Should I, or shouldn't I (?)...
Old May 8, 2001 | 05:07 AM
JP's Avatar
JP
Junior Member
Default Should I, or shouldn't I (?)...
have the fuel sensors replaced next week? I have an appointment for a 6 month (1 year at 10k miles) service. I'd rather not have the interior torn apart if these "replacement" sensors are going to fail. Opinions?
Dealer/oil/schedule notes; Dealer here is using Valvoline 5W30 which was "recommended". I'm having Mobil 1 0W30 put in.
I was offered a next day appointment if a loaner wasn't required (or anytime after that). If the loaner was needed, first appointment was 1st week of June.
Are there Union 76 stations in Montana?
..../jp
'00 2.7 T
Old May 8, 2001 | 05:45 AM
stanatl's Avatar
Default Re: Should I, or shouldn't I (?)...
I had the fuel sensor replaced in my "01 4.2 and I don't think they had to do anything with the interior. I think they had to drop the gas tank because they told me to try to have the fuel level as low as I could. My guess is that the sensor is in the tank.
Old May 8, 2001 | 06:08 AM
2.7tDallas's Avatar
AudiWorld Expert
they just drop the tank. Take it in low on gas, they will fill it up when they give it back
Old May 8, 2001 | 07:29 AM
Finman's Avatar
11 months for a service appointment?? That's pretty bad
Old May 8, 2001 | 08:08 AM
Richard Solomon's Avatar
Tech Guru
Default I don't believe they actually drop the tank, just empty it...
<ul><li><a href="http://www.vwwebsource.com/vwtechcontent/audipdf/lbcircus.pdf">LB Recall</a></li></ul>
Old May 8, 2001 | 08:13 AM
Tech Guru
Default I'm leaning toward NO
I was in the same position a while back (~6mo ago) and chose to have them replaced...now the "new" senders are flaky
Would I have had the same problem with the "old" ones? Probably. Would I be as annoyed about it? Probably not - I'd just be kicking myself for not having had the replacement done.
FWIW, I believe the tech just lifts the carpet in the trunk to get to a hatch to access the fuel sender. Try reading through the PDF I linked in the lower portion of this thread ... it's not really that complex a procedure.
Old May 8, 2001 | 10:01 AM
April's Avatar
AudiWorld Uber User
Default Your call. They lift out the rear seat. There is a pretty good size
hatch with a hefty seal. It is best if you can bring the car in with a little fuel as possible as it takes longer if they have to pump the tank. They try to avoid removing the tank because it causes a lot of work. If they have to drop the tank, then the rear suspension needs to come out in a QTR. The mechanic would prefer to minimize exposure to fumes as well.
Old May 8, 2001 | 10:38 AM
2.7tDallas's Avatar
AudiWorld Expert
My bad - I just called my tech and they agreed
 Pouria Savadkouei
 Michael S. Palmer
Old May 8, 2001 | 11:40 AM
JP's Avatar
JP
Junior Member
Thanks - I fixed that. :-)
Old May 9, 2001 | 07:04 AM
JP's Avatar
JP
Junior Member
Thanks everyone - see above - think I'll try a poll of 2nd failures.
RoberTT-WWCD
20
Aug 1, 2005 06:06 AM
squishball
Audi allroad
Oct 12, 2003 06:27 PM
System_S4k
Nov 6, 2001 06:00 PM
benn
Jan 10, 2001 03:58 PM
