sunroof is acting weired. help please
Old Feb 11, 2002 | 06:06 AM
sam'n'philly's Avatar
New Member
Default sunroof is acting weired. help please
hi. i have a 1998 A4. very nice car indeed. 2 days ago, the suroof started developping a problem, and i would appreciate your help on it. i was driving down a highway with my suroof opened, and it started rainning. so i closed it, and right before it closed all the way, it opened again as if it sensed something in its way. i tried it again and again, and for few times, it almost closes, then it suddenly retract open. i finally got it to close. this morning, i thought i would test. so i opened, and when i tried to close it, the same thing happened. right before it closed all the way, it retracted back and opened. i had to try it few times till it closed. any idea on what's going on?
regards,
sam
Old Feb 11, 2002 | 06:16 AM
CraigB's Avatar
AudiWorld Expert
Faulty switch...common problem
Old Feb 11, 2002 | 06:47 AM
New Member
Default Re: Faulty switch...common problem
craig. thank you for your response. what switch are you talking about? is it the rotating dial that closes and opens the suroof or is it a sensor somewhere else?
thanks again,
sam
Old Feb 11, 2002 | 06:49 AM
CraigB's Avatar
AudiWorld Expert
Correct...the rotary switch. It could be something else, but that's the typical problem.
Old Feb 11, 2002 | 06:51 AM
New Member
Default Re: Correct...the rotary switch. It could be something else, but that's the typical problem.
craig,
i am out of warranty. do you have any idea what's the cost of that switch? i assume you had that same problem
Old Feb 11, 2002 | 06:54 AM
BoulderA4's Avatar
Default from the dealer the switch is $74, labor is about $40
you can get the switch cheaper from other places though
Old Feb 11, 2002 | 06:56 AM
New Member
Default thank you very much
thank you craig
islingtonaudi
Audi 100 / A6 (C4 Platform)
Feb 29, 2008 09:20 AM
nguyen1368
Apr 10, 2007 07:01 PM
audiman231
Jan 22, 2006 04:38 AM
FZM
Jul 16, 2004 01:15 PM
mbusby
Oct 23, 2001 09:58 AM
