- 3.0 quattro extremely high fuel consumption
- Solve brake light error, and maybe change to led bulbs in rear
- 2004 A4 Convertible Top Inoperative
- Manually Closing roof (with opener tool) "drop" sound in trunk
- 2004 A4 B6 Cabrio - Power headrest removal and seat cover recommendations
- Audi 2005 A4 Quattro Cabriolet tonneau cover wont unlock with red key!
- D3S LEDs - brighter than xenon - cleaner white - instant on - no errors
- 2005 A4 1.8T needs tranny - now for sale
- 08 A4 Quattro 2.0 carbo coolant hose broke.
- No crank no start
- Sealing Cylinder Heads on a 3.0
- 2004 1.4 cabriolet turbo coolant line leak behind the engine.
- alignment tool
- Audi A4 B6 cabriolet subframe.
- 2008 convertible
- A4 3.0 oil type
- 2009 A4 convertible 02000 switch position
- Switch out Nav system
- Water Pipe Plug/vent?
- Is it Brilliant Red or Brilliant Pink?!?!?
- For Audi A4 S4 RS4 2008-2018
- Where is Purge Valve?
- Fit Audi MMI 2G A4 A5 A6 A7 A8 Q5 Q7 2005-2010
- Leaks leaks leaks
- Audi A4 2.0 TDI cabriolet
- Drive cycle
- I hate the smell of napalm in the evening
- UK: Heating?
- B6 CABRIO ROOF WIRING HARNESS
- Standard Delay in putting top up and down??
- SA: help me for this car?
- Can a 2006 B6 A4 Cab/Auto AMB motor replace a toast 2004 B6 A4 AMB 6MT motor?
- A4 b6 won't crank
- Full electric seat problem A4 B6 Cabriolet
- Audi A4 Convertible top replacement
- What even is this - undercarriage of A4 2022
- 2004 Audi A4 B6 cabriolet fender size and fitment
- Loosing coolant
- Audi A4 2004 cabriolet heater question
- What is this piece of hardware
- 2009 Audi Cabriolet 2.0
- Tie Rod stuck, 2003 Audi A4 Cabriolet 3L-V6
- Engine Mounts, New Busgings, Brake hose $4500?
- Blew a tire and took out a plastic hose
- UK: Can't find a ballast igniter cable. Can someone help me please?
- 2002 A4 engine noise?
- RF interfers with AC pressure readings
- Key Stuck
- Parking sensors stopped working
- 2003 A4 v6 low miles ...park/nuetral relay buz?
- UK: Audi A4 Convertible B7 2006, 3.0TDI Comfort Control Module
- 2007 A-4 Quattro Cabriolet
- 2004 A4 Cabritolet 3.0
- Hood won’t lock when closing
- 20% off our bright D1S / D2S / D3S LEDs! These are brighter than xenon bulbs!
- condensation in headlight
- No supera las 400rpm
- B6 Cabrio roof leak
- Thinking about buying and Audi
- Power seat connection
- roof wont open fully! gets 99 percent of the way
- Leaking rear window
- Comfort module replacement
- getAudiparts.com | Black Friday/Cyber Monday '23 Savings are Live!!!
- BLACK FRIDAY SALE,, SuperSprint Italy
- BLACK FRIDAY SALE / CYBER MONDAY ON NOW @ deAutoLED.com – bright error free LEDs
- B7 convertible taillights on a B6 convertible
- 2005 A4 B6 Cabrio Hood Release is broken
- Help emergency timing belt question
- HELP - A4 b6 wrong paint code
- 09 A4 power roof opens but won't close automatically
- 08 A4 3.2 cabriolet throws 7 low circuit cel codes
- Headlight Assembly
- Drivers seat not moving forward or back
- 09 A4 Cab driver side rear window down and dead
- CONVERTIBLE ROOF HYDRAULIC PUMP REPLACEMENT
- Greetings from SuperSprint Italy
- CONVERTIBLE ROOF HOSE #34
- Help .
- Audi A4 2004 convertible roof opens all the way but gets jammed
- Just had transmission rebuilt and now the car dies when it heats up
- 2006 A4 B6 headlights
- Front Suspension 2005 A4 cabriolet
- Leak
- convertible top issue
- 2006 audi a4 2.0 quattro will not start
- 2005 3.o
- UK: No Boot Release
- 2006 A4 Cab xenon vs bi xenon vs LED? Looking for advice.
- Timing Belt Dilemma - teeth stripped
- Please help, rev no acceleration, ran over parking block?
- 2006 A4 Cab Battery drain from Radio fuse
- New Cab Owner has a few questions
- 03 A4 1.8t go's into gear won't move
- 20% off NEW D3S/D1S LEDs FOR 2023 –Bright - NO ERRORS - PLUG & PLAY - NO wires!
- CCM Problems
- Seat belt warning enable
- Black Friday // Cyber Monday Sales on now – Bright error free LEDs @ the best prices!
- 2004 Cabriolet Dashboard Storage replacement
- 2003 Soft Top Issue
- Ecm coding chart.
- Warning light not listed in the manual
- A4 SVC can't diagniose my issue help?
- Unusual Ignition Switch Issue
- CEL P0299
- Passenger Window drop not working
- UK: my new car has 'spare parts' in the boot
- A4 Cabriolet Convertible Top Tensioner Cable
- Convertible top wont go down all the way.
- Need guidance on 2004 Audi A4 Cabriolet 3.0
- 2005 Audi S4 (4.2l) O-ring changed on fuel pump; now won't crank/ turn over; Starter?
- Front Rotor Size for Cabriolet? - 2005
- B6 interior in to B7 model
- cabrio trunk lid cracked - 2nd try
- Cabrio trunk lid cracked
- Solenoide connector
- Windscreen reservoir.
- Engine replacement
- Can someone help diagnose these videos? Maybe bad CV axle and other
- oil cooler location
- Rear tail light assembly attachment nubs
- Brake Assist (vacuum pump) Eliminated?
- Roof not responding at all
- "New" 2005 A4Q 3.0 Cab - upgrade int light; stereo BT/camera; humming noise FR speakr
- High pressure fuel pump bad?
- Turbo cuts out on motorway
- Getting Ready to Change Timing Belt - Question on Preferred Way to Gain Access
- Audi A$ B6 AC compressor plate: help
- 2004 A4 Cabriolet - 3.0 Opinion
- Steering failure on full lock when stationary
- Door open/close sensors
- Can you help me diagnose this issue please?
- Audi A4 cabriolet 2.5 litre v6 coolant and roof issue
- Speedometer not worting
- Fuel Door Light troubleshooting
- UK: E10 petrol?
- Key fob help
- replaced CCM
- 2005 A4 Cabriolet Comfort Control Module woes
- I am CONFUSED
- A4 2006 cabriolet
- Need help. BAD.
- a3 audi 2006
- Airbag light nightmare
- Outside of Transmission but inside of CV joint
- 2004 Audi A4 3.0
- Central convenience module issues?
- Pinout for power seat connector?
- A4 B6 CABRIOLET RADIO AMPLIFIER LOCATION
- Is Bluetooth Module Necessary?
- Slow closing deck lid
- Wings
- UK: Automatic transmission issue
- Roof error 01922 - F293 - help please
- Dash lights on
- Engine lights after timing belt kit fitted
- Can anyone tell me about this port under the Armrest
- Headliner
- part number help please
- OBD fuse location needed
- getAudiparts.com | Last Minute Holiday Savings Promo Code: HOLIDAY2020
- keyfobs not working
- UK: 3.0L petrol crank sensor location?
- A4 B6 Cabriolet No Acceleration when engine is revved
- deAutoLED Black Friday and Cyber Monday sales are LIVE NOW! Best prices of the year!!
- Audi A4 B6 3.0 Cabriolet
- Is Audi 8E0035192E a double din model
- Soft top not operational
- Audi convertable roof and windows not working
- A loud, metallic bang and I have a snapped bolt
- Where to find replacements
- Source for 2008 Cab Rear Glass
- 2006 Audi a4 quattro automatic transmission/shifter issue
- Need Advice: 08 A4 3.0 Cab Potential Purchase
- Coolant leak
- Factory cell phone
- Flashers come on when I start car
- A few issues. Help please
- Passenger seat all the way forward Help
- Is it the Passenger door wiring or body control module?
- Check Engine Lite after loose gas cap
- Cars jerking after replaced mass airflow sensor
- Odometer
- CarPlay
- 2008 A4 stereo upgrade
- 2008 A4 Cab
- Passenger seat wiring 04 a4 3.0 avk
- 2004 A4 Cabriolet with flashing PRNDS
- Reliability issues with 2005 A4 1.8T?
- UK: boot issue
- 2009 A4 cabrio 3.2l with known issues
- Audi A4 2.4 v6
- UK: YK53LCP anyone know where this car is?
- UK: 2004 Audi A4 1.8T Automatic
- Help with missing footwell light
- Battery dies when trunk is open
- Locked cams?
- Incorrect Gear Ratio code on 2005 quattro 3.0L A4 Cabrio
- 2004 a4 taillight
- 2008 A4 Cabriolet Trunk Wont Open
- 07 A4 cabriolet trunk and top
- SSR AUTOBODY ♖ | SoCal's #1 Source for Quality European Collision Repair!
- Door panel A4 Cabrio
- 2003 A4 Cabriolet 3.0 PRND Flashing
- 2004 A4 convertible
- Trunk and top
- Reversing light odd problem
- Problem with pump for folding roof?
- MYSTERY- Anti Roll Bars Activated
- Audi A4 cabriolet
- 2004 Audi A4 1.8t Dashboard not powering up (No Lights)
- very amateur mechanic with a top problem
- 2006 a4 quattro 3.0 cabriolet no power windows top light under glove box flashes
- A4 2003 v6 - Engine Light code P0171 and P0174
- getAudiparts.com | Black Friday/Cyber Monday FREE SHIPPING + Promo Code!!!
- Trouble with 2004 A4 Audi Quattro Steering Wheel
- Please Help! This can't be right!
- Please HELP 2005 Audi A4 1.8t fwd convertible
- What platforms are my convertibles?
- Replacing window regulator motor??
- Looking for Tampa Fl Audi shop...not dealership
- SWAP to Quattro ?
- Immobilizer, Cluster, CANBUS problems -> No Start
- On going problem
- air suspension
- 2009 A4 quattro, Cab. S Line.
- New headlight adjustment
- Car misfires while braking which kills battery
- 2005 A4 Mystery Overheating
- Cabrio Bumper Question
- b6 a4 cabrio rear door trim removal
- How to sound from ipad to car audio. Synced but no sound.
- B6 Cabriolet roof operates with door key, but not with roof switch
- 2006 a4 cabriolet 1.8T dashboard computer fail
- Possible speed control sensor?
- Airbag light won’t clear
- Grille Options
- Reverse light switch
- Rebuilt A4 1.8t still having issues
- 2009 a4 cab 2.0 throwing random codes after hard start
- Passenger seat won't move
- Puff of White smoke, After ideling! ??? 1.8T
- Econ mode stuck - G65 sensor are changed
- DASH TRIM REMOVAL - 2004 A4 B6 Cabriolet
- Neep help with Audi convertible, buying used.
- No roof signal at check up
- Vacume line disconnected
