need guidance removing 3rd brake light cover so that.........
Old Nov 2, 2000 | 06:47 AM
WECoyote-SuperGenius's Avatar
Default need guidance removing 3rd brake light cover so that.........
i can clean the area it covers on the inside of the rear window, thanks.
Old Nov 2, 2000 | 08:18 AM
Neutron's Avatar
New Member
Default The interior cover pulls straight off toward the front... (more)
...as you're inside facing the rear window, grab the cover on both sides and pull straight toward you. There are two little clips under the bottom edge that will release without a lot of force. You can also remove the bulb holder by undoing the two Philips screws you'll see, and disconnecting the wires underneath from inside the trunk. The red lens assembly is a little more problematic... it is screwed into the cargo shelf, and the screws are not accessible from underneath in the trunk, so you'd have to remove the whole shelf, I think. But getting the lens off isn't really necessary -- with just the cover off, you can fold up a cloth and wedge it between the lens and the glass enough to pull it side-to-side, kinda like dental floss. Hey, it worked for me!
Old Nov 2, 2000 | 08:29 AM
thanks andy," i'll use the dental floss technique"
Old Nov 2, 2000 | 08:46 AM
MarkFank's Avatar
Default It helps if you gently pry up the cover with a flat nose screwdriver before pulling on the cover.
Prying it up will release the tabs and then just pull back like Andy described.
Old Nov 2, 2000 | 08:57 AM
appreciate the tip
TwinTurboTerror
Mar 6, 2005 02:31 PM
BluDemon
Jun 29, 2002 03:39 PM
kevin99.5
Aug 29, 2001 03:55 AM
KenK in TX
Feb 7, 2001 11:55 AM
MarkFank
Oct 15, 2000 06:55 PM
