How many volts should a fully charged battery read?
Old Aug 22, 2001 | 05:17 AM
jdulac's Avatar
New Member
Default How many volts should a fully charged battery read?
Is 12.14 low?
Old Aug 22, 2001 | 05:18 AM
HDClown's Avatar
no, car batteries are 12v, they usually run 14v when the car is moving
Old Aug 22, 2001 | 05:28 AM
Perpetual Novice's Avatar
Mine reads 12.6 with the engine and all accessories off.
Old Aug 22, 2001 | 05:35 AM
Lone Starr (Ivan)'s Avatar
Elder Member
Default To answer your question, no. Your alternator should put out between 13 and 14 volts
and your battery should be right around 12 volts fully charged.
Why do you ask are you having a problem?
Old Aug 22, 2001 | 05:41 AM
a4not's Avatar
New Member
Default Alternators put out 14.4 Volts AC. The voltage regulator converts that to 12 volts DC. The ...
chopped off portion of the wave is the noise that shows up in cheap stereo amp installs.
Old Aug 22, 2001 | 06:01 AM
Mark P's Avatar
AudiWorld Expert
Tech Guru
Default what voltage regulator? Battery charges to 12V, Alternator generates 14.4V...
If you test the voltage in the car when the car is running (ie when alternator is generating power), you will test ~14.4V. There is no voltage regulator that brings this down to 12V at a high level. (<- Hmm, that may be inaccurate) Perhaps individual devices bring it down, but they probably bring it down to 5V. Amps tend to use the full voltage (while adding capacitance to stabilize the voltage), as you'll see most are spec'd out at creating more power at 14.4V than at 12V. If they had a voltage regulator to bring it down to 12V everytime, this 14.4V power increase wouldn't be possible. So, at the battery, there is 14.4V when the alternator is supplying power.
eMKay (BFLO)'s Avatar
AudiWorld Uber User
Default That's fine, a little above 12 is good with the engine off...
A little below (11.2 or so) is bad.
Old Aug 22, 2001 | 06:13 AM
HDClown's Avatar
cars do have a voltage regulator, but I'm not sure how they work
 Pouria Savadkouei
 Michael S. Palmer
Old Aug 22, 2001 | 06:16 AM
Tony T.'s Avatar
New Member
Re: 2.2 Volt per cell ... 2.2 x 6 = 14.2 Volt
Old Aug 22, 2001 | 06:25 AM
Tony T.'s Avatar
New Member
Re: Wrong! Sorry. The correct answer is 13.2 V
