H08 0052
Revision: 00000000 Serial number: 27020801450002
Coding: 010181
VCID: F0EFB64B2356489EE43-80A5
Address 15: Airbags
Cannot be reached
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Part No SW: 8K0 953 568 F HW: 8K0 953 568 F
Component: Lenks.Modul H11 0012
Revision: -------- Serial number: 90304HCL0006J
Coding: 000017
VCID: 3D71DF7FA48475F6BF5-8068
Component: E221 - MFL H02 0003
Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
Part No SW: 8K0 920 930 C HW: 8K0 920 930 C
Component: KOMBIINSTR. H15 0221
Revision: 00000000 Serial number: 7BX2A6W38
Coding: 0F05110013000008000000
VCID: 2D51EF3F74E4E5760F5-8078
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 88
Mileage: 380067 km
Time Indication: 0
Date: 2024.04.30
Time: 10:12:48
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8T0 907 468 L HW: 8T0 907 468 L
Component: GW-BEM 5CAN-M H10 0092
Revision: FB402044 Serial number: 4400F08324801E
Coding: 000303
VCID: 4A9B84A3E54AD24E0A7-801F
Subsystem 1 - Part No SW: 8K0 915 181 B HW: 8K0 915 181 B
Component: J367-BDM H03 0150
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 88
Mileage: 380067 km
Time Indication: 0
Date: 2024.04.30
Time: 10:12:48
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 E HW: 4E0 919 887 M
Component: MNS ECE H51 1050
Revision: 00000000 Serial number: 333CL087552811
Shop #: WSC 50954 141 89497
VCID: 306FF64BA3D6889E243-8065
Address 3C: Lane Change Labels: None
Part No SW: 8K0 907 566 B HW: 4L0 907 566 B
Component: J0769_SWA_MasterH01 0070
Revision: 00H01000 Serial number: 6PZ 009 014-12
Coding: 0000102
Shop #: WSC 74853 143 177181
VCID: 3663C05341B2A6AE7EF-8063
Subsystem 1 - Part No: 8K0 907 568 B
Component: J0770_SWA_Slave_H01 0070
Subsystem 2 - Serial number: 6PZ 009 014-32
Subsystem 3 - Serial number: 5F03.04.0800H010003C710001˙
Subsystem 4 - Serial number: 710001˙
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8K0 959 793 B HW: 8K0 959 793
Component: TSG FA H10 0170
Revision: Serial number: 0000006951411
Coding: 011C02204100410001
VCID: 3F8DA577AE8867E6AD9-806A
1 Fault Found:
02115 - Locking Unit for Central Locking
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 88
Mileage: 380068 km
Time Indication: 0
Date: 2024.04.30
Time: 10:32:29
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0110539382
Coding: 0100062020393454012002
Subsystem 1 - Part No SW: 8K0 959 591 A HW: 8K0 959 591
Component: J245 PS133 H06 0041
Subsystem 2 - Part No SW: 8K0 959 591 HW: 8K0 959 591
Component: J394 PS220 H06 0036
3 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 88
Mileage: 380067 km
Time Indication: 0
Date: 2024.04.30
Time: 10:12:47
02615 - Fuel Tank Cap; Lock
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 88
Mileage: 380068 km
Time Indication: 0
Date: 2024.04.30
Time: 10:32:29
02616 - Fuel Tank Cap; Unlock
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 88
Mileage: 380068 km
Time Indication: 0
Date: 2024.04.30
Time: 10:33:24
Address 47: Sound System (J525) Labels: 8T0-035-223-BOM.clb
Part No SW: 8T0 035 223 T HW: 8T0 035 223 F
Component: DSP Prem H14 0400
Revision: 00H14003 Serial number: 34814000878500
Coding: 020101
Shop #: WSC 12336 024 394758
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8K0 959 792 B HW: 8K0 959 792
Component: TSG BF H10 0170
Revision: Serial number: 0000006961158
VCID: 3E73D873A9826EEEA6F-806B
Address 53: Parking Brake
Cannot be reached
Address 55: Xenon Range Labels: 8K0-907-357.clb
Part No: 8K0 907 357 B
Component: Dynamische LWR H01 0010
Revision: 00000001 Serial number:
Coding: 0000005
Shop #: WSC 06334 000 00000
VCID: 3467FA5B57CEB4BE40B-8061
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 T HW: 4F0 035 541 L
Component: TUNER EU/US/RDW H42 0630
Revision: 00000000 Serial number: 336CT087546813
Coding: 0000001
VCID: 3169F34FA8DC81962BD-8064
Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb
Part No SW: 8K0 959 795 HW: 8K0 959 795
Component: TSG HL H06 0170
Revision: Serial number: 0000006954444
Coding: 010C02204000210001
VCID: FF0D65776E0827E66D9-80AA
Address 6D: Trunk Elect. (J605) Labels: Redir Fail!
Part No SW: 8K9 827 851 HW: 8K9 827 851
Component: J605 Master H24 0220
Revision: -------- Serial number: 8K9827851
VCID: FBF591677A103BC6411-80AE
Subsystem 1 - Part No SW: 8K9 827 852 HW: 8K9 827 852
Component: J756 Slave H24 0220
Address 72: Door, Rear Right
Cannot be reached
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4E0 910 336 M HW: 4E0 862 335
Component: Handyvorb2 H16 1130
Revision: 00000000 Serial number: 00000007590278
Coding: 0010910
VCID: 2C57E23B8FFEEC7E18B-8079
End ---------------------------------------------------------------------
My parking brake works fine too.
55 56 62 6D 72 77
Revision: --H01---
3 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Mileage: 380067 km
Date: 2024.04.30
Time: 10:21:41
Freeze Frame:
Fault Priority: 2
Mileage: 380067 km
Date: 2024.04.30
Time: 10:21:41
U0151 00 [047] - -
Freeze Frame:
Fault Priority: 6
Mileage: 380067 km
Date: 2024.04.30
Time: 10:12:47
Coding: 1B0D00
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 88
Mileage: 380067 km
Time Indication: 0
Date: 2024.04.30
Time: 10:21:38
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x07A0
Hex Value: 0x0016
Hex Value: 0x0288
Hex Value: 0x00FF
Revision: 00002001
Coding: 030200
Coding: 0041003
Coding: 36000000
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 88
Mileage: 380067 km
Time Indication: 0
Date: 2024.04.30
Time: 10:12:47
Coding: 00FD11
Coding: 025028
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 88
Mileage: 380067 km
Time Indication: 0
Date: 2024.04.30
Time: 10:12:00
Coding: 100003
Coding: 010181
Address 15: Airbags
Cannot be reached
Coding: 000017
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 88
Mileage: 380067 km
Time Indication: 0
Date: 2024.04.30
Time: 10:12:48
Coding: 000303
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 88
Mileage: 380067 km
Time Indication: 0
Date: 2024.04.30
Time: 10:12:48
Coding: 0000102
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 88
Mileage: 380068 km
Time Indication: 0
Date: 2024.04.30
Time: 10:32:29
3 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 88
Mileage: 380067 km
Time Indication: 0
Date: 2024.04.30
Time: 10:12:47
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 88
Mileage: 380068 km
Time Indication: 0
Date: 2024.04.30
Time: 10:32:29
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 88
Mileage: 380068 km
Time Indication: 0
Date: 2024.04.30
Time: 10:33:24
Coding: 020101
Cannot be reached
Coding: 0000005
Coding: 0000001
Cannot be reached
Coding: 0010910
That's a very odd scan log. You have MMI 2G, but you don't have the AMI device in the glove box (1E)? And no backup camera (6C)? And no direct TPMS (65), maybe it wasn't required in that country?.
The summary list at the start of the scan log is the list of control modules the J533 gateway says exists, and the status as reported by the J533. Notice the J533 says 72 is OK, but then VCDS cannot access it later in the scan when it tries to.
But we'll start with the one that both the J533 and VCDS say they cannot reach, the airbag control module. Which is under the center console. I know there was a recall for that module in my MY09 here in the US. They replaced it many years ago. Could be yours died if it was still original. The J234 airbag control module has a 100-pin plug on it. Pin 76 (black/white) is the 12v power supply. In your MY09, that should be fuse 12 in column D in the right rear. So check that fuse. The control module grounds through its housing the car chassis. The CAN bus lines are 99 high and 100 low. So if you have 12v on 76 and you see voltage activity on 99 (CAN high should be between 2.5v and 3.5v) and 100 (CAN low should be between 2.5v and 1.5v, the opposite of CAN high) https://copperhilltech.com/blog/can-...9-bus-voltage/, best guess is the module itself is out to lunch. The CAN bus the J234 is on is the powertrain one, with the ECM.
LucyAnderson
A4 (B7 Platform) Discussion
04-02-2023 12:40 PM
Noob_A4_Life
10
09-04-2007 07:48 AM
meem
TT (Mk1) Discussion
08-15-2006 12:26 PM
