- 2008 Audi A4 convertible comfort control module replacement
- Follow up to Trouble Shoot Roof post
- Passenger seat switch
- Driver side low beam HID won’t work while everything else does?
- Troubl shoot roof
- New Car/Major problem!
- Audi A4 Concert CD Changer wiring colours?
- Cabrio roof sitting uneven
- Top only works when windows down
- Advice needed please
- 2008 Audi A4 turn key and nothing
- Looking at a 2007 3.2L Quattro
- Wiring Schematic needed.
- audi a4 1.8t
- 2004 A4 codes 18185 18256 16891
- Fuel Gauge Malfunction
- jerk when coming to a stop
- Interior Parts?
- Took out cluster Now no start
- Audi A4 Cabriolet - Roof Problem
- Tiptronic transmission faults
- Key fob programming failure
- i currently have error code P0011 on my automatic 2L
- roof problem
- INTRO PRICE / Group Buy: *NEW* LED Fog technology: 1 LED 4 modes: WHITE/YELLOW/STROBE
- 2003 AUDI A4 1.8L CAB TURBO
- A4 b6 cabriolet heated seats
- 2004 A4 soft top remote control
- A4 B6 3.0 V6 Cabriolet Bank 1 misfire
- How do I squeeze 300 hp from my cabriolet?
- Fuel Pressure Sensor (Low Pressure) location
- Bad trans?
- No Compression Cylinder 2 Yikes
- miss firing
- getAudiparts.com | Genuine Audi Collection Key Rings!
- Help! Extremely difficult to shift gears while car is moving
- 1995 Audi Cabriolet- crank over but not start
- Best cleaner / recover/ proofer
- Can i manually change my bluetooth output from phone calls only to all audio output
- B6 to B7 taillights. What codes do I need to change in VAGCOM?
- Code 501 VSS, help
- No power, only iddle 3.0
- Part missing - don't know what it is!?!
- New Product Launch Blue, red or clean bright white FOOTWELL LEDs for all AUDI Models!
- AUDI A5 CABRIOLET SOFT TOP ROOF CATCH - 8F0 825 823 C- Help!
- leaking convertible pump
- A4 manuals needed
- How to manually put down the top 1995 Cabriolet
- 3.0 tdi engine torx and sequencing
- Headlights on all the time
- Exhaust
- s4 cabrio soft top repair
- Left side fan inop...implications?
- Aerial boosters replacing
- Headlight compatibility
- Convertablee Top won't lock.
- Need help... upper front window/roof weatherstrip
- Roof pump gets no power.
- richiej
- Help Please Part Identification 2004 Audi A4 Cabriolet
- ***WannabeRacer.com | Norcal/Bay Area Vinyl Wrapping Tour - July 30th - Aug 3rd 2018*
- Wheel alignment tolerances
- Top Leaking - 2006 A4 Cabrio 1.8T S-Line
- Calling out to people with lowered cars!
- Newbie Oil pressure / Cam-coil codes HELP?
- A4 B6 1.8T cranks but no start
- B6 All Weather Rubber Floor Mat Sets for Under $60 shipped!
- Custom headlights?
- 2004 Audi dealer can’t program key
- Main beam and fog lights not working
- 2003 Engine vibration under accelleration
- 2004 Driver seat stuck all the way forward.
- Brighter D1s/2s/3s Xenon Bulbs | Front Turns | Error Free Reverse LEDs
- Hydraulic strut for roof replacment
- Audi A4 Cabrio tire replacement
- Which Wiper Blades for 2009 A4 Quattro Cabriolet?
- Audi A4 convertable roof problem
- getAudiparts.com | Genuine OEM Audi Parts + FREE SHIPPING on Most Orders $299+!!!
- Headrest ,front how to move up and down???
- Sattelite Radio wont update.
- dome lights gone after windshield change
- soft top issue
- 2007 A4 Cabroiolet soft top is stuck
- Technical Tips for A4 (B6 Platform) 2002-2006
- Audi Over heating and blowing cold air
- 03 Audi Soft Top Functions Properly But Still Has"Soft Top Not Secured" Error Light
- A4 B6 2.4 V6 transmission conversion to manual trans
- Recommended Oil Change Interval Revealed
- 2003 A4 Cab B6 3.0L FWD Timing belt or chain?
- Driver seat fwd/ back inop
- Burned oil smell
- New Around Here
- 2009 a4 cabriolet battery keeps dying
- hood / roof switch replacement
- Scraping-like noise
- Roof not working after battery replacement
- access to fuel door actuator HELP
- Footwell lights not working
- Interior door trim
- A4 2003 cabrio belt tensioner install
- Headlight Issue
- Got the timing belt successfully changed
- Concert radio dead after battery change
- aftermarket headlights
- 2006 Audi A4 top will not finish opening
- Remove/Replace Entire Convertible Top
- '06 w/3.0L runs very rough/choppy when cold
- Strange Rear Bulb Warning Light
- Roof doesnt any lift
- The usual no heat issue
- Roof deck won't lock
- How to replace the alternator
- Oil Pan Bolts
- ***WannabeRacer.com | Boston and New Jersey Vinyl Wrapping Tour***
- Heat into UK driver side foot well
- No power to roof
- p0025 trouble code help!!!!!
- Trunk roof (storage) box won't retract
- Need to replace CCM in '05 A4 Convertible
- :: ECS Tuning :: SALE! Save up to 20% on ECS oil change kits | Ends 08/27/2017
- assistance
- Car won't start - related to problems with the roof?
- license delete plate
- Rear deck lid won't close!
- Clutch judder and hard clutch release with power on.
- 12 Volt Power for Ham Radio
- 2006 A4, 3.0L top lite blinks 3 times
- ***Don Nguyen | Norcal / Bay Area Vinyl Wrapping Tour - Aug 28th - Sept 4th, 2017***
- Exhaust
- Intermittent air conditioning problem
- 2003 2.5 TDI Motor Mount Parts Breakdown
- Wet CCM. Question about model numbers
- Defect in Audi convertible top motor replacement?
- 1995 audi rear side widows window click
- Hi Hope someone can help with Installing replacement alternator A4 B6 3.0 cabriolet !
- Brake Pad Rattle
- 2:00h warning on the miles to empty
- 2009 A4 cabrio trunk wont open
- Protect rear window separation
- Can halogen the headlight housing be modified for xenon?
- DRL Question
- LHD HEADLIGHTS
- P/M on top operation
- Replacing Memory seat switch 05 Cabriolet?
- Rear tail light assembly attachment nubs
- '04 Audi A4 3.0 Soft Top won't secure
- 2006 A4 tiptronic not working
- Auto transmission fluid too full?
- my Con Top
- Drivetrain noise?
- 255/35/19 or 235/35/19?
- rear latch will not dis-engage.
- Power seat height Adjust is stuck in highest (rear) position
- inner roof bungies..
- 1000 RPM ( High Idle?) ON DRIVE Audi A4 1.8T
- micro switch
- Need buyer tips for 2009 Audi A4 Cabriolet
- Convertible top
- Lurching@ low RPMs '03 Cab 3.0
- transmission mount center bolt
- Soft Top Manual Unlock Hole Cover
- Power seat height adjustment???
- cutting out
- '06 A4 Cabriolet CCM Replacement
- Convertible Hood Replacement
- Sounds like rolling marbles in my car????
- Rallycross A4 Build
- Paint code help
- A4 1.8 Transmission gone
- 2004 Audi A4 Cab Help me save over $1,000 on a ballast!!
- Explaining the different series and styles
- 2007 audi a4 convertible wiper blades
- Bananas!
- Ill Pay for your beer/coffee HELP
- audi
- Clutch and dual flymass wheel replacement
- Need part number for 2006 S4 c
- 08 Audi Cabriolet Seat removal issues
- 2005 A4 convertible top problems
- 2005 2.5 TDi A4 S-Line Cabriolet - Faulty MMI
- Power steering
- Leaking Light On Trunk
- Beeping, parts of electrical system inop, key fob not working
- Coolant question.... '06 w/3.0L
- NEW D1s/2s/3s Xenon Bulbs | Front Turns | Error Free Reverse LEDs | Interior LEDs!
- 1998 Audi Cabriolet 2.8L V6
- ***Don Nguyen | Norcal / Bay Area Vinyl Wrapping Tour - January 1st - 7th, 2017***
- A4 Cabriolet cover, luggage and wind screen
- Major Electrical issues no cl; no windows etc
- !AUDI ONLINE PARTS WINTER RAFFLE!
- Help with replacing shifter lever assembly
- WHAT DO YOU WANT TO SEE FROM A PARTS DEALER?
- Remove soft top storage box
- 2008 Radiator Condenser Cooling Fan Replacement
- Recommendation for a Convertible Top Place
- Help need to fix my glove box
- Cast Aluminum Coolant Flange
- Top Speed
- SportShifters.com - SportShifter now available for your B6 manual!
- 2006 A4 Cabriolet Top Doesn't do anything light flashes
- A4 2008 Soft top
- !NEW AUDIWORLD EXCLUSIVE PROMO!
- Cab roof box in the trunk - does not close!
- Glove Box Lid Question
- Audi Concert wiring
- Convertible Top Box in Ceiling of Trunk - How to Repair?
- Convertible glass coming loose.
- DYI-Picking Correct A/C Recharge Can for the Compressor
- What's with getting a new key??
- 04 A4 Cabriolet convertible top motor wiring diagram
- 2009 A4 Cabriolet Center Armrest Connector?
- How to connect iPhone 6 to A4 AMI with Nav
- BIRTHDAY SALE!
- Audi 3 litre 2003 misfire pulling codes P0300 P0302 P0305 p0306
- Generator light
- Summer Start MEGASALE!
- A4 Won't Start
- front hub bearing ssy replacement
- What to look for / Avoid in buying used A4? Good choice for winter in Canada?
- Coolant loss problem
- Convertible top Reset
- Audi A4 Cabriolet B6 Crash ECU location (warning light issue)
- 06A4Cab drivers underseat storage? & Sliding rear trim cover?
- coolant Flange/ heater core supply hose leak
- Engine swap
- Airbag Seat Connector
- 2004 A4 Cabriolet - 3.0 Opinion
- 2007 A4 2.0 Turbo Oil Leak Need Help
- Did I get lied to at my dealer?
- Hazard lights come on unexpectedly
- Compatability between B6 A4 cab and VW Eos?
- Hood latch sensor light
- Debris in engine
- FREE AutoPreme Floor Mats!?
- Audi Concert
- ***Don Nguyen | WannabeRacer.com | Vehicle Wrap - Tint - Plastidip - Custom Decals***
- Engine swap Audi 2004 A4 Cabriolet Quattro 3.0L
- Just replaced Rotors & Pads - A4 1.8T Cabriolet
- intercooler
- Convertible top hoses
- Remove the boot lock
- Audi- A4- locksmith help?
- Maaco Opinion/Paint Shop
- Soft top window separation
- Trunk/boot latch opening issues
- 1994 Audi no spark
- LEDS! Reverse, Interior, License Plate - Free Shipping/Lifetime Warranty/Error Free
- Oil Change on 2.0 Liter turbo.
- Remove dash speakers
