A5 2013 3.0 TDI quattro random chrismats tree on the dash
Like the title is saying I have A5 2013 3.0 TDI quattro with s tronic. Car runs nice, well serviced chains and everything.
Randomly couple times a year I get TPMS, ESP, parking brake and glow plug light. There is no check engine light, no limp mode but car goes from 800 to like 1k rpms idle. Below is my VCDS scan, once I clear the codes everything goes away and car runs fine with no errors showing in VCDS.
This happened to me today, last time before it happened like 1 year ago. Anyone having idea what this could be ?
Sunday,14,June,2026,14:15:07:00009
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64
VCDS Version: 22.3.1.1
Data version: 20220401 DS337.0
www.Ross-Tech.com
Mileage: 228640km-142070mi Repair Order: kk
Chassis Type: 8T-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 20 42 44 46 52 53 56 5F 62 72
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 1010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
20-High Beam Assist. -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (J623-CDUC) Labels:. 059-907-401-V2.clb
Part No SW: 8K5 997 401 HW: 4G0 907 401
Component: 3.0TDI EDC17 H41 0006
Revision: 53H41--- CVN: F26646D1
Coding: 1A254012052603020000
Shop #: WSC 57335 003 1048576
ASAM Dataset: EV_ECM30TDI0118K5997401 001006
ROD: EV_ECM30TDI0118K5997401.rod
VCID: 76E353DFC9C7343FE0-8022
VINID: 9D196AAAA2241D44401C51411CDA74C60D
11 Faults Found:
4367 - Powertrain Databus
U0001 00 [032] - Unspecified Malfunction
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 3
Mileage: 228641 km
Date: 2000.00.00
Time: 00:00:00
Engine RPM: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 29 C
Intake air temperature: 25 C
Ambient air pressure: 940 mbar
Voltage terminal 30: 12.160 V
Unlearning counter according OBD: 40
Accelerator pedal travel: 0.00 %
Accelerator pedal: sensor voltage 1: 757.4 mV
Accelerator pedal: sensor voltage 2: 381.0 mV
Accelerator pedal: switch positions-Bits 0-7: 8
Starter control: Interlock- or P/N-signal-Bits 0-7: 17
Limitation: torque: 0.0 Nm
Control Module temperature: 46.0 C
18735 - Steering Effort Control Module
U0130 00 [038] - No Communications
Freeze Frame:
Fault Priority: 6
Fault Frequency: 16
Mileage: 228641 km
Date: 2026.06.14
Time: 20:07:04
Engine RPM: 902.00 /min
Normed load value: 36.1 %
Coolant temperature: 28 C
Intake air temperature: 24 C
Voltage terminal 30: 13.100 V
Limitation: accelerator pedal: 0.0 Nm
CAN status - engine control module-Bits 0-7: 8
Cruise Control System (CCS): status-Bits 0-7: 44
CAN status - transmission control module-Bits 0-7: 0
CAN status - brake control module 1-Bits 0-7: 0
CAN status - brake control module 2-Bits 0-7: 0
selected gear-Bits 0-7: 0
5608 - No Communications with Steering Angle Sender (G85)
U0126 00 [038] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 17
Mileage: 228641 km
Date: 2026.06.14
Time: 20:07:04
4708 - No Communications with HVAC Control Module (J301)
U0164 00 [038] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 14
Mileage: 228641 km
Date: 2026.06.14
Time: 20:07:04
Engine RPM: 1023.50 /min
Normed load value: 39.6 %
Vehicle speed: 255 km/h
Voltage terminal 30: 13.120 V
Cruise Control System (CCS): status-Bits 0-7: 236
4713 - No Communication with ABS Brake Control Module
U0121 00 [167] - -
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
MIL ON - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 228641 km
Date: 2026.06.14
Time: 20:07:04
4714 - Steering Column Control Module
U0212 00 [038] - No Communications
Freeze Frame:
Fault Priority: 6
Fault Frequency: 9
Mileage: 228641 km
Date: 2026.06.14
Time: 20:07:06
Engine RPM: 1002.00 /min
Normed load value: 33.3 %
Voltage terminal 30: 13.260 V
4715 - No Communication with Instrument Cluster
U0155 00 [038] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 23
Mileage: 228641 km
Date: 2026.06.14
Time: 20:07:04
4716 - No Communications with Parking Brake Control Module
U0128 00 [038] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 20
Mileage: 228641 km
Date: 2026.06.14
Time: 20:07:04
4718 - No Communication with Transmission Control Module
U0101 00 [038] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 228641 km
Date: 2026.06.14
Time: 20:08:22
Coolant temperature: 31 C
Voltage terminal 30: 11.960 V
CAN status - engine control module-Bits 0-7: 0
Cruise Control System (CCS): status-Bits 0-7: 205
4719 - No Communication with Diagnostic Gateway
U0146 00 [038] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 18
Mileage: 228641 km
Date: 2026.06.14
Time: 20:07:04
4720 - Body Control Module (Central Electric 2)
U0141 00 [038] - No Communications
Freeze Frame:
Fault Priority: 6
Fault Frequency: 10
Mileage: 228641 km
Date: 2026.06.14
Time: 20:07:06
Engine RPM: 995.00 /min
Normed load value: 34.5 %
Readiness: 0 0 0 0 1
Address 02: Auto Trans (J217) Labels:| 0B5-927-156.clb
Part No SW: 8K2 927 156 J HW: 0B5 927 156 J
Component: 0B5 30 TDIRdW H01 0009
Revision: --H01--- CVN: 00003611
Coding: 000001
Shop #: WSC 06325 000 00000
ASAM Dataset: EV_TCMDL501021 001025
ROD: EV_TCMDL501021.rod
VCID: 3D718CF3AC71A767E1-8068
5 Faults Found:
7999 - No Communication with Instrument Cluster
U0155 00 [038] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 40
Mileage: 228641 km
Date: 2026.06.14
Time: 20:07:08
Engine RPM: 1001 /min
Transmission input speed: 1001 /min
Transmission output speed: 0 /min
Engine torque: -12 Nm
ATF temperature: 27 C
Accelerator pedal position: 0.0 %
Clutch status: Beide Kupplungen offen
Voltage terminal 30: 13.400 V
Voltage_5V_CAN_pressuresensors-Param to DOP: 4.910 V
8001 - No Communication with Diagnostic Gateway
U0146 00 [038] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 40
Mileage: 228641 km
Date: 2026.06.14
Time: 20:07:08
Engine RPM: 999 /min
Transmission input speed: 999 /min
Voltage_5V_CAN_pressuresensors-Param to DOP: 4.912 V
8013 - Body Control Module (Central Electric)
U0140 00 [038] - No Communications
Freeze Frame:
Fault Priority: 6
Fault Frequency: 5
Reset counter: 40
Mileage: 228641 km
Date: 2026.06.14
Time: 20:09:03
Engine RPM: 0 /min
Transmission input speed: 0 /min
Engine torque: -60 Nm
ATF temperature: 28 C
Voltage terminal 30: 11.900 V
20363 - No Communications with HVAC Control Module (J301)
U0164 00 [038] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 40
Mileage: 228641 km
Date: 2026.06.14
Time: 20:08:25
Engine RPM: 0 /min
8015 - Steering Column Control Module
Freeze Frame:
Fault Priority: 6
Fault Frequency: 8
Reset counter: 40
Mileage: 228641 km
Date: 2026.06.14
Time: 20:08:25
Engine RPM: 0 /min
Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V1.clb
Part No SW: 8K0 907 379 CK HW: 8K0 907 379 CK
Component: ESP8 quattro H09 0100
Revision: -------- Serial number: --------------
Coding: 391D4C
VCID: 04073917871B16AFEE-8050
3 Faults Found:
01314 - Engine Control Module
013 - Check DTC Memory
Freeze Frame:
Fault Status: 01101101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 220
Mileage: 228641 km
Time Indication: 0
Date: 2026.06.14
Time: 20:07:04
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x40A2
Hex Value: 0x000B
Hex Value: 0x49A3
Hex Value: 0x0000
01315 - Transmission Control Module
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 6
Fault Frequency: 1
Reset counter: 220
Mileage: 228641 km
Time Indication: 0
Date: 2026.06.14
Time: 20:07:05
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x62A2
Hex Value: 0x000D
Hex Value: 0x85A4
Hex Value: 0x0000
00473 - Control Module for Elect. Park/Hand Brake (J540)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 220
Mileage: 228641 km
Time Indication: 0
Date: 2026.06.14
Time: 20:07:05
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x62A0
Hex Value: 0x001A
Hex Value: 0x02A2
Hex Value: 0x0000
Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
Part No SW: 8K0 907 064 GF HW: 8K0 907 064 FF
Component: BCM2 2.0 H12 0633
Revision: 00002001
Coding: 05A44040000000000000
VCID: 7AFB47EFF5DF505F84-802E
1 Fault Found:
01330 - Central Control Module for Central Convenience (J393)
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 6
Fault Frequency: 7
Reset counter: 4
Mileage: 228641 km
Time Indication: 0
Date: 2026.06.14
Time: 20:07:06
Address 08: Auto HVAC (J255) Labels:. 8Kx-820-043-3Z.clb
Part No SW: 8K1 820 043 T HW: 8K1 820 043 T
Component: KLIMA 3 ZONEN H04 0123
Revision: C1000000 Serial number: 01180420131932
Coding: 3620028000
VCID: 397998E3B0599B47CD-806C
No fault code found.
Address 09: Cent. Elect. (J519) Labels:. 8K0-907-063.clb
Part No SW: 8K0 907 063 DF HW: 8K0 907 063 DF
Component: BCM1 1.0 H16 0103
Revision: 06016001 Serial number: 00000045895102
Coding: 260000108074AFE01781400300001D0D4F1C42082609020100 0008004401030100000000000000
Shop #: WSC 06325 123 12345
VCID: 76E353DFC1C7343FE0-8022
Subsystem 1 - Part No SW: 8T1 955 119 D HW: 8J1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 150413 H15 0080
Serial number: SWF13040155376
Coding: 00FD11
Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
Component: G397_RLFS H06 0002
Serial number: 21206254
Coding: 02005D
Subsystem 3 - Part No SW: 8K0 941 531 AS HW: 8K0 941 531 AS
Component: E1 - LDS H03 0031
Serial number: 00000000001004130035
Subsystem 4 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H03 0003
Serial number: 167903A6000000000001
1 Fault Found:
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 6
Fault Frequency: 4
Reset counter: 5
Mileage: 228641 km
Time Indication: 0
Date: 2026.06.14
Time: 20:07:06
Address 15: Airbags (J234) Labels:| 8K0-959-655.clb
Part No SW: 8K0 959 655 N HW: 8K0 959 655 N
Component: AirbagVW-AU10 H45 0610
Serial number: 003KFD99MFM%
Coding: 30513938363030303030554A304C38543053
ASAM Dataset: EV_AirbaECUVWAUDI010 003010
ROD: EV_AirbaECUVWAUDI010_003_AU48.rod
VCID: 489FED27F3B3F2CF42-801C
Crash sensor for side airbag: driver side:
Serial number: 6334MSME79443047B
Front Passenger's Side Airbag Crash Sensor:
Serial number: 6344MSME7A415A6AR
Rear Side Airbag Crash Sensor (on driver's side):
Serial number: 6352QSME2C321D54J
Passenger side rear thorax airbag crash sensor:
Serial number: 6362QSME0A312E56J
Crash sensor for front airbag: driver side:
Serial number: 63732SME25301064K
Crash sensor for front airbag: front passenger side:
Serial number: 63832SME402F1060S
3 Faults Found:
12583424 - Powertrain Databus
U0002 00 [008] - No Communications
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 5
Reset counter: 5
Mileage: 228641 km
Date: 2026.06.14
Time: 20:07:04
12670208 - No Communication with Instrument Cluster
U0155 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 5
13636864 - Control Module for ABS Brakes
U1015 00 [008] - No Communications
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 5
Address 16: Steering wheel (J527) Labels:. 8K0-953-568.clb
Part No SW: 8R0 953 568 Q HW: 8R0 953 568 Q
Component: Lenks.Modul H02 0171
Revision: 00000000 Serial number: 20130418001153
Coding: 000036
Shop #: WSC 65500 001 104857
VCID: 4FADC63B1EDD25F703-801A
Component: E221 - MFL H03 0004
Address 17: Instruments (J285) Labels:. 8T0-920-xxx-17.clb
Part No SW: 8T0 920 932 HW: 8T0 920 932
Component: KOMBIINSTR. H35 0556
Revision: 00200000 Serial number: UUV25JF4E
Coding: 13A7310003010008000000
VCID: 75E154D3DCC13F27E9-8020
Address 19: CAN Gateway (J533) Labels:. 8T0-907-468.clb
Part No SW: 8R0 907 468 P HW: 8R0 907 468 D
Component: GW-BEM 5CAN-M H11 0056
Revision: 1Z110028 Serial number: 2841Z1333001B7
Coding: 80C707FF00
VCID: 4C97D137EFCB1EEF66-8018
Subsystem 1 - Part No SW: 8T0 915 181 HW: 8T0 915 181
Component: J367-BDMHella H03 8041
Serial number: 7959928901
Subsystem 2 - Part No SW: 8K0 959 663 HW: 8K0 959 663
Component: J532_DCDCStab H17 0042
Serial number: 13106002552011200181
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 5
Mileage: 228641 km
Time Indication: 0
Date: 2026.06.14
Time: 19:56:50
Freeze Frame:
Bin. Bits: 10000
Voltage: 11.90 V
Count: 7
Bin. Bits: 10000
Time: 0.40 s
01312 - Powertrain Data Bus
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 1
Fault Frequency: 3
Reset counter: 5
Mileage: 228641 km
Time Indication: 0
Date: 2026.06.14
Time: 19:59:07
Freeze Frame:
Bin. Bits: 10000
Voltage: 12.10 V
Count: 7
Bin. Bits: 10000
Address 20: High Beam Assist. (J844) Labels:. 8K0-857-511.clb
Part No SW: 8T0 857 511 AD HW: 8T0 857 511 AD
Component: FLA H04 0012
Revision: AA001002
Coding: 02019864747464545425363E00
VCID: 7CF741F7FFEB6E6F96-8028
Address 42: Door Elect, Driver (J386) Labels:. 8K0-959-793.clb
Part No SW: 8T0 959 793 P HW: 8T0 959 793 G
Component: TSG FA H09 0304
Coding: 011C12625C00450005
VCID: 56A3335F2107543FC0-8002
Address 44: Steering Assist (J500) Labels:| 8K0-909-144.clb
Part No SW: 8K0 909 144 F HW: 8K0 909 144 B
Component: RCEPS H37 0507
Revision: 00001000 Serial number: 0008380429
Coding: 100000000001
Shop #: WSC 06324 000 00000
ASAM Dataset: EV_RCEPSAU48X 008014
ROD: EV_RCEPSAU48X_008.rod
VCID: 3467A9D79F3B662F1E-8060
Address 46: Central Conv. (J393) Labels:. 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0304722578
Coding: 01000E2020B900818320043680000000
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 7
Reset counter: 4
Mileage: 228641 km
Time Indication: 0
Date: 2026.06.14
Time: 20:07:06
Address 52: Door Elect, Pass. (J387) Labels:. 8K0-959-792.clb
Part No SW: 8T0 959 792 P HW: 8T0 959 792 G
Component: TSG BF H09 0304
Coding: 011C12225E00450005
VCID: 55A134533C015F27C9-8000
Address 53: Parking Brake (----) Labels: 8K0-907-801-V2.clb
Part No SW: 8K0 907 801 L HW: 8K0 907 801 J
Component: EPB-4 H01 0003
Revision: -------- Serial number: 30000000040508
ASAM Dataset: EV_ParkiBrake 001027
ROD: EV_ParkiBrake_AU48.rod
VCID: 387F9DE78353824F32-806C
2 Faults Found:
329728 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 9
Reset counter: 5
Mileage: 228641 km
Date: 2026.06.14
Time: 20:07:04
Voltage terminal 30: 13.1 V
Internal Fault ID: 94
Network management state: normal
Function light in parking brake button: On
Red operating lamp: On
Red warning lamp: OFF
Green operating lamp: OFF
Yellow warning lamp: OFF
Terminal 15 status: On
RWU: not active
DSD: not active
HTR: not active
ECD: not active
ACC requested apply: not active
Auto Adjust: not active
General Inspection Function: not active
Internal Parking Brake state: static
Status of parking brake button: Not operated
Status ParkingBrake left: applied
Status ParkingBrake right: applied
329984 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 7
Reset counter: 5
Mileage: 228641 km
Date: 2026.06.14
Time: 20:07:04
Internal Fault ID: 95
RWU: not active
DSD: not active
HTR: not active
ECD: not active
Address 56: Radio (R) Labels:. 4F0-035-0xx-56.clb
Part No SW: 4G1 035 053 G HW: 4G1 035 053
Component: Radio U Basic H41 0121
Revision: AB001007 Serial number: 227D%0D7728419
Coding: 010003020100000001
VCID: 23455A8B22D5F197F7-8076
Address 5F: Information Electr. (J794) Labels:. 4E0-035-6xx-5F.clb
Part No SW: 8R1 035 666 B HW: 8R1 035 666 C
Component: H-BN-EU H45 0639
Revision: -------- Serial number: 205E00E7584971
Coding: 130100040006E1EC05808B5C00000401E40000020000000000
VCID: 377D9EDB864D8D373B-8062
Subsystem 1 - Part No: 8R0 060 884 AR
Component: ECE 2013 1505
Subsystem 2 - Part No SW: 8R0 919 604 A HW: 8R0 919 604 A
Component: DU7 High H42 0104
Serial number: A130DL0D2703624
Subsystem 3 - Part No SW: 8T0 919 611 L HW: 8T0 919 611 C
Component: E0380 Bedient H02 0030
Serial number: 00000001480791
Subsystem 4 - Part No: 8R0 060 961 E
Component: CD-Database 4949
Address 62: Door, Rear Left (J388) Labels:. 8K0-959-795.clb
Part No SW: 8T0 959 795 Q HW: 8T0 959 795 H
Component: TSG HL H07 0304
Coding: 010C12224000450005
VCID: 59B9386350197B47ED-800C
Address 72: Door, Rear Right (J389) Labels:. 8K0-959-794.clb
Component: TSG HR H07 0304
End-------------------------(Elapsed Time: 03:22)--------------------------
