1998 Audi A6 Q
Old Apr 10, 2003 | 05:20 AM
MCB 1973's Avatar
New Member
Default 1998 Audi A6 Q
Has anyone had their muti function switch fail in their Audi A6?
Old Apr 10, 2003 | 05:47 AM
KellerA6's Avatar
Default Re: 1998 Audi A6 Q
I had a problem with the display being very washed out and they replaced it under warranty. The switch itself was fine.
Old Apr 10, 2003 | 08:11 AM
QCRAZY's Avatar
There's about 100 things in an Audi that could use that name...what are you referring to??
Old Apr 10, 2003 | 09:58 AM
AudiForYou's 4.2's Avatar
Junior Member
Default Gremlins in the tranny? - HANDS-ON ENTHUSIASTS, please help!
Back-up lights light up in park. Go out once you switch to drive.
Check engine light.
Under engine fault codes - 18032 MIL Signal Active
Under Transmission:
00293 - Multifunction Switch (F125) 27-00 - Implausible Signal
00526 - Brake Light Switch (f) 27-00 Implausible Signal
Any way I can trick out the ECU to stop it from throwing these codes? I can clear the code and drive around without it reappearing, but as soon as I re-start the car, the check engine light comes back on.
So far I've heard
a) check all bulbs (fine)
b) replace the multi-function switch that sits somewhere on the transmission
Who's got some ideas?
Thanks for helping.
Old Apr 11, 2003 | 12:51 PM
MCB 1973's Avatar
New Member
All repaired, dealer told me that a wire had become loose behind the fuse panel, causing mega codes. all ok.
Boatdude
May 27, 2013 11:17 AM
omen62
Audi 100 / A6 (C4 Platform)
Dec 24, 2010 04:34 AM
JohnLZ7W
Feb 26, 2007 06:50 PM
BCD
VAG-COM Discussion
Dec 12, 2003 07:44 AM
AudiForYou's 4.2
Apr 11, 2003 07:37 AM
