i took off the drivers side headlight the other night...
Old Nov 1, 2000 | 05:56 AM
Imolsify's Avatar
Default i took off the drivers side headlight the other night...
to check out how easy it was to remove before performing the clear corner mod. after placing it back into its position i noticed that the cutoff was lower than previously. how could i re-adjust this?
Old Nov 1, 2000 | 08:50 AM
Tostao's Avatar
Member
I noticed the same, I just went back and tighten it back while holding it up.
Old Nov 1, 2000 | 09:23 AM
Silver S4's Avatar
Member
Default Get the VWtool/Vag Tool, there is a headlight levelling program in there
Going to need this after you perform the headlight change. Make sure if you are going to replace blinkers to clear that you get it right when the lights are out or you will have to do it again, since you have to pull the entire assembly to change the freakin bulb.
Old Nov 1, 2000 | 10:22 AM
Imolsify's Avatar
thanks guys
riding_dirty
Sep 4, 2016 11:22 PM
richmond5
Oct 6, 2008 06:28 AM
proudA6papa
Feb 19, 2005 06:35 AM
alms_lefko
Oct 2, 2004 04:18 PM
KobeCow
Feb 7, 2003 06:03 AM
