Engine problem question-
Old Feb 11, 2002 | 07:50 AM
Lance_L's Avatar
New Member
Default Engine problem question-
If the ECU is in a "limp" mode will it stop the turbo from producing boost?
I have a couple of problems with my car and I am curiuos if they are being caused by the ECU.
Old Feb 11, 2002 | 07:59 AM
RedBlackYellow's Avatar
if you said what the problems were somebody can probably help you
Old Feb 11, 2002 | 08:36 AM
Perpetual Novice's Avatar
Default ECU usually goes into limp mode when there's a problem .
But that doesn't mean the ECU is the problem, If you get my meaning.
Describe what's happening, let us know what indicator lights are on, and we'll try to help
Old Feb 11, 2002 | 08:53 AM
Lance_L's Avatar
New Member
Default Cam position sensor error, and now no boost, dealer says turbo is bad.
I just dont feel like buying a new turbo because a sensor is making the car go into limp mode. dealer says ECU is bad, I shipped the ECU to some very competent people and they say the ECU is fine.
Dealer tends to recommend a new ECU very easily as a solution to a problem, great when under warranty, but not when I gotta shell out 600-700 for one.
The car went in making boost but the timing felt as though it was being pulled back, when i got it back they told me "bad ecu" and "bad turbo". Now it has no power.
Old Feb 11, 2002 | 09:06 AM
Lance_L's Avatar
New Member
Default Here is the story...
I have a 1997 1.8t. I started to run rough, not too bad, but it ddin't like to start in the morning. Had to crank it over for a minute while pumping the gas. Initially no lights were present, but after about 6 days of this the CEL came on. I though finally, a code for what the problem is. I figured some sort of sensor.
I brought it to the dealership and they put the diagnostic on the car and got the code for a bad cam position sensor. They then tested the sensor with an ohm meter or some gizmo and it fell within proper specs, then they tested the harness to see if there was a short, no short, then they swapped the sensor for another on and still got the code. They said it was sending a signal but the ecu wasn't responding.
The car is chipped and I have had a similar problem in the past. I sent the ECU bact to shop that did the work to have them check it out. They are unable to find a fault in the ECU (they found a solder jump last time and repaired it - that problem took a year to show up and the car ran fine until then). I trust the shop that checked the computer and they have a very good reputation in my area.
to compound this mess the dealer says the turbo is producing 0 boost and needs to be replaced. (1400 for a K03!), it was making erratic boost before this now none at all?
This car is testing me.
Old Feb 11, 2002 | 09:07 AM
Your ecu carries a 8 year warranty!
Old Feb 11, 2002 | 09:14 AM
Lance_L's Avatar
New Member
Even if I am the second owner?
Old Feb 11, 2002 | 09:31 AM
Default Try to borrow another ECU from someone locally
trade it in and see if the problem goes away. If so, and your turbo starts blowing, you're in luck, just buy a new chipped ecu, several come up in the classifieds.
BTW what chip are you using?
 Pouria Savadkouei
 Michael S. Palmer
Old Feb 11, 2002 | 09:32 AM
Yes, but just read you're chipped. you voided your ECU warranty.
Wahhab
Audi Original "S" Cars
Jul 22, 2009 11:50 AM
Shainz
Aug 1, 2005 04:16 AM
WOT FREAK (BR)
Apr 30, 2004 10:14 AM
tti
Sep 6, 2003 08:13 PM
Ricpat
Apr 16, 2000 05:37 AM
