2011 q5 Water leak right rear fuse compartment
Thanks for any assistance.
Some folks would use a cheap fog machine instead, but that may leave some residue.
The other good trick (commonly used in boatyards) is to take a leafblower, or the exhaust frkm a shopvac, and duct tape it through a corrugated cardboard. Duct tape that into a window and let it run.
You are pressurizing the car. Air will leak out through the cabin vents--but also from the source of the leak. So...you keep tossing soapy water by the roof drains, the tail light weatherstrip...whatever is leaking will actually blow soap bubbles. Yes, that really works!
There is also a drain tube in the gas filler panel, hidden just below the gas cap. I used weed-wacker "string" to route mine out. It floods from rain, it clogs easily, and if someone tried a stiff wire to unclog it? That could tear it and pour water into that "fuse" bay.
