Multiple issues
Old May 21, 2025 | 11:19 AM
kwame12's Avatar
Default Multiple issues
I drove through rain and i got a system fault: steering. You can continue driving. I got home parked the car and the error cleared. The next day, I moved the car and I got the steering defective do not drive. I scanned the car and got this errors:
The car starts fine but unable to drive it. Any help will be appreciated.
Sunday,18,May,2025,14:28:51:08924
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 25.3.1.1 HEX-V2 CB: 0.4671.4
Data version: 20250415 DS365.0
www.Ross-Tech.com
Chassis Type: FC-AU57 (4G8)
Scan: 01 02 03 05 08 09 15 16 17 19 36 3B 42 44 46 52 53 5F 62 6C
72 8F 90 47
VIN: WAUC8AFCXHN041969 Mileage: 158368km-98405miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: Cannot be reached 0100
05-Acc/Start Auth. -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: Malfunction 0010
3B-Sensor Elect. -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 0110
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: Malfunction 0010
5F-Information Electr. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
6C-Back-up Cam. -- Status: Malfunction 0010
72-Door, Rear Right -- Status: OK 0000
8F-Pretens. Frt Left -- Status: Malfunction 0010
90-Pretens. Frt Right -- Status: Malfunction 0010
Address 01: Engine (J623-CYNB) Labels:. 06L-907-115-V1.clb
Part No SW: 4G5 907 115 C HW: 8T2 907 115
Component: 2.0l R4 TFSI H13 0001
Revision: --H13--- CVN: 09EA4145
Coding: 0A2500322424010E2002
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ECM20TFS0204G5907115C 001001
ROD: EV_ECM20TFS0204G5907115C.rod
VCID: 2A0D0E97CC7D049AF1E-807E
VINID: 9D1953211593A1878010124624F62DDA43
6 Faults Found:
20662 - Oxygen (Lambda) Sensor B1 S1
P0131 00 [00101000] - Signal too Low
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 158368 km
Date: 2025.05.18
Time: 11:46:43
Engine speed: 1442.75 /min
Normed load value: 9.4 %
Vehicle speed: 0 km/h
Coolant temperature: 72 ∞C
Intake air temperature: 49 ∞C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 11.933 V
Unlearning counter according OBD: 40
Engine: operating status: IS
ECU_STATE: SYN_ENG_IGK_ON
T_ES: 3 min
T_AST_SAE: 0 s
TTIP_MES_LS_UP[1]: -2048.0000 ∞C
TEG_DYN_LS_UP[1]: 117.2250 ∞C
Lambda probes actual: bank1: 1.2002
17178 - Databus
U1123 00 [00101111] - Received Error Message
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 158368 km
Date: 2025.05.18
Time: 11:07:05
Engine speed: 773.25 /min
Normed load value: 16.1 %
Coolant temperature: 74 ∞C
Intake air temperature: 37 ∞C
Voltage terminal 30: 13.066 V
Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration: No
Drivetrain coordinator: ACC fault status-ACC active: although TSK passive: No
Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set: No
Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously: No
Drivetrain coordinator: ACC fault status-ACC active: although limiter active: No
Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking: No
Drivetrain coordinator: ACC fault status-ACC sends undefined signals: No
Drivetrain coordinator: ACC fault status-ACC active although main switch off: No
Drivetrain coordinator: ACC fault status-ACC is active despite driver braking: No
Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling: No
Drivetrain coordinator: brake fault status-Deceleration sensor not available: No
Drivetrain coordinator: brake fault status-Deceleration sensor malfunction: No
Drivetrain coordinator: brake fault status-ESP system error: No
Drivetrain coordinator: brake fault status-ESP system malfunction due to inaccurate engine torque: No
Drivetrain coordinator: brake fault status-ESP indicates TSK message consistency error: No
Drivetrain coordinator: brake fault status-TSK/ESP handshake error: No
Drivetrain coordinator: brake fault status-ESP automatic engagement malfunction: No
Drivetrain coordinator: brake fault status-Brake light implausible: No
17186 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 158368 km
Date: 2025.05.18
Time: 11:46:43
Engine speed: 1453.75 /min
Voltage terminal 30: 11.914 V
ACC variants (coding): CCS
CCS Switch: CCS operating unit
Cruise control switch actuation-Main switch: Not operated
Cruise control switch actuation-Set: Not operated
Cruise control switch actuation-Resume: Not operated
Cruise control switch actuation-Status: OK
Cruise control switch actuation-Accelerate: Not operated
Cruise control switch actuation-DELAY: Not operated
Cruise control switch actuation-Cancel: Not operated
Cruise control switch actuation-Main switch hardware: Not operated
Cruise control switch actuation-Coding: plausible
Cruise control switch actuation-Limit function: not selected
Cruise control switch actuation-Limit button: Not operated
Cruise control switch actuation-Main switch CAN: Not operated
Cruise control switch actuation-Large increment: Not operated
Cruise control switch actuation-Control component verified: Yes
ACC variants: ACC
22055 - No Communications with Power Steering Control Module
U0131 00 [00101111] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 15
Mileage: 158368 km
Date: 2025.05.18
Time: 11:07:05
Engine speed: 774.25 /min
Normed load value: 14.9 %
Engine oil temperature: 31.0 ∞C
Time since engine start: 70.4 s
T_ES: 0 min
T_AST_SAE: 0 s
22059 - No Communications with Steering Angle Sender (G85)
U0126 00 [00101111] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 158368 km
Date: 2025.05.18
Time: 11:07:05
T_ES: 0 min
T_AST_SAE: 0 s
23128 - Implausible Data Received from ABS Control Module
U0415 00 [00100000] - -
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 158368 km
Date: 2025.05.18
Time: 13:45:17
Engine speed: 766.50 /min
Normed load value: 13.3 %
Coolant temperature: 106 ∞C
Intake air temperature: 55 ∞C
Voltage terminal 30: 13.144 V
Engine oil temperature: 105.0 ∞C
Time since engine start: 411.1 s
T_ES: 0 min
T_AST_SAE: 409 s
Readiness: 1000 0101
Address 02: Auto Trans (J217) Labels:| 0CJ-927-156.clb
Part No SW: 4G1 927 153 HW: 0CK 927 156 AA
Component: 0CK 20TFSINAR H04 0003
Revision: --H04--- Serial number: 0000000607 CVN: D0CBFCAE
Coding: 000001
ASAM Dataset: EV_TCMDL382021 002021
ROD: EV_TCMDL382021_AU57.rod
VCID: 678BB7A31FEFF9F22E0-8032
MTF pump:
Subsystem 1 - Part No SW: 0CK 927 152 AA HW: 0CK 321 281 K
Component: V553 MTFP 002 0572
Serial number: 75117071160232000948
1 Fault Found:
20936 - No Communications with Steering Angle Sender (G85)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 158368 km
Date: 2025.05.18
Time: 11:07:05
Engine speed: 775 /min
Driving position: P
ATF temperature: 29 ∞C
Transmission output speed: 0 /min
Voltage terminal 30: 13.2 V
Engine torque: -4 Nm
selected gear: 1
Ctrl. mod.: operating condition: regular operation
Auxiliary pump for transmission: requesting function: Filter ATF
Auxiliary hydraulic pump for transmission oil: current: 1 A
Oil pressure reservoir: pressure: 27.1 bar
Pressure of clutch 1: actual value: 0.0 bar
Pressure of clutch 2: actual value: 0.0 bar
Clutch status: Neutral
Occurrence_counter_over_length_of_life: 1
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V2.clb
Part No SW: 4G0 907 379 S HW: 4G0 907 379 S
Component: ESP9 Premium H01 0530
Revision: -------- Serial number: --------------
Coding: 41A29641824569821B00
ASAM Dataset: EV_ESP9BOSCHAU57X 004018
ROD: EV_ESP9BOSCHAU57X.rod
VCID: 41DF493B510BE7C2C04-8014
22 Faults Found:
13056 - Function Restricted due to Missing Message(s)
U1111 00 [00100000] - -
[ComScl_PDU_EPB_01_Timeout]
172544 - Function Restricted due to Missing Message(s)
U1111 00 [00101111] - -
[ComScl_PDU_LH_EPS_02_Timeout]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Mileage: 158368 km
Date: 2025.05.18
Time: 11:07:04
VzRef: 00
Bit Info 1: C0
Bit Info 2: 40
Bit Info 3: 02
Bit Info 4: 1F
Uz: A8
120064 - Function Restricted due to Missing Message(s)
[ComScl_PDU_LH_EPS_03_Timeout]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Mileage: 158368 km
Date: 2025.05.18
Time: 11:07:04
VzRef: 00
Bit Info 1: C0
Bit Info 2: 40
Bit Info 3: 02
Bit Info 4: 1F
Uz: A8
17152 - Function Restricted due to Missing Message(s)
U1111 00 [10101111] - -
[ComScl_PDU_LWI_01_Timeout]
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 158368 km
Date: 2025.05.18
Time: 11:07:04
VzRef: 00
Bit Info 1: C0
Bit Info 2: 40
Bit Info 3: 02
Bit Info 4: 1F
Uz: A8
132608 - Function Restricted due to Missing Message(s)
[ComScl_PDU_SARA_06_Timeout]
124416 - Function Restriction due to Faults in Other Modules
U1113 00 [00101000] - -
[Ldm_ApbFailureState]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 158368 km
Date: 2025.05.18
Time: 13:45:17
VzRef: 00
Bit Info 1: 00
Bit Info 2: 43
Bit Info 3: 02
Bit Info 4: 1F
Uz: A9
132864 - FlexRay Databus
U1031 00 [00101000] - No Synchronization
[NET09_SyncLost_FlxrA]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 158368 km
Date: 2025.05.18
Time: 13:27:49
VzRef: 00
Bit Info 1: 00
Bit Info 2: 02
Bit Info 3: 20
Bit Info 4: 1F
Uz: A1
176384 - Function Restriction due to Implausible Message(s)
U1112 00 [00100000] - -
[SCL_EPB_Fehlerstatus_Invalid]
176896 - Function Restriction due to Implausible Message(s)
[SCL_EPB_Schalterposition_Invalid]
177408 - Function Restriction due to Implausible Message(s)
[SCL_EPB_Spannkraft_Invalid]
177664 - Function Restriction due to Implausible Message(s)
[SCL_EPB_Status_Invalid]
177920 - Function Restriction due to Implausible Message(s)
[SCL_EPB_Verzoeg_Anf_Invalid]
178176 - Function Restriction due to Implausible Message(s)
U1112 00 [00100011] - -
[SCL_EPS_DSR_Status_Invalid]
178688 - Function Restriction due to Implausible Message(s)
[SCL_EPS_Lenkmoment_Invalid]
178944 - Function Restriction due to Implausible Message(s)
[SCL_EPS_Lenkungstyp_Invalid]
179456 - Function Restriction due to Implausible Message(s)
[SCL_EPS_Unterstuetzungsleistung_Invalid]
205568 - Function Restriction due to Implausible Message(s)
[SCL_SARA_Accel_X_010_Invalid]
205824 - Function Restriction due to Implausible Message(s)
[SCL_SARA_Accel_Y_010_Invalid]
206080 - Function Restriction due to Implausible Message(s)
[SCL_SARA_Omega_Z_010_Invalid]
90880 - Front Left Wheel Speed Sensor
C101A 14 [00101000] - Open or Short to Ground
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 158368 km
Date: 2025.05.18
Time: 13:45:17
VzRef: 00
Bit Info 1: 00
Bit Info 2: 42
Bit Info 3: 02
Bit Info 4: 1F
Uz: A9
91648 - Front Left Wheel Speed Sensor
C101A 01 [00100000] - Electrical Failure
203520 - Front Left Wheel Speed Sensor
Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
Part No SW: 4H0 907 064 HR HW: 4H0 907 064 HR
Component: BCM2 2.0 H61 0825
Revision: 00002001
Coding: 0DA86F4E000000000000
VCID: 00598C3F1A012ECA8FA-8054
Subsystem 2 - Part No SW: 4H0 905 852 C HW: 4H0 905 852 C
Component: J764 ELV MLB H40 0046
Serial number: 3216000120728013
1 Fault Found:
01330 - Central Control Module for Central Convenience (J393)
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 6
Fault Frequency: 3
Reset counter: 167
Mileage: 158368 km
Time Indication: 0
Date: 2025.05.18
Time: 13:25:17
Address 08: Auto HVAC (J255) Labels:| 4G0-820-043-2Z.clb
Part No SW: 4G0 820 043 BP HW: 4G0 820 043 BP
Component: KLIMA 2 ZONEN H14 0113
Serial number: 17081600110357
Coding: 64013018C90000
ASAM Dataset: EV_AirCondiBasisUDS 003009
ROD: EV_AirCondiBasisUDS_003.rod
VCID: 6E85C287301528BA6D6-803A
1 Fault Found:
0276 - Engine Off Timer Performance
P150A 00 [00001000] - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 166
Mileage: 158368 km
Date: 2025.05.18
Time: 11:22:49
Voltage terminal 30: 12.04 V
Terminal 15 status: Terminal 15 on
Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V2.clb
Part No SW: 4H0 907 063 GM HW: 4H0 907 063 AM
Component: BCM1 2.0 H20 0368
Revision: 21020001 Serial number: 00001451778502
Coding: 26000091063C9FE08100488380003D0CCF9CD208A609022100 0004207100140200600034030000
VCID: 79AFE1DB79DB7F02C84-802C
Subsystem 1 - Part No SW: 4G1 955 119 HW: 4G8 955 119 Labels: 1KX-955-119.CLB
Component: WWS57X 160718 H38 0080
Serial number: 160725044349
Coding: 0045F7
Subsystem 2 - Part No SW: 8U0 955 559 C HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
Component: G397_RLFS H06 0004
Serial number: 62208865
Coding: 02006D
Subsystem 3 - Part No SW: 4G0 941 531 AL HW: 4G0 941 531 AL
Component: E1 - LDS H07 0044
Serial number: 22 08 2016 00000229
Subsystem 4 - Part No SW: 4G0 907 410 A HW: 4H0 907 410 A
Component: USHL4.2 H30 0030
Serial number: 00000000095Z026D5E0C
Subsystem 5 - Part No SW: 4G0 907 658 B HW: 4G0 907 658 B
Component: Humidity_Sens H01 0005
Serial number: 5059444800PAG0FSA002
7 Faults Found:
01309 - Power Steering Control Module (J500)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 6
Fault Frequency: 1
Reset counter: 126
Mileage: 158368 km
Time Indication: 0
Date: 2025.05.18
Time: 11:07:01
00466 - Control Module for Steering Column Electronics (J527)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 126
Mileage: 158368 km
Time Indication: 0
Date: 2025.05.18
Time: 11:07:03
Freeze Frame:
Fault Priority: 6
Fault Frequency: 14
Reset counter: 167
Mileage: 158368 km
Time Indication: 0
Date: 2025.05.18
Time: 11:07:24
01317 - Control Module in Instrument Cluster (J285)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 6
Fault Frequency: 1
Reset counter: 167
Time Indication: 0
01299 - Diagnostic Interface for Data Bus (J533)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 167
Time Indication: 0
01316 - ABS Control Module
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 167
Mileage: 158368 km
Time Indication: 0
Date: 2025.05.18
Time: 13:45:18
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 167
Mileage: 158368 km
Time Indication: 0
Date: 2025.05.18
Time: 13:45:22
Address 15: Airbags (J234) Labels:* 4H0-959-655.clb
Part No SW: 4G0 959 655 B HW: 4G0 959 655 B
Component: Airbag10.43 H62 0086
Revision: -------- Serial number: 003G0003D5FC Dataset Number: 4G0909602N 0002
Coding: 303331343134303334374A55304C34473053
ASAM Dataset: EV_AirbaAU10BPAAU64X 001014
ROD: EV_AirbaAU10BPAAU64X_VW51.rod
VCID: 343110EF1EB9426A5B2-8060
Seat occupied recognition:
Subsystem 1 - Part No SW: 5C6 959 339 B HW: 5C6 959 339 B
Component: BF-Gewichtss. H11 0046
Serial number: 6940000Y160001J6SE0%
Crash sensor for side airbag: driver side:
Serial number: 3575HRB405T436HQAPB0
Crash sensor for side airbag: passenger side:
Serial number: 3585HRB400Q571EQCOD-
Rear Side Airbag Crash Sensor (on driver's side):
Serial number: 3515JRB400K5752GJOVW
Passenger side rear thorax airbag crash sensor:
Serial number: 3525JRB400O5752GCPBB
Crash sensor for front airbag: driver side:
Serial number: 3554VRB400A5761QNHR/
Crash sensor for front airbag: passenger side:
Serial number: 3564VRB40045761QROQ2
3 Faults Found:
1049349 - Databus
U1123 00 [00001000] - Received Error Message
[CAN: 0x103 ESP_03 error value ESP_VL_Radgeschw]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 167
Mileage: 158368 km
Date: 2025.05.18
Time: 13:45:17
1050112 - Databus
U1121 00 [00001001] - Missing Message
[CAN: 0x086 LWI_01 Timeout]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 126
Mileage: 158368 km
Date: 2025.05.18
Time: 11:07:06
9682162 - Multiple collision brake
B13BC F2 [10001001] - No function
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 158368 km
Date: 2025.05.18
Time: 11:07:20
Address 16: Steering wheel (J527) Labels:. 4H0-953-568.clb
Part No SW: 4H0 953 568 K HW: 4H0 953 568 K
Component: Lenks.Modul H06 0005
Revision: C0068538 Serial number: 91560PHV00022
Coding: 000034
VCID: 3B233BD333678D129A8-806E
Subsystem 1 - Part No SW: 4G0 951 528 A HW: 4G0 951 528 A
Component: E221 - MFL H08 0010
Serial number: 08 07 2016 E0017336
2 Faults Found:
00895 - Cruise Control Switch (E45)
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 3
Fault Frequency: 13
Reset counter: 127
Mileage: 158368 km
Time Indication: 0
Date: 2025.05.18
Time: 11:07:01
003 - Mechanical Failure
Freeze Frame:
Fault Status: 01100011
Fault Priority: 3
Fault Frequency: 10
Reset counter: 127
Mileage: 158368 km
Time Indication: 0
Date: 2025.05.18
Time: 11:07:01
Address 17: Instruments (J285) Labels:| 4H0-920-xxx-17.clb-SRI1
Part No SW: 4G8 920 987 T HW: 4G8 920 987 T
Component: TBenUsa H14 0225
Revision: 11001108 Serial number: 658260816596021
Coding: 0BE609040B41D705020000
ASAM Dataset: EV_RBD4K 004060
ROD: EV_RBD4K_AU57.rod
VCID: 4ACD6E176C3D249A11E-801E
1 Fault Found:
16776978 - Function Restricted due to Missing Message(s)
U1111 00 [00001001] - -
[LH_EPS_01 keine Kommunikation]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 126
Mileage: 158368 km
Date: 2025.05.18
Time: 11:07:03
Address 19: CAN Gateway (J533) Labels:| 4H0-907-468.clb
Part No SW: 4G8 907 468 H HW: 4G8 907 468
Component: J533--Gateway H15 0096
Revision: -------- Serial number: 00000002356667 Dataset Number: 4G0909515K 0022
Coding: C0CD072910
GVL: FD81C808D820600D00040800
ASAM Dataset: EV_GatewPkoUDS 002000
ROD: EV_GatewPkoUDS_002_AU57.rod
VCID: 3D2735CB2DF38322A4C-8068
Battery Monitoring Control Module:
Subsystem 1 - Part No SW: 8S0 915 181 B HW: 8S0 915 181 B
Component: J367-BDMHella H10 9070
Serial number: 3863501204
Voltage stabilizer:
Subsystem 2 - Part No SW: 8K0 959 663 F HW: 8K0 959 663 F
Component: J532_DCDCStab H23 0022
Serial number: 16052600000000000128
4 Faults Found:
4906 - Power Steering Control Module
U101D 00 [00001001] - No Communication
Freeze Frame:
Fault Priority: 2
Fault Frequency: 15
Reset counter: 127
Mileage: 158368 km
Date: 2025.05.18
Time: 11:07:03
Voltage terminal 30: 13.0 V
Voltage terminal 15: 13.0 V
Control Module temperature: 27 ∞C
System status: Terminal 15 on
IN ESP_standstill flag: standstill detected
Engine running: On
IN ZAS_Te_X: On
Terminal 15 status via CAN: On
Terminal 15 status: On
Datenfeld: 0
4230 - No Communications with Steering Angle Sender (G85)
U0126 00 [00001001] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 126
Mileage: 158368 km
Date: 2025.05.18
Time: 11:07:03
Engine running: On
IN ZAS_Te_X: On
Datenfeld: 0
0265 - Data Bus for Control/Display
U10AF 00 [00001000] - 1-Wire Mode
Freeze Frame:
Fault Priority: 3
Fault Frequency: 30
Reset counter: 167
Mileage: 158368 km
Date: 2025.05.18
Time: 13:31:28
Voltage terminal 30: 13.1 V
Control Module temperature: 31 ∞C
Engine running: On
IN ZAS_Te_X: On
Datenfeld: 18
0274 - FlexRay-Data bus
U1048 00 [00001001] - defective
[Konzern-Datenbus Flexray defekt]
Freeze Frame:
Fault Priority: 1
Fault Frequency: 15
Reset counter: 127
Mileage: 158368 km
Date: 2025.05.18
Time: 11:07:03
Engine running: On
IN ZAS_Te_X: On
Datenfeld: 2
Address 36: Seat Mem. Drvr (J136) Labels: None
Part No SW: 4G8 959 760 HW: 4G8 959 760
Component: MEM-FS H03 0157
Revision: AA000000 Serial number: 00000214242201
Coding: 00581B0000006001000001010101102030303232203232
VCID: 77ABE7E34FCF6972BE0-8022
2 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 167
Mileage: 0 km
Time Indication: 0
01320 - Control Module for Climatronic (J255)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 167
Time Indication: 0
Address 3B: Sensor Elect. (J849) Labels: 4G0-907-637.clb
Part No SW: 4G0 907 637 H HW: 4G0 907 637 D
Component: SARA 3D H04 0056
Revision: -------- Serial number: EJ1BPA720SSVSW Dataset Number: 4G0909573C 0006
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
VCID: 333313F31BB74552428-8066
No fault code found.
Address 42: Door Elect, Driver (J386) Labels:. 4H0-959-793.clb
Part No SW: 4G8 959 793 J HW: 4G8 959 793 G
Component: TSG FA H03 0511
Coding: 011F17014E00628002000002
VCID: 47CB57237FAFD9F20E0-8012
3 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 167
Time Indication: 0
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 167
Time Indication: 0
01314 - Engine Control Module
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 167
Time Indication: 0
Address 44: Steering Assist
Cannot be reached
Address 46: Central Conv. (J393) Labels:. 4H0-907-064-46.clb
Revision: 00002001 Serial number: 0414979690
Coding: 0106063A00FA400580B0088402070E47000000000000000000 0000000000
Subsystem 1 - Part No SW: 4G0 959 719 HW: 4G0 959 719
Component: GTO BF H01 0081
Serial number: 00000000000000362099
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Subsystem 3 - Part No SW: 4G8 959 591 A HW: 8V3 959 591 A
Component: J245 PS40.402 H03 0004
Serial number: 0000FST001519M200000
Coding: 101F02
Subsystem 4 - Part No SW: 4G0 947 135 G HW: 4G0 947 135
Component: Dachelektroni H10 0100
Serial number: 0000000AP00024055916
Coding: 010000
4 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 15
Reset counter: 127
Mileage: 158368 km
Time Indication: 0
Date: 2025.05.18
Time: 11:07:01
03932 - Real Lid/Hatch Opening Sensor
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 126
Mileage: 158368 km
Time Indication: 0
Date: 2025.05.18
Time: 11:07:05
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 167
Mileage: 158368 km
Time Indication: 0
Date: 2025.05.18
Time: 13:25:17
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 167
Mileage: 158368 km
Time Indication: 0
Date: 2025.05.18
Time: 13:45:22
Address 52: Door Elect, Pass. (J387) Labels:. 4H0-959-792.clb
Part No SW: 4G8 959 792 J HW: 4G8 959 792 G
Component: TSG BF H03 0511
VCID: 46D55A2778A5C0FAF56-8012
3 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 167
Time Indication: 0
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 167
Time Indication: 0
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 167
Time Indication: 0
Address 53: Parking Brake (----) Labels: 4H0-907-801.clb
Part No SW: 4H0 907 801 L HW: 4H0 907 801 A
Component: EPB-4 H05 0017
Revision: -------- Serial number: 00000001936731 Dataset Number: 4G0909522F 0008
ASAM Dataset: EV_ParkiBrake 001029
ROD: EV_ParkiBrake_VW51.rod
VCID: 313F19FBE1AB7742304-8064
1 Fault Found:
459520 - Function Restriction due to Faults in Other Modules
U1113 00 [00001000] - -
[FC_SIGNAL_ESP_FL_RADGESCHW_ERROR_VALUE]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 167
Mileage: 158368 km
Date: 2025.05.18
Time: 13:45:17
Voltage terminal 30: 13.3 V
Internal Fault ID: 139
Network management state: normal
Function light in parking brake button: On
Red operating lamp: On
Red warning lamp: OFF
Green operating lamp: OFF
Yellow warning lamp: OFF
RWU: not active
DSD: not active
HTR: not active
ECD: not active
ACC requested apply: not active
Auto Adjust: not active
General Inspection Function: not active
Internal Parking Brake state: static
Status of parking brake button: Not operated
Status ParkingBrake left: applied
Status ParkingBrake right: applied
Address 5F: Information Electr. (J794) Labels:| 4G1-035-MIB-HGH2.clb
Part No SW: 4G1 035 025 C HW: 4G1 035 025 C
Component: MU-H-LNS-US 052 0671
Serial number: A741I0G7513385 Dataset Number: 4G1909545H 0037
Coding: 01750102FF0A000013220001041A00102F0006E5F17001047E
ASAM Dataset: EV_MUHig6C3Gen2HBAS 001115
ROD: EV_MUHig6C3Gen2HBAS_AU57.rod
VCID: 1E65D2478035F83A9D6-804A
Data carrier:
Subsystem 1 - Part No SW: V03 959 802 DL HW: -----------
Component: NAR 2019 --- 0069
Serial number: --------------------
Multimedia display unit 1:
Subsystem 2 - Part No SW: 4G1 919 605 B HW: 4G1 919 605 B
Component: DU8 C7 SV H63 0007
Serial number: AUZ8Z9GY805ZFR
Multimedia system control head:
Subsystem 3 - Part No SW: 4G1 919 610 F HW: 4G1 919 610 F
Component: E380 BDT C7 H20 0250
Serial number: 90349QIK00135
Compact disc data bank:
Subsystem 4 - Part No SW: V03 959 800 EG HW: -----------
Component: Gracenote2--- --- 3009
1 Fault Found:
0020 - Tuner for Satellite Radio
B11CF 53 [00001001] - Deactivated
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 126
Mileage: 158368 km
Date: 2025.05.18
Time: 11:15:44
Voltage terminal 30: 12.6 V
Satellite radio tuner status-Satellite radio antenna status: electrically OK
Satellite radio tuner status-Channel selection for satellite radio: 0
Satellite radio tuner status-Audio Signal: Not available
Satellite radio tuner status-Antenna current: 0 mA
Satellite radio tuner status-Reception quality: Not available
Satellite radio tuner status-Satellite radio tuner: pre-activation status: 00
Satellite radio tuner status-Satellite radio tuner: pre-activation value: 00
Address 62: Door, Rear Left (J388) Labels:. 4H0-959-795.clb
Part No SW: 4G8 959 795 J HW: 4G8 959 795 G
Component: TSG HL H03 0511
Coding: 010F17004000628002000002
VCID: 49CF511B69BB2F82184-801C
Address 6C: Back-up Cam. (J772) Labels:| 4S0-980-556.clb
Part No SW: 4S0 980 556 HW: 4M0 980 556
Component: RVC Compact H08 0140
Dataset Number: 4G0909460D 0013
Coding: 0275000102002003000040
ASAM Dataset: EV_CamSysRVRVCPANAAU57X 001001
ROD: EV_CamSysRVRVCPANAAU57X_001.rod
VCID: 78A9E4DF4251660AB7A-802C
1 Fault Found:
13705510 - Databus
[Oldbit-monitoring Gateway_06.LWI_01_alt]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 126
Mileage: 158368 km
Date: 2025.05.18
Time: 11:07:31
passive
Address 72: Door, Rear Right (J389) Labels:. 4H0-959-795.clb
Component: TSG HR H03 0511
Address 8F: Pretens. Frt Left (J854) Labels: 4H0-980-94x-RGS.clb
Part No SW: 4H0 980 945 B HW: 4H0 980 945 C
Component: RGS-VL H16 0080
Dataset Number: 4G0909614C 0001
Coding: 00060000031F030000030801424CDA010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
1 Fault Found:
12583690 - Function Restricted due to Missing Message(s)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 126
Mileage: 158368 km
Date: 2025.05.18
Time: 11:07:03
Address 90: Pretens. Frt Right (J855) Labels: 4H0-980-94x-RGS.clb
Part No SW: 4H0 980 946 B HW: 4H0 980 946 C
Component: RGS-VR H16 0080
Dataset Number: 4G0909615C 0001
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
VCID: 323D16F7E4AD4C5A49E-8066
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 126
Mileage: 158368 km
Date: 2025.05.18
Time: 11:07:03
End----------(Elapsed Time: 02:38, VBatt start/end: 12.9V/13.1V)-----------
------------------------------65 Faults Found------------------------------
tenspeed
A7
Jan 24, 2025 04:37 PM
EEM
Audi A3 / S3 / RS 3 MKII
Nov 19, 2024 05:46 AM
anuragh
Q7 MK 1 Discussion
14
Feb 17, 2024 05:10 PM
Matijan3001
A6 (C7 Platform) Discussion
Oct 19, 2022 11:05 AM
F_Palle
May 17, 2021 03:39 PM
