First trip for dealer service coming up - questions!!
Old Nov 1, 2000 | 05:29 AM
S4_Robert's Avatar
New Member
Default First trip for dealer service coming up - questions!!
I have compiled a list of stuff that I want corrected on my '00 S4 for its 8000 mile service. One of the biggies is the blown rear speaker - if I call the dealership (Rod East in San Antonio) and let them know that I'm coming in soon, can and will they pre-order the part so that it's there when I bring the car in?
Also, here's my list. Anyone have similar problems, and are some of these, in your opinion(s), just too bitchy to bring up?
1. Blown right rear speaker
2. Driver's seat wobbles on weight transfer transients such as launch
3. Strange warbling sound from engine at about 2500RPM
4. Bose radio weirdness (stations, bass, treble)
5. Thwack! sound from rear on some suspension transients
6. Dash rattle
7. Rattle in B pillar right behind my ear
8. Loose shift ****
9. Harsh clutch engagement sometimes on release
I am also going to have them inspect the oil supply seals on the turbos (someone here in Austin recently had one fail) and the washer reservoir (another common failure point)
What think?
Thanks,
Old Nov 1, 2000 | 06:30 AM
WECoyote-SuperGenius's Avatar
Default while you're in have them replace the w/s wiper blades........
it's covered under the warranty/service. did mine yesterday (forgot to have them done when i was in last month and didn't care to make a 3 week appointment just for that). as usual the germans have over engineered even the wiper blades, when replacing "rubber blade inserts" you have to use the old metal tension strips, it was a pain in the *ss to reassemble, i am not a patient person.
Old Nov 1, 2000 | 04:28 PM
BillK's Avatar
Default Be warned...
Just FYI:
2) They will likely say the seat is "within tolerances." Search the list - the problem is not unique to your vehicle. IMHO, it's because the seat motors aren't strong enough to restrain the seat movement via the worm gears.
4) Universal problem with the "Symphony" radio. I'm not sure if there is a real fix, but one I've seen here is to always turn off the radio before you turn off the car.
5,6,7) Sound normal, as my wife's A4 does similar things, but it never hurts to have them check it.
As far as the washer reservoir, just use your washers with the headlights on; if your reservoir doesn't then drain itself in a day or two, you're probably fine...
jmcgeejr
S4 (B9 Platform) Discussion
Nov 5, 2018 08:19 AM
S4Tune
Dec 13, 2001 03:46 PM
ec-s4
Sep 12, 2001 10:16 PM
GolfGL
Jul 28, 2000 04:43 AM
Bobby Kinstle
Jul 21, 2000 08:02 AM
