Question(s) for Innovator
Old Nov 2, 2000 | 10:27 AM
oliaris's Avatar
New Member
Default Question(s) for Innovator
How difficult it is to change the transmission oil yourself in an S4 6sp? Does S4 have an "uphill" fill hole, does it require any special tools?
The owner manual does not say what oil shoud be used, I did a search and everything points to a 75w90 oil, about 2.9 quarts of it, but nobody says anything about GL-4 or GL-5. Most gearboxes use GL-4, unless high pressure between teeth require GL-5 (like most rear differentials), but the the high pressure additives found in GL-5 are not syncro friendly, as they are probably made of bronze, so I am really split here. I really need to try a different oil (Red Line) because my second gear is so sloppy it takes away much of the pleasure of driving this car.
Old Nov 2, 2000 | 10:36 AM
Ironeagle's Avatar
New Member
Default Re: Question(s) for Innovator
My dealer told me that there is not "uphill" fill hole for the transmission oil like they had it with engine oil. I don't think the S4 even comes with a dip stick for the trans oil either.
Mike in San Diego
May 30, 2007 01:40 PM
beejohn
Mar 12, 2006 11:00 PM
dyagoubian
18
Jan 18, 2006 08:53 AM
Black2001S4
Sep 4, 2003 08:54 AM
maaliish
Mar 13, 2001 04:54 PM
