Well hoping to put some rumors to rest.....an alignment is not needed after..........
Old Nov 20, 2002 | 11:28 AM
M3KILR's Avatar
Default Well hoping to put some rumors to rest.....an alignment is not needed after..........
new suspension is correctly installed. Got mine aligned today after three weeks with the H&R/Bilstein setup. I was found to be in perfect alignment already. Thank-god I did'nt have to pay because I have a 3/yr unlimited alignment deal .... :-)......but for those who have to pay Audi I hope this helps. Note..... this was on a car that had already been aligned a month before the install.
Old Nov 20, 2002 | 12:33 PM
George @ BostonAudi's Avatar
Elder Member
You got lucky. Alighment is definitely needed after swapping suspensions...
Old Nov 20, 2002 | 12:58 PM
ConeKiller's Avatar
Junior Member
Default It all depends.
The problem on the s is that camber which is ussually the most signifacant allignment factor is not adjustable. You can only compensate from side to side so assuming the camber is set then once you lower the car the camber will change but will still be equal on both sides which is as good as it gets unless you change to adjustable cpp links. The only thing that could really be affected by lowering is toe and caster. Also you want to make sure that they check the allignment after the new suspension has had some time to settle properly
Nba1008
Q7 MKII Discussion
Mar 22, 2019 04:32 AM
brillianTTdc
20
Aug 21, 2008 07:06 PM
nizmosx
Feb 14, 2004 12:08 PM
ReTodd
Apr 29, 2003 11:11 AM
