SE: So many trouble codes! Help!!
Old May 12, 2021 | 07:31 AM
F_Palle's Avatar
Default SE: So many trouble codes! Help!!
Hello! I have started to have several trouble codes in late time, it comes more often and the instrument i lighting up as a christmas tree...
ABS , ESP , Gearbox , Engine , Tire Pressure , Handbrake , and the speedo stops working, also the power steering and AC.
Please Help
//Regards Fredrik
Monday,10,May,2021,18:33:16:00007
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 18.9.0.2
Data version: 20180927 DS296.0
www.Ross-Tech.com
VIN: WAUZZZ4G0CN085614 License Plate: 1111111111111111111
Mileage: 237818km-147773mi Repair Order: 111111111111111
Chassis Type: 4G-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 28 30 3B 42 44 46 52 53 5F
62 69 6D 72 8F 90
VIN: WAUZZZ4G0CN085614 Mileage: 237818km-147773miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
28-HVAC, Rear -- Status: Malfunction 0010
30-Special Function II -- Status: Malfunction 0010
3B-Sensor Elect. -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: Malfunction 0010
5F-Information Electr. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
69-Trailer -- Status: OK 0000
6D-Trunk Elect. -- Status: Malfunction 0010
72-Door, Rear Right -- Status: OK 0000
8F-Pretens. Frt Left -- Status: Malfunction 0010
90-Pretens. Frt Right -- Status: Malfunction 0010
Address 01: Engine (J623-CLAB) Labels:. 059-907-401-V2.clb
Part No SW: 4G0 907 311 G HW: 4G0 907 401
Component: 3.0TDI EDC17 H37 0003
Revision: 53H37---
Coding: 12034012053401020800
Shop #: WSC 00365 211 178921
ASAM Dataset: EV_ECM30TDI0114G0907311G 001003
ROD: EV_ECM30TDI0114G0907311G.rod
VCID: 275D4D9D5EED1372B4-8072
7 Faults Found:
4698 - Function Restriction due to Faults in Other Modules
U1113 00 [044] - -
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 6
Mileage: 237811 km
Date: 2021.05.10
Time: 17:07:19
Engine speed: 1049.50 /min
Normed load value: 47.5 %
Vehicle speed: 255 km/h
Coolant temperature: 87 °C
Intake air temperature: 31 °C
Ambient air pressure: 970 mbar
Voltage terminal 30: 13.520 V
Unlearning counter according OBD: 40
Cruise Control System (CCS): switch position-Bits 0-7: 10000001
Cruise Control System (CCS): status-Bits 0-7: 00101100
Cruise control switch-off: irreversible-Bits 0-7: 11111111
Cruise control switch-off: reversible-Bits 0-7: 11111111
Cruise Control System: specified speed: 0.00 km/h
Engine control module reset status-Bits 0-7: 00000000
Cruise control switch-off: irreversible w. brake intervention-Bits 0-7: 00000000
4699 - Function Restriction due to Faults in Other Modules
U1113 00 [032] - -
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 237502 km
Date: 2021.05.03
Time: 20:19:08
Engine speed: 781.00 /min
Normed load value: 23.1 %
Vehicle speed: 0 km/h
Coolant temperature: 77 °C
Intake air temperature: 12 °C
Ambient air pressure: 980 mbar
Voltage terminal 30: 14.620 V
Unlearning counter according OBD: 29
5250 - Function Restriction due to Faults in Other Modules
U1113 00 [032] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Mileage: 237502 km
Date: 2021.05.03
Time: 20:19:08
Engine speed: 775.50 /min
Normed load value: 25.1 %
Voltage terminal 30: 14.600 V
ACC target acceleration: 0.000 m/s²
ACC control module received status-Bits 0-7: 00000110
Active brake system error status-Bits 0-7: 00000000
Status of ACC/CCS acceleration interface-Bits 0-7: 00000000
Acceleration: 0.000 m/s²
Engine status: COENG_RUNNING
4660 - Please Check Fault Codes in Control Module for ABS Brakes
U1017 00 [032] - -
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Mileage: 237502 km
Date: 2021.05.03
Time: 20:19:08
7136 - No Communication with ABS Brake Control Module
U0121 00 [044] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 74
Mileage: 237811 km
Date: 2021.05.10
Time: 17:07:17
Engine speed: 1156.00 /min
Normed load value: 64.3 %
Vehicle speed: 37 km/h
Voltage terminal 30: 13.540 V
Limitation: accelerator pedal: 132.3 Nm
CAN status - engine control module-Bits 0-7: 00000000
Cruise Control System (CCS): status-Bits 0-7: 00101000
CAN status - transmission control module-Bits 0-7: 00000000
CAN status - brake control module 1-Bits 0-7: 00000000
CAN status - brake control module 2-Bits 0-7: 00000000
selected gear-Bits 0-7: 00000100
4713 - No Communication with ABS Brake Control Module
U0121 00 [172] - -
MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Mileage: 237811 km
Date: 2021.05.10
Time: 17:07:11
Engine speed: 1127.50 /min
Normed load value: 67.5 %
Vehicle speed: 19 km/h
Limitation: accelerator pedal: 0.0 Nm
selected gear-Bits 0-7: 00000000
5523 - Engine Start Blocked by Immobilizer
P1570 00 [032] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 237487 km
Date: 2021.05.03
Time: 17:27:19
Engine speed: 741.50 /min
Normed load value: 0.0 %
Coolant temperature: 64 °C
Intake air temperature: 16 °C
Ambient air pressure: 990 mbar
Voltage terminal 30: 11.580 V
Immobilizer snapshot A-Sia Error Snap A: 1C 17 0F
Immobilizer snapshot B-Sia Error Snap B: 1A 00 00
Readiness: 1 1 0 0 0
Address 02: Auto Trans (J217) Labels:| 0AW-927-156.clb
Part No SW: 4G1 927 155 F HW: 0AW 927 156 K
Component: 0AW 30TDI RdW H04 0002
Revision: --H04--- Serial number: 0000000038
Coding: 000001
Shop #: WSC 02311 785 00200
ASAM Dataset: EV_TCMVL381 A02428
ROD: EV_TCMVL381.rod
VCID: 2F6DA5BD761D4B327C-807A
3 Faults Found:
2265 - No Communication with ABS Brake Control Module
U0121 00 [044] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 30
Mileage: 237502 km
Date: 2021.05.03
Time: 20:19:33
Transmission input speed: 1 /min
Transmission output speed: 1 /min
Engine torque: 4 Nm
Transmission fluid temperature: 64 °C
Accelerator position: 0.0 %
Clutch status: 13
Occurrence_counter_over_length_of_life: 149
2310 - Transmission Control Unit
P1701 00 [044] - Locked
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 237487 km
Date: 2021.05.03
Time: 17:27:19
Engine speed: 778.00 /min
Engine torque: -40 Nm
Transmission fluid temperature: 49 °C
Clutch status: 1
Unlearning counter according OBD: 28
Occurrence_counter_over_length_of_life: 8
Immobilizer_ambient_data: 1D 1D 11 12 00 00
7063 - Torque Request to Engine Implausible
P183A 00 [044] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 237814 km
Date: 2021.05.10
Time: 17:24:47
Engine speed: 1088.00 /min
Transmission input speed: 1083 /min
Transmission output speed: 92 /min
Engine torque: -16 Nm
Transmission fluid temperature: 92 °C
Accelerator position: 4.4 %
Clutch status: 6
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V1.clb
Part No SW: 4G0 907 379 H HW: 4G0 907 379 H
Component: ESP PREMIUM H09 0361
Revision: -------- Serial number: --------------
Coding: 07A18701E085E180EB00
ASAM Dataset: EV_ESPPremiAU57X 004028
ROD: EV_ESPPremiAU57X_004_AU57.rod
VCID: 366390D989477AFA3F-8062
5 Faults Found:
0601 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 155
Mileage: 237813 km
Date: 2021.05.10
Time: 17:21:14
VzRef: 00
Bit Info 1: 00
Bit Info 2: 4F
Bit Info 3: 22
Bit Info 4: 1F
F-Path: 02
F-Type: 0F
Uz: A0
0486 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 9
Reset counter: 155
Mileage: 236094 km
Date: 2021.04.04
Time: 11:35:46
VzRef: 00
Bit Info 1: 00
Bit Info 2: 03
Bit Info 3: 22
Bit Info 4: 1F
F-Path: 02
F-Type: 04
Uz: 9A
0519 - FlexRay Databus
U1031 00 [008] - No Synchronization
Freeze Frame:
Fault Priority: 6
Fault Frequency: 19
Reset counter: 153
Mileage: 236276 km
Date: 2021.04.04
Time: 15:20:30
VzRef: 00
Bit Info 1: 80
Bit Info 2: 40
Bit Info 3: 24
Bit Info 4: 1F
F-Path: 00
F-Type: 69
Uz: BF
0148 - Function Restriction due to Implausible Message(s)
U1112 00 [008] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 155
Mileage: 237816 km
Date: 2021.05.10
Time: 17:50:35
VzRef: 00
Bit Info 1: 00
Bit Info 2: 42
Bit Info 3: 22
Bit Info 4: 1F
F-Path: 02
F-Type: 42
Uz: AA
0834 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 5
Reset counter: 155
Mileage: 237811 km
Date: 2021.05.10
Time: 17:07:19
VzRef: 26
Bit Info 1: 00
Bit Info 2: 40
Bit Info 3: 22
Bit Info 4: 1F
F-Path: 02
F-Type: 22
Uz: B0
Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
Part No SW: 4H0 907 064 BH HW: 4H0 907 064 BH
Component: BCM2 2.0 H31 0333
Revision: 00002001
Coding: 01893006000000000000
Shop #: WSC 02391 785 00200
VCID: 70EF66C1A3A314CA25-8024
2 Faults Found:
01330 - Central Control Module for Central Convenience (J393)
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 6
Fault Frequency: 80
Reset counter: 155
Mileage: 237812 km
Time Indication: 0
Date: 2021.05.10
Time: 17:16:49
00956 - Key 2
002 - Lower Limit Exceeded
Freeze Frame:
Fault Status: 01100010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 98
Mileage: 237347 km
Time Indication: 0
Date: 2021.04.30
Time: 06:07:58
Address 08: Auto HVAC (J255) Labels:* None
Part No SW: 4G0 820 043 J HW: 4G0 820 043 J
Component: KLIMA 4 ZONEN H12 0062
Serial number: 10111100040828
Coding: 3602007820
ASAM Dataset: EV_AirCondiComfoUDS 002033
ROD: EV_AirCondiComfoUDS_002.rod
VCID: 2643409959E70A7A8F-8072
2 Faults Found:
0247 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 17
Reset counter: 155
Mileage: 235461 km
Date: 2021.03.25
Time: 06:02:30
Outside air temperature: 3.5 °C
Engine speed: 1072 /min
Vehicle speed: 46.00 km/h
0330 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 109
Reset counter: 155
Mileage: 235461 km
Date: 2021.03.25
Time: 06:02:29
Voltage terminal 30: 14.11 V
Engine speed: 1155 /min
Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V1.clb
Part No SW: 4H0 907 063 BA HW: 4H0 907 063 A
Component: BCM1 2.0 H12 0100
Revision: 12012002 Serial number: 00000001277602
Coding: 69098011C134AFE08105008000005F5F4F9CE60A2608010100 0008402001
VCID: 68DF0EA19B73DC0A7D-803C
Subsystem 1 - Part No SW: 4G1 955 119 HW: 4G8 955 119 Labels: 1KX-955-119.CLB
Component: WWS57X 111013 H35 0051
Serial number: 111019192207
Coding: 0045F7
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Serial number: 11771281
Coding: 02512B
Subsystem 3 - Part No SW: 4G0 941 531 HW: 4G0 941 531
Component: E1 - LDS H07 0044
Serial number: 02 11 2011 00000483
Subsystem 4 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H02 0002
Serial number: 0128C6D5000000000001
2 Faults Found:
01771 - Control Module for Headlight Range (J431)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 6
Fault Frequency: 1
Reset counter: 208
Mileage: 223663 km
Time Indication: 0
Date: 2020.08.16
Time: 10:09:00
01316 - ABS Control Module
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 6
Fault Frequency: 9
Reset counter: 155
Mileage: 237812 km
Time Indication: 0
Date: 2021.05.10
Time: 17:16:00
Address 10: Park/Steer Assist (J446) Labels:| 4H0-919-475-7X2.clb
Part No SW: 4H0 919 475 L HW: 4H0 919 475 C
Component: PARKHILFE ACC H07 0043
Revision: 11001001 Serial number: 55901131600477
Coding: 090307
ASAM Dataset: EV_EPHVA18AU57X0000 002005
ROD: EV_EPHVA18AU57X0000_002_AU57.rod
VCID: 3B7581EDB265A792C0-806E
1 Fault Found:
12656912 - Databus
U1121 00 [008] - Missing Message
Freeze Frame:
Fault Priority: 6
Fault Frequency: 200
Reset counter: 155
Mileage: 235461 km
Date: 2021.03.25
Time: 06:02:29
Address 15: Airbags (J234) Labels:* 4H0-959-655.clb
Part No SW: 4H0 959 655 C HW: 4H0 959 655 C
Component: Airbag10.43 H40 0040
Revision: -------- Serial number: 003JG005DPRM
Coding: 30323436313330303435554A304C34473053
ASAM Dataset: EV_AirbaAU10BPAAU64X 001014
ROD: EV_AirbaAU10BPAAU64X_VW51.rod
Crash sensor for side airbag: driver side:
Serial number: 3575HRB405H0UJCIG1AZ
Crash sensor for side airbag: front passenger side:
Serial number: 3585HRB405J0U20Q59UY
Crash sensor for side airbag: rear: driver side:
Serial number: 3515JRB405N0TGJIH8GB
Crash sensor for side airbag: rear: passenger side:
Serial number: 3525JRB405V0Q8K6HOHF
Crash sensor for front airbag: driver side:
Serial number: 3554VRB405F0ODISN0KL
Crash sensor for front airbag: front passenger side:
Serial number: 3564VRB40570ODISD8ME
8 Faults Found:
1048832 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 27
Reset counter: 155
Mileage: 235461 km
Date: 2021.03.25
Time: 06:02:30
1049090 - Databus
U1122 00 [008] - Implausible Message
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 155
Mileage: 237814 km
Date: 2021.05.10
Time: 17:24:22
1049088 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 23
Reset counter: 155
Mileage: 235461 km
Date: 2021.03.25
Time: 06:02:27
1049093 - Databus
U1123 00 [008] - Received Error Message
Freeze Frame:
Fault Priority: 6
Fault Frequency: 7
Reset counter: 144
Mileage: 236094 km
Date: 2021.04.04
Time: 11:30:41
1049094 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 7
Reset counter: 144
Mileage: 236094 km
Date: 2021.04.04
Time: 11:30:41
1049095 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 7
Reset counter: 144
Mileage: 236094 km
Date: 2021.04.04
Time: 11:30:41
1049344 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 22
Reset counter: 155
Mileage: 235461 km
Date: 2021.03.25
Time: 06:02:26
1049866 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 5
Reset counter: 155
Mileage: 237812 km
Date: 2021.05.10
Time: 17:16:52
Address 16: Steering wheel (J527) Labels:. 4H0-953-568.clb
Part No SW: 4G0 953 568 A HW: 4G0 953 568 A
Component: Lenks.Modul H05 0201
Revision: 00000000 Serial number: 20111111001121
Coding: 000015
VCID: 306FA6C1632354CA65-8064
Subsystem 1 - Part No SW: 4G0 951 528 D HW: 4G0 951 528 D
Component: E221 - MFL H09 0009
2 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 136
Reset counter: 155
Mileage: 235461 km
Time Indication: 0
Date: 2021.03.25
Time: 06:02:26
02085 - Incorrect Control Module Installed
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 155
Mileage: 237816 km
Time Indication: 0
Date: 2021.05.10
Time: 17:50:34
Freeze Frame:
Voltage: 13.20 V
Hex Value: 0x0000
Speed: 0.0 km/h
Steering Angle: 0.39°
Address 17: Instruments (J285) Labels:. 4H0-920-xxx-17.clb-SRI1
Part No SW: 4G8 920 900 H HW: 4G8 920 900 H
Component: MDieRdw H34 0209
Revision: 25450205 Serial number: 658101111592015
Coding: 13A71000030100080D0000
ASAM Dataset: EV_RBC7KMID 004045
ROD: EV_RBC7KMID.rod
2 Faults Found:
16776968 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 205
Reset counter: 155
Mileage: 235461 km
Date: 2021.03.25
Time: 06:02:27
16776973 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 28
Reset counter: 155
Mileage: 237812 km
Date: 2021.05.10
Time: 17:16:21
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 4G0 907 468 G HW: 4G0 907 468 A
Component: J533--Gateway H08 0214
Revision: -------- Serial number: 00000000303725
Coding: 00CD077D00
ASAM Dataset: EV_GatewUDS 001025
ROD: EV_GatewUDS_AU57.rod
VCID: 3467AAD19F3B68EA01-8060
Battery Monitoring Control Module:
Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
Component: J367-BDM H07 0141
Serial number: 00000000003790949226
Voltage stabilizer:
Subsystem 2 - Part No SW: 8K0 959 663 HW: 8K0 959 663
Component: J532_DCDCStab H17 0042
Serial number: 11314000131021200181
2 Faults Found:
4224 - No Communication with Engine Control Module (SAE ECM/PCM)
U0100 00 [008] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 153
Mileage: 237752 km
Date: 2021.05.08
Time: 20:09:48
Voltage terminal 30: 12.4 V
Voltage terminal 15: 0.0 V
Control Module temperature: 17 °C
System status: Awake_Timer_active
IN ESP_standstill flag: no standstill detected
Engine running: OFF
IN ZAS_Te_X: OFF
Terminal 15 status via CAN: OFF
Terminal 15 status: OFF
Datenfeld: 0
4352 - ABS Control Module on FlexRay Data Bus
U10BD 00 [008] - No Communication
Freeze Frame:
Fault Priority: 2
Fault Frequency: 217
Reset counter: 155
Mileage: 235461 km
Date: 2021.03.25
Time: 06:02:29
Voltage terminal 30: 14.4 V
Voltage terminal 15: 14.4 V
Control Module temperature: 10 °C
System status: Terminal 15 on
Engine running: On
IN ZAS_Te_X: On
Terminal 15 status via CAN: On
Terminal 15 status: On
Datenfeld: 0
Address 28: HVAC, Rear (E265) Labels:* 4G0-919-158.clb
Part No SW: 4G0 919 158 C HW: 4G0 919 158 C
Component: KLIMA FOND H07 0062
Serial number: 12111100040879
Coding: 00
ASAM Dataset: EV_ClimaContrUnitRearUDS 002015
ROD: EV_ClimaContrUnitRearUDS_002.rod
1 Fault Found:
0136 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Reset counter: 155
Mileage: 235461 km
Date: 2021.03.25
Time: 06:02:29
Voltage terminal 30: 14.19 V
Address 30: Special Function II (J843) Labels: 8K0-907-440.clb
Part No SW: 4H0 907 440 HW: 4H0 907 440
Component: STS H06 0030
Revision: S0H06000 Serial number: 00000000022313
Coding: 01010101000000000001000203
VCID: 64C71A91675BB86A51-8030
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 155
Mileage: 237812 km
Time Indication: 0
Date: 2021.05.10
Time: 17:18:13
Address 3B: Sensor Elect. (J849) Labels: 4G0-907-637.clb
Part No SW: 4G0 907 637 B HW: 4G0 907 637 B
Component: SARA 6D H02 0004
Revision: -------- Serial number: EJ1BPA4202PJJM0
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_SARA 006014
ROD: EV_SARA_006.rod
VCID: 2D51BFB57C1139224E-8078
1 Fault Found:
3801346 - Function Restricted due to Missing Message(s)
U1111 00 [044] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 238
Reset counter: 155
Mileage: 235461 km
Date: 2021.03.25
Time: 06:02:29
DCU Temperature: 12 °C
Voltage Clamp 15: 14.6 V
Voltage Clamp 30: 14.1 V
Ignition Cycle Count: 41007
WAUZZZ4G0CN085614
Address 42: Door Elect, Driver (J386) Labels: None
Part No SW: 4G8 959 793 E HW: 4G8 959 793 A
Component: TSG FA H05 0212
Coding: 011C17204020628002080002
Shop #: WSC 02312 785 00200
VCID: 428BFC09DD8FD65A83-8016
2 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 15
Reset counter: 155
Mileage: 237812 km
Time Indication: 0
Date: 2021.05.10
Time: 17:18:57
00109 - Left Mirror Turn Signal Lamp (L131)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 3
Fault Frequency: 122
Reset counter: 154
Mileage: 234188 km
Time Indication: 0
Date: 2021.02.26
Time: 16:30:59
Address 44: Steering Assist (J500) Labels:| 4G0-909-144.clb
Part No SW: 4G0 909 144 L HW: 4G0 909 144 G
Component: RCEPS H35 0010
Revision: 00001000 Serial number: 0029216362
Coding: 101000010000
ASAM Dataset: EV_RCEPS 009008
ROD: EV_RCEPS_009.rod
VCID: 326BACC9652F66DA13-8066
1 Fault Found:
3158273 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 193
Reset counter: 155
Mileage: 235461 km
Date: 2021.03.25
Time: 06:02:30
Write only channel
Address 46: Central Conv. (J393) Labels:. 4H0-907-064-46.clb
Revision: 00002001 Serial number: 0163066045
Coding: 013E063820B93C008320090428010400000000000000000000 0000000000
Subsystem 1 - Part No: 4G0 951 177
Component: DWA-Sensor H01 0010
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
4 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 80
Reset counter: 155
Mileage: 237812 km
Time Indication: 0
Date: 2021.05.10
Time: 17:16:49
02616 - Fuel Tank Cap; Unlock
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 2
Fault Frequency: 15
Reset counter: 7
Mileage: 223920 km
Time Indication: 0
Date: 2020.08.16
Time: 16:42:39
02615 - Fuel Tank Cap; Lock
Freeze Frame:
Fault Priority: 2
Fault Frequency: 7
Reset counter: 5
Mileage: 224017 km
Time Indication: 0
Date: 2020.08.19
Time: 07:04:50
02739 - Bulb for Tail/Brake Light; Right
012 - Electrical Fault in Circuit - MIL ON
Freeze Frame:
Fault Status: 11101100
Fault Priority: 2
Fault Frequency: 2
Reset counter: 88
Mileage: 237071 km
Time Indication: 0
Date: 2021.04.25
Time: 08:19:38
Address 52: Door Elect, Pass. (J387) Labels: None
Part No SW: 4G8 959 792 E HW: 4G8 959 792 A
Component: TSG BF H05 0212
Coding: 011C17204C20628002080002
VCID: 4189F305D889CD429A-8014
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 15
Reset counter: 155
Mileage: 237812 km
Time Indication: 0
Date: 2021.05.10
Time: 17:18:57
Address 53: Parking Brake (----) Labels: 4H0-907-801.clb
Part No SW: 4H0 907 801 E HW: 4H0 907 801 A
Component: EPB-4 H03 0012
Revision: -------- Serial number: 00000000184111
ASAM Dataset: EV_ParkiBrake 001022
ROD: EV_ParkiBrake_VW51.rod
VCID: 2A5BB4A94DFF2E1AAB-807E
7 Faults Found:
328448 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 191
Reset counter: 155
Mileage: 236276 km
Date: 2021.04.04
Time: 15:20:30
Voltage terminal 30: 14.9 V
Internal Fault ID: 89
Network management state: normal
Function light in parking brake button: OFF
Red operating lamp: OFF
Red warning lamp: OFF
Green operating lamp: OFF
Yellow warning lamp: OFF
RWU: not active
DSD: not active
HTR: not active
ECD: not active
ACC requested apply: not active
Auto Adjust: not active
General Inspection Function: not active
Internal Parking Brake state: static
Status of parking brake button: Not operated
Status ParkingBrake left: Open
Status ParkingBrake right: Open
328704 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 194
Reset counter: 155
Mileage: 236276 km
Date: 2021.04.04
Time: 15:21:22
Voltage terminal 30: 15.0 V
Internal Fault ID: 90
Vehicle speed: 4 km/h
Yellow warning lamp: On
RWU: not active
DSD: not active
HTR: not active
ECD: not active
328960 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 185
Reset counter: 155
Mileage: 236276 km
Date: 2021.04.04
Time: 15:21:22
Internal Fault ID: 91
RWU: not active
DSD: not active
HTR: not active
ECD: not active
329216 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 199
Reset counter: 155
Mileage: 236276 km
Date: 2021.04.04
Time: 15:20:30
Internal Fault ID: 92
RWU: not active
DSD: not active
HTR: not active
ECD: not active
396800 - Function Restriction due to Implausible Message(s)
U1112 00 [008] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 155
Mileage: 237814 km
Date: 2021.05.10
Time: 17:24:22
Internal Fault ID: 115
Vehicle speed: 50 km/h
RWU: not active
DSD: not active
HTR: not active
ECD: not active
459264 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 6
Reset counter: 144
Mileage: 236276 km
Date: 2021.04.04
Time: 15:20:30
Internal Fault ID: 138
Vehicle speed: 510 km/h
RWU: not active
DSD: not active
HTR: not active
ECD: not active
Internal Parking Brake state: Emergency running mode
463616 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 6
Reset counter: 144
Mileage: 236276 km
Date: 2021.04.04
Time: 15:20:30
Internal Fault ID: 185
RWU: not active
DSD: not active
HTR: not active
ECD: not active
Address 5F: Information Electr. (J794) Labels: None
Part No SW: 4G0 035 193 D HW: 4G0 035 193 D
Component: RMC Cnct Nav H52 0761
Coding: 0100010001415B47403B060301010000000000
VCID: 24475A9127DBF86A91-8070
Subsystem 1 - Part No: 8X0 919 884 D
Component: P13-50-11.06 0002
Subsystem 2 - Part No SW: 4G0 919 603 HW: 4G0 919 603
Component: DU6 Basic H42 0084
Serial number: 9464JZ0B0068902
Subsystem 3 - Part No SW: 4G1 919 610 B HW: 4G1 919 610 B
Component: E380 BDT C7 H11 0204
Serial number: 90349KK8000IJ
3 Faults Found:
00862 - Antenna for GPS Navigation (R50/R52)
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 4
Fault Frequency: 24
Reset counter: 121
Mileage: 223663 km
Time Indication: 0
Date: 2020.08.16
Time: 10:11:28
03157 - Functionality limited due to Communications Disruption
Freeze Frame:
Fault Priority: 6
Fault Frequency: 5
Reset counter: 155
Mileage: 237816 km
Time Indication: 0
Date: 2021.05.10
Time: 17:50:34
Freeze Frame:
Bin. Bits: 00000000 10000000
Bin. Bits: 00000000 00000000
03278 - Functionality Limited due to Missing Messages
Freeze Frame:
Fault Priority: 6
Fault Frequency: 149
Reset counter: 155
Mileage: 237816 km
Time Indication: 0
Date: 2021.05.10
Time: 17:53:29
Freeze Frame:
Bin. Bits: 00001101 00000000
Address 62: Door, Rear Left (J388) Labels: None
Part No SW: 4G8 959 795 E HW: 4G8 959 795 A
Component: TSG HL H04 0212
Coding: 010815204020628002080002
VCID: 4487FA11C79BD86AB1-8010
No fault code found.
Address 69: Trailer (J345) Labels:. 4G8-907-383-V1.clb
Part No SW: 4G8 907 383 HW: 4G8 907 383
Component: Towbar module H07 0100
Coding: 0109080000000000
VCID: 71E963C5A8A91DC22A-8024
Address 6D: Trunk Elect. (----) Labels:* Redir Fail!
Part No SW: 4G9 959 107 A HW: 4G9 959 107 A
Component: HDSG-Modul H03 0139
Revision: 14003001 Serial number: 310100158
Coding: 097205C011
ASAM Dataset: EV_HDSGAu572 001001
ROD: EV_HDSGAu571.rod
1 Fault Found:
0044 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 3
Fault Frequency: 19
Reset counter: 155
Mileage: 237812 km
Date: 2021.05.10
Time: 17:18:56
Voltage terminal 30: 14.45 V
Address 72: Door, Rear Right (J389) Labels: None
Component: TSG HR H04 0212
Address 8F: Pretens. Frt Left (J854) Labels: 4H0-980-94x-RGS.clb
Part No SW: 4H0 980 945 B HW: 4H0 980 945 B
Component: RGS-VL H13 0080
Coding: 00060000031F030000030801424CDA010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
VCID: 3169A3C560295DC26A-8064
6 Faults Found:
12583684 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 201
Reset counter: 155
Mileage: 235461 km
Date: 2021.03.25
Time: 06:02:30
12583686 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Reset counter: 155
Mileage: 235461 km
Date: 2021.03.25
Time: 06:02:25
12583687 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 210
Reset counter: 155
Mileage: 235461 km
Date: 2021.03.25
Time: 06:02:27
12583949 - Function Restriction due to Implausible Message(s)
U1112 00 [008] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 196
Reset counter: 155
Mileage: 237811 km
Date: 2021.05.10
Time: 17:06:59
12583955 - Function Restriction due to Implausible Message(s)
U1112 00 [008] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 254
Reset counter: 155
Mileage: 235461 km
Date: 2021.03.25
Time: 06:02:22
12583958 - Function Restriction due to Implausible Message(s)
U1112 00 [008] - -
Freeze Frame:
Fault Priority: 2
Reset counter: 155
Mileage: 235461 km
Date: 2021.03.25
Time: 06:02:23
Address 90: Pretens. Frt Right (J855) Labels: 4H0-980-94x-RGS.clb
Part No SW: 4H0 980 946 B HW: 4H0 980 946 B
Component: RGS-VR H13 0080
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
6 Faults Found:
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Reset counter: 155
Mileage: 235461 km
Date: 2021.03.25
Time: 06:02:30
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Reset counter: 155
Mileage: 235461 km
Date: 2021.03.25
Time: 06:02:26
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Reset counter: 155
Mileage: 235461 km
Date: 2021.03.25
Time: 06:02:27
U1112 00 [008] - -
Freeze Frame:
Fault Priority: 2
Reset counter: 155
Mileage: 237811 km
Date: 2021.05.10
Time: 17:06:59
U1112 00 [008] - -
Freeze Frame:
Fault Priority: 2
Reset counter: 155
Mileage: 235461 km
Date: 2021.03.25
Time: 06:02:22
U1112 00 [008] - -
Freeze Frame:
Fault Priority: 2
Reset counter: 155
Mileage: 235461 km
Date: 2021.03.25
Time: 06:02:23
End-------------------------(Elapsed Time: 05:22)--------------------------
Old May 17, 2021 | 03:39 PM
mdkv5's Avatar
If I were to guess:
Internet says: "Y
ou have problem with flexray wiring from gateway to abs unit. common failure."
Also: https://forums.ross-tech.com/index.php?threads/19809/
ShowMeData
Audi allroad
Sep 4, 2008 05:14 PM
A8thegreat
May 11, 2008 02:41 PM
Greg PAW - MS
12v V6 Discussion
May 11, 2004 06:15 AM
brierfr
VAG-COM Discussion
Mar 23, 2003 12:22 PM
Jason H
Aug 11, 1999 06:58 AM
