Q8 is dead - Mystery?
2. LIST OF DTCs
U041600 INVALID DATA RECEIVED FROM VEHICLE DYNAMICS CONTROL MODULE - ACTIVE
U028700 LOST COMMUNICATION WITH TRANSMISSION FLUID PUMP MODULE A - ACTIVE
U112300 DATABUS ERROR VALUE RECEIVED - ACTIVE
C052F00 ABS PUMP MOTOR SUPPLY VOLTAGE CIRCUIT/OPEN - ACTIVE
U112100 DATABUS MESSAGE MISSING - ACTIVE
U112300 DATABUS ERROR VALUE RECEVIED - ACTIVE
U020800 LOST COMMUNICATION WITH SEAT CONTROL MODULE A
B13BCF2 MULTIPLE COLLISION BRAKE NO FUNCTION
Symptom summary
- Engine shut off while reversing (under load / low speed maneuver)
- Now: cranks but does not start
- Multiple simultaneous U-codes (network/communication faults) + ABS/power supply faults
Most likely root causes (ranked)
1. Low system voltage / failing battery / loose terminal
This is the single most common cause given your DTC cluster.Why it fits:
- U-codes across unrelated modules (ABS, transmission pump, seat module)
- ABS pump voltage circuit open (C052F00)
- Sudden stall during maneuver (high electrical load event: steering, braking, reversing sensors)
- Crank/no-start after stall
- Drop module bus voltage
- Corrupt CAN communication → U-codes cascade
- Disable fuel/ignition enable logic → crank/no start
2. Main ground or power distribution fault
Common scenarios:- Loose engine ground strap
- Corroded chassis ground point
- Failing battery ground to body/engine
- Blown main fusible link / power distribution block issue
- Random module dropouts
- ABS pump supply faults
- “Lost communication” across multiple ECUs
3. ABS / stability system power failure cascading into CAN issues
The ABS code:- C052F00 (pump motor supply voltage/open)
- ABS module is a CAN gateway or heavily integrated node
- If it drops out, it can trigger widespread U-codes
4. Transmission pump module communication loss
U028700 suggests loss of communication with transmission pump module.This again typically happens when:
- CAN bus voltage collapses
- Module loses power supply rather than failing independently
5. Less likely but possible
- Water intrusion into fuse box / BCM area
- Failed Body Control Module (BCM)
- CAN bus short to ground or short between lines
- Immobilizer issue (usually would not generate this many unrelated U-codes)
Why it now only cranks but won’t start
Crank/no-start after a stall with network faults usually means:- ECU is not fully booting or is intermittently resetting
- Fuel injection / ignition enable is not being authorized
- CAN network is unstable so key modules cannot coordinate start sequence
What to check first (in order)
1. Battery voltage (critical)
- Engine off: ~12.6V healthy
- Cranking: should stay above ~9.6–10V
- <12V static → battery likely failed
- large drop during crank → battery or connection issue
2. Battery terminals
Check:- Tightness (cannot rotate by hand)
- Corrosion under clamp (often invisible)
- Ground cable condition
3. Engine ground strap
Look for:- Frayed braided strap from engine to chassis
- Loose bolt at transmission bellhousing / frame
4. Main fuse / power distribution
Inspect:- Fusible link / main fuse box under hood
- ABS pump supply fuse (given C052F00)
- Signs of heat damage or melting
5. CAN wake-up behavior (quick clue test)
Turn ignition ON:- Do dash lights fully initialize?
- Any flickering?
- ABS/traction lights immediately on?
Interpretation of your DTC cluster
This combination is important:- U041600 (invalid data from vehicle dynamics control)
- U112100 / U112300 (bus errors/missing messages)
- U028700 (lost transmission pump module)
- C052F00 (ABS pump voltage open)
It is almost always:
A shared electrical supply or ground failure affecting multiple modules at once.
Most probable outcome
In practice, cases like this resolve with:- Battery replacement OR
- Ground cable repair/replacement OR
- Main fuse/terminal block repair
If you want a precise next step
Provide:- Vehicle year/make/model/engine
- Battery age
- Voltage readings (resting + cranking)
- Whether dash fully powers up normally
