Is it just me or the power steering is too noisy? (more)
Old Apr 25, 2000 | 07:30 AM
eduardo's Avatar
New Member
Default Is it just me or the power steering is too noisy? (more)
My 2.7T has 920 miles. I like most everything about it but the power steering. For one thing, it is overboosted and a bit slow for my taste. OK, so this is not a TT. But it is also noisy. Not just at parking lot speeds but all the way to 25mph or so, I can hear whining sounds, from the power steering pump, I presume. The noise wouldn't be objectionable in agricultural equipment, but this is a luxury sedan. Is this normal? Do your steering pumps also whine and whirl? BTW, my car has 235/45/17 S-02 Pole Position tires. But the 4.2 has optional 255/40/17 tires. Is the steering in the 4.2 the same as in the 2.7T?
Thanks!
Old Apr 25, 2000 | 08:43 AM
JimOB's Avatar
New Member
My power steering seems very quiet. No complaints on this issue.
Old Apr 25, 2000 | 09:10 AM
eduardo's Avatar
New Member
Jim, do you have a 2.7T?
Old Apr 25, 2000 | 10:27 AM
April's Avatar
AudiWorld Uber User
If you can hear it above walking speed ( should be faint whir ), see your local service dept.
Old Apr 25, 2000 | 04:56 PM
pablo1's Avatar
Eduardo, no noise in my 4.2. I would take April's advice. Good luck resolving it.
Old Apr 26, 2000 | 06:03 AM
GiantIke's Avatar
New Member
Mine got a little noisy once(4.2), while making a sharp turn.
Old Apr 26, 2000 | 08:17 PM
2.7Tango's Avatar
25 Year Member
Default It is not just you!!!
I drive a 2.7T also, it was quiet until about 4000 miles on the odometer when it started making a power steering related whining noise. It only does this at slow speeds, less then 10 mph when turning the wheel, but it is truly obnoxious and will go into service as soon as possible. Btw, I drive on the stock Dunlop 9000s, upon which I just noticed a bubble forming in the sidewall of one of the fronts when making my pre-flight walk around. I have not so much as tickled a curb or hit any pot holes. The tires are at the recommended pressure for expressway driving with two passengers, **** luck I guess
It has also developed a loud whirring that gradually spools up when the climate control is switched on. It is very noticable and seems to come from the fan mounted forward of the radiator. Once spooled up, the whir seems somewhat tied to engine RPM, which suggests to me that it is tied somehow to alternator output.
Otherwise, it is an awesome car!
Old Apr 26, 2000 | 08:37 PM
JimOB's Avatar
New Member
Yes, a 2000 2.7T 6-speed manual.
 Pouria Savadkouei
 Michael S. Palmer
byablun
Jan 31, 2018 11:45 AM
andys3
May 23, 2005 11:28 AM
Nogaro Stg3
Apr 18, 2005 03:34 AM
Obli
Jul 17, 2002 09:08 AM
Tom S
Dec 10, 1999 11:22 PM
