New rotors on all 4 today! :-)
Old Apr 14, 2003 | 04:03 PM
Haystack's Avatar
Default New rotors on all 4 today! :-)
My stock rotors became very badly corroded while my car was sitting for a month while waiting for some body parts last summer. The water collecting around the pads corroded a nice pad-shaped oval in each rotor. I figured they'd wear off, but wrongo! The brakes got worse and worse until I had so much vibration under braking that I literally could not see out of the rear view mirror!
Warranty replacement is a many splendored thing however, and today 4 brand new shiny rotors were installed.
I went easy on them for about 5 miles, then performed 80-30 cycles a number of times.
The brakes are now (and for a while, I hope) smooth as silk!!!
Small pleasures, but nice brakes are... nice brakes!
Old Apr 14, 2003 | 05:44 PM
ZCD2.7T's Avatar
GREAT Sig! So, where are the gradations on the scales???
Old Apr 14, 2003 | 06:48 PM
Haystack's Avatar
Default About my sig...
I tried to line the grid up roughly with the dyno plot on the Stratmosphere site. The units there were kind of funky, so I left them off to give a cleaner look.
According to O.CT specs, I should have pretty close to 400lb-ft of torque and just over 370HP with my current setup.
What is really interesting is the smooth delivery of power -- silky smooth right to the top of the tach! I think it is partly due to the flat torque curve, and partly magic! I feel that it is as smooth or smoother than stock with a TON more torque and HP!
Basically from 2300 or so right to 6500 my car just keeps on pulling! I have not been to the drags, but a similarly set up A6 is running in the low 13's. Not bad for a 4000 lb luxury sport sedan IMHO!<ul><li><a href="http://www.stratmosphere.com/oct_a6_stage4.htm">click for the A6 Stage 4 page at Stratmosphere</a></li></ul>
Old Apr 14, 2003 | 10:14 PM
6sidua's Avatar
fun sig, you might consider a red line to graph depreciation, with bars added for service costs....
5v/cyl
May 19, 2011 11:37 AM
vegaS4
Sep 2, 2005 09:31 AM
lookaught::02_Avant!
Apr 11, 2005 05:48 AM
paulroad
NY / NJ / CT Discussion
Jun 30, 2004 05:12 AM
hermitage1
9
Mar 18, 2003 08:56 PM
