Does this mean I need a VAG tool to adjust Xenons? ..... more
Old May 2, 2001 | 02:49 PM
KL'00-2.7T's Avatar
New Member
Default Does this mean I need a VAG tool to adjust Xenons? ..... more
Per Audi Tech Bulletin -
Subject: Xenon Headlight Adjustment
Before adjusting headlights on vehicles equipped with xenon headlamps, it is critical that you initialize basic settings in group "04", then go to channel "001", and wait until display changes to "set". This will take approximately one minute. Then perform mechanical adjustments and finally set adaptation "002" until value has been learned.Pleases refer to the latest repair information in AESIS group 01, on board diagnostics and technical bulletin 94-98-01.
Old May 2, 2001 | 04:38 PM
pablo1's Avatar
Default My 2000 4.2 has a phillips screw on each headlight. Someone on this board posted it. Piece of cake
to adjust. I did it. Now my low beams are outstanding and no one has flashed their headlights at me.
Old May 2, 2001 | 09:27 PM
Pete RD's Avatar
Same with my 2.7T. Just need a screw-driver, no VAG.
Old May 3, 2001 | 05:35 AM
Norcal2.7t's Avatar
Default Bar 2.7t posted a nice description of adjusting
brake and headlights 2/28/01 @20:37. I have done this and it works well. Needs a 6mm hex and takes less than 5 minutes for headlight.
EdyJun
21
May 14, 2010 09:51 PM
S4Patrick
Jul 29, 2003 01:22 PM
feakara
Apr 5, 2003 10:46 AM
EdP
Oct 29, 2001 08:16 PM
stevews
Oct 14, 2001 05:10 PM
