Electrical issue / module issue help
Hello,
I have a 2016 Audi rs6. I hadn’t drove it for around 4 weeks, then I drove it for 15 minutes faultless until all of a sudden I had multiple warnings on the dash then the dash went completely black but the engine still runs. I have no hvac, no wipers no indicators no clocks but will still start up.
Anyway I did a scan with vcds and i can’t communicate to multiple modules.
I charged the battery just in case it was that also I have checked fuses which all seem to be ok.
here are the faults 9803 - No Communications with Parking Assist Control Module A
U0159 00 [00100111] - -
Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Date: 2000.00.00
Time: 00:00:00
Engine speed: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 78 °C
Intake air temperature: 37 °C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 11.944 V
Unlearning counter according OBD: 40
CAN status - engine control module-Bits 0-7: O
CAN status - transmission control module-Bits 0-7: 0
CAN status - brake control module 1-Bits 0-7: 0
CAN status - brake control module 2-Bits 0-7: 0
selected gear-Bits 0-7: 0
Cruise control switch actuation-Bits 0-7: 0
4708 - No Communications with HVAC Control Module (J301)
U0164 00 [00100111] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Date: 2000.00.00
Time: 00:00:00
CAN status - engine control module-Bits 0-7: 0
4714 - Steering Column Control Module
U0212 00 [00100111] - No Communications Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Date: 2000.00.00
Time: 00:00:00
4715 - No Communication with Instrument Cluster
U0155 00 [00100111] - -
[New feature! Extended UDS fault detail is only supported by
current gen. interfaces]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Date: 2000.00.00
Time: 00:00:00
Voltage terminal 30: 11.968 V
