Anyone know what this fault code means? 16487
Old Oct 22, 2001 | 06:05 PM
cs22's Avatar
New Member
Default Anyone know what this fault code means? 16487
mass or volume air flow circuit high input - intermittent....switched bpv's earlier today. tia
Old Oct 22, 2001 | 06:09 PM
EdP's Avatar
EdP
AudiWorld Uber User
MAF sensor error. I'll look it up in a bit in Bentley.
Old Oct 22, 2001 | 06:22 PM
cs22's Avatar
New Member
Thanks.....let me know
Old Oct 22, 2001 | 06:35 PM
EdP's Avatar
EdP
AudiWorld Uber User
Default Ok, here's what it said....
The best way to do this is to get a vag tool, like vag com.
With it at idle, check data block 002, and get the value for field 4 (air mass).
If at idle it's more than 4.5 g/s, then it's one of two things, load on engine due to accessories, or voltage supply to the MAF or ECU is spiking.
Since your's is intermittent, it just may be due to the A/C cycling at idle on a hot day, or some other large engine load.
Otherwise, take it in to have the wiring checked out. May just be the MAF connector is shorting...
Old Oct 22, 2001 | 07:36 PM
cs22's Avatar
New Member
Default Re: Ok, here's what it said....
Just checked and it fluctuates between 4.2 and 4.4 with an occasional 4.5 - is it normal to fluctuate like that? I live in Minnesota and haven't used the air in a while, and the only extra accessory is a lighted shift ****.
jurq
Jan 2, 2009 07:29 PM
ecgarzone
Aug 18, 2008 03:31 PM
S4-Fireblade
Audi Original "S" Cars
Sep 14, 2005 11:36 AM
Tramper Al
Aug 24, 2004 07:23 AM
DAP@EPL
19
Mar 31, 2003 11:55 AM
