Audi A8 D3 3.0TDI ASB cylinder head removal
I have a 2007 A8 D3 3.0TDI ASB 233hp.
I dropped something inside the injector port on cylinder 2 while doing injector seals. Can't fish it out or look for it with a borescope so I'm thinking of pulling the head out to remove it.
As per the repair manual I need to set the engine at TDC and lock the timing but since there is a foreign object in the cylinder, I can't rotate the crankshaft to TDC as to not cause damage to the valves or head.
My question is, can I remove the head without locking the timing and then redo the timing during the head installation? Do I need to set the timing on bank 2 while installing the head on bank 1?
On the bright side, perhaps it's an opportunity to renew all the gaskets and seals and to inspect things since it was never done.
Any insights will be helpful!
P.S. I know I'm dumb.. just looking for advice.
Thanks
Moving to cylinder 2 I didn't check the tolerances (big mistake) and went straight to plugging the bore but for some reason the plug fell straight through (did it with the same plug I used on cylinder 1). I did try to fish it out with a magnet through the injector bore but that didn't work. Also tried with a borescope to see where exactly the plug is stuck but that didn't work as well. I'm not sure where exactly its stuck inside. If it's on top of the cylinder, I should've managed to fish it out with the magnet.
I might remove the spark plug and try to lower the cylinder then blow some compressed air inside and try to fish it out again rather than jumping to removing the head (maybe as a last resort) like dvs_dave and Sci-fi_Wasabi mentioned.
In the end I removed the glow plug and with a magnet I lifted the metal plug up, so it lined up with the injector hole and with a second magnet I fished it out through the injector hole.
The metal plugs in the kit I bought have a ridge that is supposed to seal the injector hole and that is what is holding the metal plug.
It turned out that the ridge on the plug was malformed out of the box and it wasn't sealing right so that's why it fell through.
I examined the rest of the plugs in the kit and only 1 (the first one I used for cylinder 1) was not defective.
