Door Panel
Old Aug 31, 2003 | 06:08 AM
GTI--->S4's Avatar
New Member
Default Door Panel
<center><img src="http://pictureposter.audiworld.com/50969/panel.jpg"></center><p>Just went through frustrating process... I had my windows tinted and the shop took a chunk out of the front drivers sdie door panel and cracked the wood trim. THe good thing was they acknowledged the damaged and ordered new parts (they claim they were $600). Well they installed them yesterday and the ended up ripping the door panel slightly again and the trim piece that goes where your hand grabs the door to close the door doesn't fit right. Any tips on getting this piece to fit flush as it should. You can see from the pic that it just doesn't want to meet flush up top. Any help would be appreciated.
Old Aug 31, 2003 | 07:04 AM
B5_S4_NYC's Avatar
New Member
Default just remove the screw on the side and play with that ....
just remove the screw on the side and play with that small piece , it will fit ...door panel comes OFF so easy .. just gatta go UP and remove 2 screws on the side and 2 gold screws under that small plastic that dont want to fit right ..
Old Aug 31, 2003 | 07:09 AM
Steve Trac, Sec 303's Avatar
keep playing with it until it clicks into place. it'll be obvious when it does.
Old Aug 31, 2003 | 08:19 AM
GTI---&gt;S4's Avatar
New Member
Default Re: just remove the screw on the side and play with that ....
It does click into place, but there is a gap at the top. Just one of those things that pisses me off.
Old Aug 31, 2003 | 11:02 AM
sack lunch's Avatar
Senior Member
yeah, mine get's a little moody as well...just gotta show it who's boss and put it in it's place.
Old Aug 31, 2003 | 09:02 PM
Mortt's Avatar
Default Ditto to all these... just pry, push, prod, pull, poke and punish it until it gets in there...
it WILL fit with no gap, I get the exact same problem a lot, just seems like it wont fit until *snap* ...and it does.
Andrew Gilbert
A7
Jun 4, 2016 04:38 AM
mpollan
Sep 6, 2008 02:59 PM
tree580
Sep 30, 2007 07:20 PM
leonpro
9
Nov 4, 2006 05:45 PM
javier mirandes
Nov 24, 1998 08:12 AM
