keyless entry acting funny
Harinder
I'm guessing your problem is intermitent because you are probably unknowingly performing the re-sync sequence just to get into your car. (pressing fob button; button doesn't work; put key into car and open manually).
The owners manual details the procedure and causes, but long & short is don't press the key fob buttons if the car is out of range.
I ended up having to go inside and pull the door handle on the inside to unlock the door. I realized later that I probably could have stuck the key in the door and turned it to do it also. Of course, if this happened on one of the other three doors which don't have key locks, then I couldn't have done that with those.
