Do all TIPs act like this? Will a chip help?
Seems dangerous to pull out in trafic and have it shift to 2nd and bog due to low RPMs. Is this something a TIP chip would correct?
yes the engine has plenty of torque in 2nd but it does delay as it shifts to 2nd.I'll play with different throttle openings. Mabey I am a little to gentle with this car but to keep it in 1st is like drag racing.
I have found that staying just above or just barely touching the kickdown allows for the best shifts between all the gears(if your trying to get on freeway or need some extra oomph). Going WOT seems to slow the shift between the gears. I do not know why but have verified it using timing devices.
Even if you dont go WOT and press firmly on the gas, the shift will occur a little higher in the RPM range.
While doing testing with a gtech we found that staying off the kickdown switch improved 0-60 times from .15 to .22. And during these runs it felt as if the 1-2 shift happened quicker. I have tryied to contact Garrett and found out if there was an explanation and will post when I get an answer. The above tests were done with a GIAC TIp chip "race version".
We tried a bonestock A6 Tip and the shifts also felt a shade quicker, but did not have a gtech to measure. Oh ya, all this was done in "D" mode. We found it better to leave it there for straight line stuff. Too hard to hit the shift points correctly while in Tip mode.
