Un-chipping for a day......... What Codes to clear
There should only be one code that indicates a loss of power, which is what would let someone know ecus had been removed. There should be no other code.
Then you should do a throttle body adapt.
In the Engine module, click on Measuring Blocks
Insert under Group the numbers "060" and then click "switch to basic settings"
You should see numbers run up and down in the four spaces to the right of the group 060.
When the numbers stop,and it indicates ADP OK, your throttle adaptation is done
Let me know if you need more info
